Was The Grumman "Bearcat" Flown Off Carriers?
Old January 22nd 04, 08:41 PM
Jack G
Would that be the Douglas B-26 (JD) or the Martin B-26 (JM) :O)
Jack
"Nice Again" wrote in message
I can picture the JD in my mind but I have trouble with the B-26.
link.net...
F fighter
8 eighth model
F Grumman
I did not ask for an explanation of the Navy's bizarre designation
system,
it was your message that was a mystery.
  #32
Old January 22nd 04, 08:44 PM
Lynn in StLou
Nice Again wrote:
That's one of the points, you can tell the mfg. Doh!
It was was pointed out in another forum that you can tell
the manufacturer of an AF craft if the complete designator
is used. Such as:
P-38J-25-LO
P-47D-25-RE
P-51H-5-NA
B-17F-1-DL (Built by Douglas)
B-17F-1-BO (Boeing)
The Navy simply made it a more integral part of the
designation. I do not know if this holds true still in the
standardised designation system.
Lynn in StLou
REMOVE anti-spam measure to reply
  #33
Old January 23rd 04, 02:03 AM
Thomas Schoene
I'd call it a bug, not a feature. If it told you the designer, it might be
of some value, but manufacturer names are often too fluid to be helpful. As
is, the system is potentially quite confusing, as the examples given before
can show (F4U, FG and F3B are the same plane!?!) It makes little sense to
use a system that requires different designations for the same aircraft just
because it was built by different companies or the factory changed
ownership.
Moreover, from an amateur's perspective, the Navy system makes it difficult
to instantly recognize which aircraft came first in production, or tell
which are contemporaries of each other. The F4U and F4D aren't even
remotely of the same era, for example, but you can't tell that from their
designations. OTOH, you can tell that the F-14, -15, and -16 came in that
order and probably realize that they are rough contemporaries.
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
  #34
Old January 23rd 04, 02:46 AM
Steven P. McNicoll
So what? With that system you wind up with multiple designations for
virtually identical aircraft. A Corsair could be an F4U, an FG, or an F3A.
Boeing, Douglas and Vega all built Flying Fortresses, but under the USAAF
system they were all B-17s.
  #35
Old January 23rd 04, 02:49 AM
Steven P. McNicoll
The Navy system wasn't bizzarre.
The Navy system had multiple designations for virtually identical aircraft.
That's bizarre.
It made it easy to identiy a/c (mental
picture) by just the lettr and numbers.
No easier than the USAAF/USAF system, which had the advantages of order and
logic.
  #37
Old January 23rd 04, 02:52 AM
Steven P. McNicoll
I can picture them both, and the JM too.
  #38
Old January 23rd 04, 02:59 AM
Steven P. McNicoll
"Thomas Schoene" wrote in message
link.net...
be
As
before
Ah, but they're not the same plane! The F4U was, of course, the Vought
Corsair, and the FG was a Corsair built by Goodyear. But the F3B was a
Boeing biplane fighter of the late twenties. The Brewster-built Corsair was
the F3A.
  #39
Old January 23rd 04, 03:06 AM
Ogden Johnson III
That's bizarre.
logic.
But.
The USAAF/USAF system didn't permit any fun aircraft, like B1RDs.
OJ III
[Email sent to Yahoo addy is burned before reading.
Lower and crunch the sig and you'll net me at comcast]
  #40
Old January 23rd 04, 03:21 AM
Steven P. McNicoll
"Ogden Johnson III" wrote in message
The Navy system didn't allow a B1RD.
Grumman FAAV? Charles Gray Military Aviation 1 July 19th 04 06:55 AM
Most aircraft types flown by 1 pilot? Chad Irby Military Aviation 10 January 7th 04 03:47 AM
