STOVL and CTOL from big decks - deconflicting ?
Old March 2nd 04, 08:14 PM
John S. Shinal
Default STOVL and CTOL from big decks - deconflicting ?
I'm merely an amateur observer, but it looks like there are a
couple of issues.
Deployment to theater - means one fewer USN CTOL squadrons
aboard the carrier once in theater. This might not be a big deal if
you are mostly tasked with CAS for Marines, but for a large campaign
using two CVNs, would they configure both air wings with a Marine
squadron or not ?
Cyclic ops - CTOL has long operated with tightly timed
launches and deployments - do you launch and recover CTOL a/c together
and STOVL together, but never mix types ?
How do you change over deck if you are landing a stack of CTOL
a/c and a STOVL has a an emergency landing ?
Are they planning deck run takeoffs with JSF ? (!!!!!)
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Old March 3rd 04, 11:05 AM
Guy Alcala
couple of issues.
squadron or not ?
No idea. But if the opportunity arose to move the marines ashore to an FOB, they
probably would.
That certainly can be an issue, but with the reduced airgroups there may well be room
to do both simultaneously. Perhaps the angle will be used by the STOVL a/c to make
free runs, while the bow cats shoot off the rest, or vice-versa (this will require
some experiment). The ability of STOVL a/c to make simultaneous or near simultaneous
landings (by section or on CVs, even by division) probably makes landings, at least, a
non-issue.
Where's the problem? Even assuming that the STOVL a/c can't just find a piece of
empty deck starboard, it can just get in the regular pattern. It's not as if they
have to reconfigure the deck (or do emergency pull-forwards), as would be the case
with a conventional carrier a/c declaring an emergency.
Sure (I assume you're referring to the F-35B). FAIK they could do them with the
F-35Cs as well, at least when fairly light, if they've got the t/w ratio. This would
return the situation to what it was in WW2, when a deck-load strike was catapulted off
until there was adequate t/o run available, at which point the remaining a/c made
(faster cycle) free take-offs. Typically the fighters were furthest forward as they
required the shortest run, then dive bombers and/or torpedo planes.
Guy
Old March 4th 04, 01:27 AM
Frijoles
"John S. Shinal" wrote in message
couple of issues.
squadron or not ?
Not sure what your concern might be. Marine squadrons routinely deploy on
CVs today (and have for some time). For the most part, they fly the same
missions that their Navy counterparts fly.
It remains to be seen how the cycle would be run with STOVL JSFs. AV-8As
deployed on FDR in the late 70s, so it's not impossible. There is some
additional flexibility that comes with the ability to stop and land, but it
will be interesting to see how the Navy uses it. There will be great
inertia to make it operate like the conventional cat-trap aircraft on board.
What's to change?
Absolutely.
News==----
Newsgroups
Old March 4th 04, 04:19 AM
John R Weiss
"John S. Shinal" wrote...
For timing purposes, it shouldn't be much different than a mixed A-6 / F-4 or
F-14 / F-18A/B flight deck -- the cycle time is controlled by the shortest
endurance.
In the case of the former, there was enough organic tanker support to keep the
F-4s alive for a 1+45 cycle. In the latter case, the F-18s dominate, and normal
cycle times are reduced to 1+30 or less.
When you come to a F-18 / F-35 STOVL loadout, there could be a LOT of F-18
tankers supporting 1+30 cycles for the F-35, or the cycle times will be reduced
to 1+15 or less. OTOH, maybe cyclic ops will become history, and "flex deck"
will become the norm...
OTOOH, I don't see the F-18 / F-35 STOVL loadout as a "normal" loadout...
That's not a problem at all -- the landing area is clear, and you just delta the
CTOL until the emergency gets aboard.
Old March 4th 04, 05:23 AM
Guy Alcala
endurance.
to 1+15 or less.
snip
Don't see why. The F-35B will have considerably more internal fuel than an F-18A-D
with similar weight, a single engine and no need for 3-5,000 lb. of recovery fuel
reserve. Marine profile mission radius (KPP) is 450nm from a 550' STO (590nm for
the USAF F-35A mission profile; 600nm for the USN F-35C mission profile), with a VL
bringback of .2 x 1k JDAMs and a pair of AIM-120s, plus reserve fuel.
Guy
Old March 4th 04, 06:26 AM
John R Weiss
"Guy Alcala" wrote...
reduced
to 1+15 or less.
F-18A-D
fuel
for
a VL
What are the comparative thrust and specific fuel consumptions of the 2
airplanes' powerplants? What will the fuel burn be for a typical approach and
vertical landing for the F-35?
Why will there be a significantly lesser fuel reserve requirement? Will the
bingo fuel requirement be less for a STOVL airplane than a CTOL airplane?
The F/A-18 hasn't met fuel specs yet, to my knowledge. The A/B/C/D never met
the original requirements, and the C/D specs were "adjusted" so much from the
original requirements that it is almost impossible to make an apple-apple
comparison.
So far, I believe the combination of cost and performance requirements for the
F-35 are hopelessly optimistic...
Old March 4th 04, 03:48 PM
John S. Shinal
There is some scant info from RN 801 Squadron in their
Falklands ops on INVINCIBLE. ISTR that Sharkey Ward insisted they use
their fuel on CAP and not in the pattern, with some *really* low fuel
loads at land-on, and not much burned during their approach and
translation maneuver. Most 801 flights were 2 ship CAPs.
