Old airframe, new engine
Old October 20th 03, 05:16 AM
WaltBJ
Mary Shafer wrote in message . ..
On Tue, 14 Oct 2003 22:41:47 +0100, "José Herculano"
No jet ever made (or that ever will be made) had enough power.
Possible exception of the F/A-22 Raptor under current conditions...
How about the big black twin two-seater I used to work on? Whatever
its limitations, lack of thrust wasn't one.
It's not every airplane that can burn 85,000 lb of fuel in just over
an hour, you know.
Mary
Come on, Mary; an F4 on the deck burns at the rate of 1500 a minute,
90,000 an hour, and even goes a lot faster than the 71 down there. Of
course, it'll be dry in about 7 minutes (clean), but it's a great ride
to bingo. Once I took an F4D up for a test hop for a rudder actuator
change. (Fly; if it's ok, land.)The original one had cracked and
leaked red fluid all over . . . . the crew chief asked me to get the
residual hydraulic fluid out of the aft section. Flat out around 750
KIAS at 100 ASL off shore of Kunsan Korea did a good job of blowing it
dry. The fuel state visibly reduces, too.
Walt BJ
Old October 20th 03, 04:36 PM
mah
James Woody wrote:
I did not see it listed on the web site.
http://www.combatairmuseum.org/aircraft.htm
Any other information on this bird?
Woody
Dug through my photos from the trip. 66-268 looks to be a C/D with a
Mig kill on 12 Oct 1972. Left side painted as it was when assigned to
SEA, right side painted when assigned to KS ANG. The aircraft is decked
out for air defense with drop tanks, 4 x sidewinder, and 4 x sparrow.
Don't have access to binary groups through my ISP or I'd post photos.
If you are interested in photos, I can email them. (I remove the
NOTAT?)
MAH
Old October 20th 03, 08:53 PM
Mary Shafer
On Wed, 15 Oct 2003 15:49:15 -0500, catsrus
Mary -
Is there any sensible reason why your airframe was retired from
service when it still seemed to be viable?
No agency mission. We didn't have any experiments that justified
keeping it going.
Was it only a money issue or is there more to it than that?
I suspect that money was part of the decision, since it usually is,
but it was probably more of an effect than a cause.
Mary
Mary Shafer Retired aerospace research engineer
Old October 21st 03, 03:42 AM
Mary Shafer
On Tue, 21 Oct 2003 01:14:57 GMT, "Doug \"Woody\" and Erin Beal"
On 10/20/03 3:06 PM, in article ,
"Mary Shafer" wrote:
Incidentally, most people know that the SR-71 used the dipsy-doodle to
convert potential energy to kinetic energy (altitude to velocity)
through the transonic region. Many people think it could only go
supersonic if it dipsy-doodled, but that wasn't the case. It could
get supersonic flying straight and level, too. However, as soon as it
did, it pretty much had to slow down and go look for the tanker. This
took a little longer than seven minutes, though.
Is the "dipsy doodle" what most fighter pilots refer to as the Ritowski
climb?
I don't know, as I don't know exactly what the Ritowski climb is. I
think it is, though.
Essentially, the SR-71 climbs at constant qbar (400 KEAS) to Mach 0.9,
then descends at a constant rate to Mach 1.25 (450 KEAS at 30,000
feet), and then climbs again at a different constant qbar (450 KEAS)
to cruise.
I would assume so since that's the recommended procedure for getting most
supersonic aircraft going high and fast quickly and without running out of
gas.
Seems reasonable to me that it would work generally, not just for the
SR-71.
Please elaborate. And what were the specifics of the profile for the SR-71
(as long as it's not classified, of course)?
Naturally, I'm here and my Dash-1 is there, so I can't produce the
exact numbers unless they're in the Researcher's Handbook. Let me go
look. OK, I'm wrong, I do have the Dash-1, which was hiding on the
wrong shelf.
I'll still going to look first in the Researcher's Handbook, except
that it doesn't have an index. An index won't help, though, because
"dipsy doodle" isn't exactly an official USAF term. Nada.
OK, here it is from the Dash-1. It's pretty long, but I thought you'd
prefer the exact description, not my briefer version of it. It's "a
climb-and-descent maneuver". You'll have to imagine the typography,
boxes, and indentation yourself, though.
TRANSONIC ACCELERATION PROCEDURE
Transonic acceleration is accomplished at either a level altitude or
during a climb-and-descent maneuver.
NOTE
The climb-and-descent acceleration is recommended for best specific
range (NM per pound of fuel used).
Level Acceleration
A level acceleration to intercept the supersonic climb speed schedule
can be made at refueling altitude, normally 25,000 feet. When ambient
temperatures are near or lower than standard, less time and distance
are required to intercept the climb speed schedule than the
climb-and-descent procedure. The total range penalty is small under
these conditions.
Start the acceleration with minimum afterburner. Complete course
changes while subsonic so that the additional power required for
turning will not diminish the power available for transonic
acceleration. Set maximum power at Mach 0.9. Gently increase pitch
to climb attitude near 430 KEAS. A smooth technique is required, as
450 KEAS is only slightly more than Mach 1.1 at 25,000 feet and is
still within the critical thrust/drag speed range which begins near
Mach 1.05.
WARNING
Airspeed may increase rapidly after Mach 1.1 is reached. Reduce power
(below Military, if necessary) to avoid high airspeeds. Do not use
excessive load factors to prevent exceeding 450 KEAS,
The procedure can be used at another altitude; however, when lower,
the transition to 450 KEAS climb attitude must be made in the
unfavorable speed range from Mach 1.05 to 1.10. At higher altitudes,
the transition through this speed range can be completed before
starting the climb, but less thrust is available. If ambient
temperature increases, thrust decreases and the time, fuel, and
distance penalty for using the level acceleration procedure is
greater.
