A6 Intruder----Question?
Old October 28th 03, 12:27 PM
Kurt {:{
Default A6 Intruder----Question?
Hi,
I was to an air show awhile back. I was inspecting a Navy A6 Intruder. I
caught the exhaust end of the tail pipe and noticed a circumference of
mesh "feathers" on the inner ID, that honestly looked like dragonfly
wings, gossamer in texture. I wonder what the function of this is, what
the material is, and how is it produced? A stamping process is a guess.
Material---titanium?
Thanks.
Kurt
Old October 28th 03, 04:25 PM
Larry
It must have been WAY back- no A-6E Intruders are flying anymore since
VA-196 sent the last to the desert in the mid 90's. What you saw was likely
an EA-6B Prowler, easily recognizable by the two canopy (four seat)
configuration.
I caught the exhaust end of the tail pipe and noticed a circumference of
The exhaust ducts hang suspended away from the heat shield in the rear of
the engine cavity to facilitate movement of cooling air around the engine.
These "turkey feathers" (the official nickname by the way) you saw, make up
the rear barrier of this ventilated area. They are some high-temp alloy, but
I'm not sure if it titanium or not.
When I worked QA in the Prowler community, a detailed inspection of this
area was required during every engine change or drop. The "turkey feathers"
also help keep the tailpipe centered, which is essential for safe flight.
Larry
AECS (AW/SW/MTS)
Disabled Combat Veteran
USN Retired
20 years of Navy in my rear view mirror
and getting further away every day ;-)
"Kurt {:{" wrote in message
Hi,
Thanks.
Kurt
Old October 28th 03, 05:48 PM
Andrew Venor
configuration.
Unless he went to the airshow they had in Eugene, OR a few months back.
The Oregon Air and Space Museum towed their A-6 out of the hanger and
had it on display for the weekend.
ALV
Old October 28th 03, 08:01 PM
Larry
Cool. I didn't know they had one down there.
The motors are basically the same configuration as the Prowler (just a
little less thrust).
Larry
AECS (AW/SW/MTS)
USN Retired
"Andrew Venor" wrote in message
ink.net...
likely
configuration.
ALV
Old October 29th 03, 03:09 AM
Kurt {:{
Hi guys,
Thanks for the response.
Yeah, I'm former Navy myself---SEABEES, Builder Rate.
"Awhile back" for me was about 1991 to a commercial airport, just south
of Scranton, PA , them doing a military air show, also with the Blue
Angels F-18's. I think the facility was called Aviation Park, just off
Rt.81.
It was a two seater A6 Intruder with a refuelling arm out the front of
it and one Navy pilot in a flight suit was tending to it, he looked
kinda' bored. I should have asked him my question then, but I didn't.
I was looking in the tail end of the engine. These "turkey feathers"
were right there at the rear end of the exhaust, a circular ID laying
and overlapping and interconnecting other "turkey feathers," they were
laying on top of the ID of the external metal of the outer combustion
chamber. Sorry about the lousy description, I'm not familiar with the
jargon of such stuff.
I frequent rec.crafts.metalworking and I 1st posted these questions
there. One guy wrote me privately to try your site here as to a more
detailed explanation. And the best explanation so far, if indeed it is
true, from a Brit off the metalworking site. I thought former Navy
aviators would have given a more detailed, aerodynamic engineering
explanation.
But thanks anyway,
Kurt
His reply:
Group: rec.crafts.metalworking Date: Mon, Oct 27, 2003, 10:14pm (EST+5)
"Don't know how they're made but the tail feathers are used to form the
variable geometry exhaust nozzle. They close down or open up to control
the jet exhaust and hence thrust. I suspect that they are titanium."
My original query:
On Mon, 27 Oct 2003 12:50:31 -0500 (EST), (Kurt {:{)
Hi,
No, I'm not into the inner workings of such.
Thanks.
Kurt
Old October 29th 03, 05:01 AM
Andrew Venor
Larry
AECS (AW/SW/MTS)
USN Retired
It's a small museum on the back side of the airport, but it has a couple
of nice aircraft in the collection.
http://www.oasm.org/
ALV
ink.net...
likely
configuration.
ALV
Old October 29th 03, 06:00 AM
Larry
Some guy thought he knew what he was talking about when he spouted:
LMAO! Nope- not even close.
Prowlers and Intruders (all flavors of the A-6 family) just got a little
bend in the exhaust- nothing more.
Thanks for the chuckle! :-)
Larry
AECS (AW/SW/MTS)
USN Retired
(way too much time spent on broken Intruders)
Hi guys,
Rt.81.
explanation.
But thanks anyway,
Kurt
His reply:
My original query:
Hi,
Thanks.
Kurt
Old October 29th 03, 06:09 AM
user
Prowler Motors are mostly J52-408Bravo's now. Same thrust as the
408A's (10,400 - 11,200 lbs per motor) but modified to try and
eliminate the "chugs", (didn't work, the compressor still stalls under
the right conditions), also have new 3 1/2 bearings and a reinforced
or beefed up compressor casing.
On Tue, 28 Oct 2003 07:27:07 -0500 (EST), (Kurt
{:{) wrote:
Hi,
Thanks.
Kurt
Old October 29th 03, 06:22 AM
user
Maybe he is talking about the "turkey feathers" on a F110-GE-400 or
the TF-30's on the Tomcat? Either way his message don't make sense!
On Tue, 28 Oct 2003 22:00:31 -0800, "Larry"
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 06:05 PM
