On Sat, 20 Mar 2004 05:20:01 GMT, Guy Alcala
wrote: Ed Rasimus wrote: You're adding a parameter here, the need to pre-program the missile. That's a step beyond the initial proposition of "look-to-kill" linkage between the helmet field of view and the missile's regard. I've always been a bit cautious, nay even skeptical about marketing brochure claims and operational capability. From an article in the May 22nd, 2000 AvLeak, pg. 28. I forget who's speaking, but IIRR it was an Air Force type, maybe the program manager: "'We are embarking on putting a high off-boresight capability into AMRAAM.'" The keyword here, I think, is "embarking". "Two Phase Program. Initially, only the missile software will be modified, allowing AMRAAM to engage a target throughout the FOV of the fighter's radar, including about 70 degrees off boresight. The current software limits the missile to about 25 degrees off boresight. The enhancement should be available next year [i.e. 2001]. That pretty much describes the state-of-the-art I'm familiar with. Going to 70 degrees off boresight is a lot of angular range, but it still hasn't reached the wing line. "The second phase, still unfunded, would involve upgrading the fighter's software and enable AMRAAM to engage targets behind the shooting a/c. Data on the target would be provided by a second fighter through so-called 'third-party cuing,' [through Link-16],. After launch, updates continue to be relayed through back and sidelobes of the firer's radar. The upgrade follows the ongoing improvement to the missile's warhead, fuse and motor." Here's where things begin to get interesting. First, the data fusion aspect--integrating sensor info from multiple players to provide a full 360 degree field of presentation. Conceptually it's been around for 15 years or more (since my days with ATF at Northrop), but it is elusive. What is problematic is the ability to provide jam-proof links between the players and the desire to keep emissions low in a stealthy environment. Radar is the default primary sensor, but it really lights up the emitter so while one side wants to keep increasing power and scan limits, the other side wants to go LPI and use small, infrequent low-power pinging for data which is then adjusted by trend sensing software to keep the picture current. Compex to say the least. Then, the "updates relayed through back and sidelobes of the firer's radar" is a perfect example of the incompatibility of the two competing concepts. Getting back and sidelobes powerful enough for guidance is in direct conflict with minimizing or eliminating back and sidelobes for stealth. The AGM-78 Standard ARM had the first generation program for launch capability to strike targets behind the launch aircraft. In the Standard's case, I've read Weasel anecdotes which suggest that making a 180 pretty much decreased the remaining energy to zero, the Standard not being the most maneuverable missile on the planet. I've been given some info of the kind of sustained maneuverability the P4 is capable of, and if you'd like I'll be happy to share it with you. Suffice it to say (here), it's far better. The Standard usually didn't turn left or right, but took off and turned upward. Then from high altitude it used the potential energy to maintain manuever on the downward track to the target. That gave it considerable range to the rear, but as I said, very little confirmation of effectiveness other than the occasional signal kill at an approximately correct elapsed time from launch. A lot has to happen in very short time and in a very dynamic scenario. Sure does. And computers just get faster, smaller and cheaper all the time. We appear to be entering the era of missiles like the ones 007 had on his gyro in "You Only Live Twice." Spot on. It is allowing amazing things to happen. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
"Boomer" wrote in message ...
I believe the Super Hornets are getting AIM-9X and the HMCS as we speak. I HAVE seen pics of SH on deck with AIM-9Xs just dont know if that was still in testing or not. -- Go to: http://www.raytheon.com/products/aim9_x/ and click the "play video" link on the right side on the page to see a video of what AIM-9X can do. |
Is replacing Maverick with JCM a good idea? | Scott Ferrin | Military Aviation | 12 | June 16th 04 10:07 PM |
asymetric warfare | phil hunt | Military Aviation | 505 | January 23rd 04 12:31 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