Climb-And-Descent Acceleration
The climb-and-descent procedure requires less fuel to intercept the
climb speed schedule than the level acceleration when ambient
temperatures are warmer than standard.
NOTE
The climb-and-descent procedure is recommended for best specific range
(NM per pound of fuel used) at all temperatures.
WARNING
Although angle of attack increases during the subsonic climb, pitch
attitude must decrease to avoid dangerous flight conditions. Failure
to monitor and control attitude, speed, and angle of attack can result
in approach to pitch-up conditions.
Start the acceleration with minimum afterburner power. Intercept Mach
0.9. Set maximum afterburner at 30,000 feet for the remainder of the
acceleration, observing the 300 KEAS restriction. At 33,000 feet,
increase speed to at least Mach 0.95. This speed is slightly above
the start of the drag rise region. Make a smooth transition to
establish a 2500 to 3000 fpm rate of descent.
NOTE
Engine stalls during the subsonic climb may indicate a potentially
dangerous flight situation. Stalls can result from low CIP or high
distortion in the inlet associated with aircraft operating beyond
established flight limits. Refer to Subsonic Compressor Stalls,
Section III.
After establishing the descent rate, maintain attitude until
initiating climb. Avoid higher rates of descent since the usual
result is altitude penetration below 29,000 feet and high fuel
consumption. When using the climb-and-descent procedure, it is
important to exceed Mach 1.05 early in the descent, and to avoid
turning until the climb is established. Begin the transition to climb
near 435 KEAS so as to intercept 450 KEAS while climbing.
WARNING
- Airspeed may increase rapidly after Mach 1.1 is reached. Reduce
power (below Military, if necessary) to avoid high airspeeds. Do not
use excessive load factors to prevent exceeding 450 KEAS.
- In turbulence, reduce climb speed as specified in Section VII,
Operation in Turbulence.
This is just over a page, but the SUPERSONIC ACCELERATION PROCEDURE is
two and a third pages.
Mary
Old October 21st 03, 12:47 PM
John Carrier
I'm curious why the 450 limit is such an issue ... your quote implies bad
things happen if it's exceeded. I realize the SR had a relatively low
q-limit, but I didn't believe it that low. Was another factor the issue?
R / John
Old October 21st 03, 01:03 PM
Doug \Woody\ and Erin Beal
On 10/20/03 9:42 PM, in article ,
climb?
to cruise.
gas.
SR-71.
wrong shelf.
NOTE
Level Acceleration
these conditions.
Mach 1.05.
WARNING
greater.
NOTE
WARNING
NOTE
Section III.
WARNING
Mary
Mary,
Thanks for the detailed response. Must come with the retirement. I'm
interested in the 450 KEAS limit and the "Do not use excessive load factors
to prevent exceeding..." comment. What is an excessive load factor in this
flight regime. 1.5G? 2.0G?
The Ritowski climb is essentially the same thing. I think that the numbers
are different for most aircraft, but for the Hornet, it's 400KCAS to .85 in
the mid 30's, push it over to exceed 1.0, and climb supersonic afterward.
Works great on FCF's for the mil lock-up procedure (above 1.23M).
--Woody
  #28
Old October 21st 03, 08:35 PM
John Carrier
Just out of curiosity, Woody, what is the fastest you've had the Hornet in
KIAS and IMN? I had a TPS guy claim 800/1.8 for the C, but I think he was
feeding me pure unadulterated BS. In my brief exposure, I was astounded by
its LACK of speed.
R / John
  #29
Old October 21st 03, 10:29 PM
On 10/21/03 2:35 PM, in article , "John
its LACK of speed.
R / John
John,
I've never seen that with my own eyes--and I doubt he has either unless the
jet was slick and new and he had a full tank allocated for just that
purpose. 800/1.8 are the "do not exceed" limits in the book.
I've never had a dedicated hop (or the desire) to make an attempt at them.
Fastest I've had the Hornet was doing the mil lockout test on an FCF about
2-3 years ago in W174C (Key West). I coaxed it to 1.46 at 35,000 in a 20
degree dive down from 45,000 before I got a R DUCT DR caution and had to
slow up. It was a slick jet, and I could have probably gotten it faster...
had it been working correctly.
Most I've ever seen in the HUD is 710 KCAS, but that was at approximately
1.06 at 200 AGL off shore San Diego making a supersonic low pass (combat
spread with my -2) on a Coast Guard cutter we were working with. It was a
LONG run-in for fun/show. As a section, we brought one jet down each side.
I had a slight advantage with the EPE motors. (We had finished a sea
surface search radar test early.) We were configured single centerline
tank, no pylons. I don't think it would have gone much faster than that.
I know you didn't ask, but being a chicken with regard to aviation
physiology, I've never climbed one over 53,000 @ 1.10--and that was circa
1994 out in the R2508 when I was a "Laker." It would have gone much higher
in my opinion.
Got any F-8 or Turkey personal experience numbers you want to share? I'd
assume they'd be much better.
--Woody
  #30
Old October 22nd 03, 02:53 AM
WaltBJ
Re the 'Rutowski' climb path. We got the word from Eglin AFB around
1965 and used it in the 104A with the old J79-3b engine. It worked
nicely but had to be flown precisely to avoid wasting fuel. When we
got the J79-19 it was such a thrust improvement (17900 vice 13850) we
didn't bother. One nifty climb profile was to accelerate to 600 KIAS
at say 1000 AGL after T/O (height optional as long as you didn't get
caught) about a mile or so off the end of the runway and then maintain
600 to crossover to M2.0. Made for quick intercepts and was quite
exhilirating! This was a real case of a new engine (F4E/S)in an old
(1956) airframe.
Walt BJ
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