Is there a USN "best practice" for fuel load at the trap ?
Five minutes of fuel at a given SFC, or something like that ?
Old March 4th 04, 04:26 PM
John R Weiss
Policies during actual wartime may differ significantly from "peacetime"
practice. Actually saving the ships from incoming missiles tends to make a
single airplane a reasonable trade...
That has evolved through the years, based on experience, changing tactics, and
risk-averse trends on the part of the upper echelons...
In my 81-83 A-6 cruise on Midway, our daytime minimum was 3.5-4.0 (3500-4000 lb
at landing), and 4.0-5.0 at night. By the time I got to Kitty Hawk in 87, it
was 5.0-5.5 day and max trap (6.0-7.5, depending on airframe and loadout) at
night. Nimitz 88-89 was essentially max trap all the time...
I don't know what the current state of affairs is...
Unless the ship is working "blue water" (no divert field available), min landing
fuel is usually the fuel required for divert. In "blue water" ops, numbers
similar to those I cited above come into play. Generally, 2 looks at the ball
(maybe 3 at night) plus min landing fuel for the airplane (e.g., 2.0 for the
A-6).
Old March 4th 04, 08:18 PM
Woody Beal
On 3/4/04 10:26, in article yMI1c.178613$uV3.756299@attbi_s51, "John R
Weapons bring back typically influences these policy decisions.
SNIP
Case I "charlie" (day/VMC) is tank plus three passes (2.5 +.4 + .4 + .4) or
3.7.
Case II/III (night/IMC) "charlie" is night tank plus two passes (3.0 + .8 +
..8) or 4.6.
All this is from memory (i.e. I know the numbers [3.7/4.6] are correct, but
the calculation method may be slightly off without refreshing my knowledge).
Other carrier guys feel free to jump in and correct me.
--Woody
Old March 5th 04, 01:01 AM
Guy Alcala
reduced
to 1+15 or less.
F-18A-D
fuel
for
a VL
Actual thrust numbers, SFC, BPR, pressure ratio etc. are all still unavailable for
the F135 and 136; basic layout (turbine and compressor stages) is about all that you
can find. P&W & GE both just say "40,000 lb. thrust class." I've seen somewhere
(but can't find it) that Rolls-Royce mentioned ca. 34,000 lb. dry, 56,000 lb. wet
for the F136, but that may include the lift fan. The F136 is based on the F120
design, and IIRR that engine was variable-cycle. The use of the lift fan eliminates
the Harrier problem of needing a very high bpr to generate sufficient lift for VTOL,
screwing the SFC in throttled back cruise or at high CAS.
As to the F-18A-D, off the top of my head F404-400s were rated at about 10,800 lb.
mil (or maybe that was the internal fuel), 16,000 lb. A/B, with the -402 boosted to
17,600 lb. max. A/B.
Considering how low it was for the Harrier, with the F-35B being easier to control,
it should be minimal. Harrier transition and landing takes a minute (or two at the
outside), with max. fuel burn (wet) of 220 lb./minute for the -406, and presumably a
bit more for the -408. The F-35B probably has between 50 and 100% more power in the
hover, with a newer engine design and using an optimized lift fan plus a
less-optimized core engine, so you can make your own estimates.
Because there's no little need for multiple looks at the deck -- no bolters, no
fouled decks. Enough fuel for one go-around seems to be about the max required, at
least in wartime. Peacetime requirements will undoubtedly be greater, but still
considerably less.
Will the
Are you referring to bingo fuel to the beach, or mission bingo? You have little
need for the former. In Sherman Baldwin's book "Ironclaw," he describes the Midway
trying to get a single F-18 back on board at night just prior to DS, while they were
running at 30 knots or so, directly towards Iranian territorial waters. IIRR they
tanked the guy a couple of times, and spent an hour getting him aboard. Just about
the time they were going to have to bingo him because they had to change course to
stay out of Iranian waters, they got him aboard. None of that would have been
necessary if he'd been flying a STOVL a/c. The Midway could have been cruising
along at any speed above steerage way, and he would have recovered on the first
pass.
For mission bingo, it has been less for Harriers. As John Shinal alluded to, during
the Falklands war, the CO of 801 Squadron told his pilots that if they landed back
on board with more than 800 lb. of fuel from a CAP mission, he'd "put his boot up
their arse." Average fuel at land on seems to have been under that, in the 600 lb.
range, with several landings with 400 lb., and in at least one case, when the
visibility was perhaps 50 feet in fog and the pilot in question made one missed
approach and then had the carrier shine a spotlight straight up, descending
vertically next to it and landing on without ever seeing the deck or the island (or
they him), 200 lb. Flight ops had already been shut down prior to his recovery.
Over Bosnia, USN F-18s were originally operating with 5,000 lb. landing reserves,
subsequently cut to 3,500 lb. to increase weapons bringback. Even being really
generous, it's hard to see why an F-35B would need more than 2,000 lb. landing
reserve. Night landings, even Case III, just aren't the same white-knuckle affair
that they are when you have to trap.
comparison.
The F-18E/F supposedly meets the original F-18A spec. The threshold radius for the
F-35B is greater than that.
Aren't they all? But they are paying a lot more attention to cost ceilings on the
program than they've done in the past; that is indeed one of the prime drivers.
We'll just have to see how the performance falls out.
Guy
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
