#31
"old hoodoo" wrote in message
Here in Victoria we had an F-101 that when we got it, we prepared pads and metal supports to secure it and get the tires off the ground. Not a particularly difficult or expensive task. Sir Frances Chichester flew his Gypsy Moth through an typhoon in the orient when he turned up at the wrong hangar to berth it. He reasoned that it was designed to fly at the same airspeeds it was threatened with. What sort of planes do the US consider worth keeping that couldn't do that? -- Posted via Mailgate.ORG Server - http://www.Mailgate.ORG |
#32
orient when he turned up at the wrong hangar to berth it. He reasoned that it was designed to fly at the same airspeeds it was threatened with. The Gypsy Moth "flew" at about 6 knots soaking wet. Nice try. |
#33
![]() "SFbobby" wrote in message ... Sir Frances Chichester flew his Gypsy Moth through an typhoon in the orient when he turned up at the wrong hangar to berth it. He reasoned that it was designed to fly at the same airspeeds it was threatened with. The Gypsy Moth "flew" at about 6 knots soaking wet. Nice try. Sir Frances Chichester was famous for making 2 journeys in a mode of transport called Gypsy Moth The second was the yacht which you seem to be alluding to but the first was the DeHavilland biplane he flew from England to Australia in 1929. Keith |
#34
SFbobby wrote: Sir Frances Chichester flew his Gypsy Moth through an typhoon in the orient when he turned up at the wrong hangar to berth it. He reasoned that it was designed to fly at the same airspeeds it was threatened with. The Gypsy Moth "flew" at about 6 knots soaking wet. Nice try. You might want to consider /why/ Chichester chose the names "Gypsy Moth II", "Gypsy Moth III" and "Gypsy Moth IV" for his yachts, with especial reference to what "Gypsy Moth" might have been to him ![]() http://www.gileschichestermep.org.uk...chester_cv.htm Refers. Specifically: "In 1929 Francis Chichester made the second solo flight to Australia; in 1931, the first solo flight across the Tasman Sea from East to West in his Gypsy Moth aeroplane fitted with floats. Awarded the Johnson Memorial Trophy for his epic flight, he was the first holder of this coveted award. In flying solo from New Zealand to Japan he made the first solo long distance flight in a sea plane. This flight ended in disaster when he collided with an overhead cable and the plane crashed in Katsuura Harbour. He was dreadfully injured but was nursed back to health by a brilliant doctor and kind, sympathetic Japanese nurses." -- Andy Breen ~ Interplanetary Scintillation Research Group http://users.aber.ac.uk/azb/ "Time has stopped, says the Black Lion clock and eternity has begun" (Dylan Thomas) |
#35
Thank you both...I humbly stand corrected. In my ignorance, I knew nothing
about the original Gypsy Moth. Thank you. From: (ANDREW ROBERT BREEN) Date: 9/23/2004 10:55 Eastern Daylight Time Message-id: In article , SFbobby wrote: Sir Frances Chichester flew his Gypsy Moth through an typhoon in the orient when he turned up at the wrong hangar to berth it. He reasoned that it was designed to fly at the same airspeeds it was threatened with. The Gypsy Moth "flew" at about 6 knots soaking wet. Nice try. You might want to consider /why/ Chichester chose the names "Gypsy Moth II", "Gypsy Moth III" and "Gypsy Moth IV" for his yachts, with especial reference to what "Gypsy Moth" might have been to him ![]() |
#36
Hope the SNB-5P made it. It was one of the planes we used for our photo
training hops in the 50s - with Navy and Marine APs as pilots. Frank - 34 yrs USN "Thomas A. Hoffer" wrote in message ... I copied this article segment from a local Pensacola newspaper. Looks the exhibits suffered no damage with minor damage to the building itself. While it mentions some damage to static aircraft displays outside, it sounds like nothing was totally destroyed. I'm curious if the "significant" damage to some planes is fixable. " The National Museum of Naval Aviation was almost unscathed by the storm. Nichols said there were a few leaks in the roof, but the exhibits inside were unharmed. Some of the historic aircraft parked on the tarmac behind the museum were damaged, however. The canopy of an A-6 was sheared off. A couple of wings lay on the pavement and some planes, evidently blown off their moorings, had collided with other aircraft, causing significant damage." |
#37
The "Secret Navy Bomber" (SNB / UC-45J) was still in service with VT-10
during the late 1960s when I was stooging my way through the SNFO pipeline. At VT-10 it was used for low-level day VMC nav training over scenic southern Alabama. -- Mike Kanze "It was like being a rat living under a bowling alley." - Willem Dafoe, commenting on what it was like to sleep in a compartment just below the flight deck of an aircraft carrier. "Frank" wrote in message m... Hope the SNB-5P made it. It was one of the planes we used for our photo training hops in the 50s - with Navy and Marine APs as pilots. Frank - 34 yrs USN "Thomas A. Hoffer" wrote in message ... I copied this article segment from a local Pensacola newspaper. Looks the exhibits suffered no damage with minor damage to the building itself. While it mentions some damage to static aircraft displays outside, it sounds like nothing was totally destroyed. I'm curious if the "significant" damage to some planes is fixable. " The National Museum of Naval Aviation was almost unscathed by the storm. Nichols said there were a few leaks in the roof, but the exhibits inside were unharmed. Some of the historic aircraft parked on the tarmac behind the museum were damaged, however. The canopy of an A-6 was sheared off. A couple of wings lay on the pavement and some planes, evidently blown off their moorings, had collided with other aircraft, causing significant damage." |
#38
I thought it was the "Subsonic Navy Bugsmasher" or Sneeb!
You were doing that while I was scaring cows in South Texas in the Stoof, S-2F (actually TS-2F, all the ASW gear was removed - I assume to protect it from an SNA's smooth landing techniques!) tom USN Ret "Mike Kanze" wrote in message ... The "Secret Navy Bomber" (SNB / UC-45J) was still in service with VT-10 during the late 1960s when I was stooging my way through the SNFO pipeline. At VT-10 it was used for low-level day VMC nav training over scenic southern Alabama. -- Mike Kanze "It was like being a rat living under a bowling alley." - Willem Dafoe, commenting on what it was like to sleep in a compartment just below the flight deck of an aircraft carrier. "Frank" wrote in message m... Hope the SNB-5P made it. It was one of the planes we used for our photo training hops in the 50s - with Navy and Marine APs as pilots. Frank - 34 yrs USN "Thomas A. Hoffer" wrote in message ... I copied this article segment from a local Pensacola newspaper. Looks the exhibits suffered no damage with minor damage to the building itself. While it mentions some damage to static aircraft displays outside, it sounds like nothing was totally destroyed. I'm curious if the "significant" damage to some planes is fixable. " The National Museum of Naval Aviation was almost unscathed by the storm. Nichols said there were a few leaks in the roof, but the exhibits inside were unharmed. Some of the historic aircraft parked on the tarmac behind the museum were damaged, however. The canopy of an A-6 was sheared off. A couple of wings lay on the pavement and some planes, evidently blown off their moorings, had collided with other aircraft, causing significant damage." |
#39
Several TS-2As remain flying today with the California Division of Forestry
(CDF) as retardant bombers. These are being re-engined with turboprops. -- Mike Kanze "It was like being a rat living under a bowling alley." - Willem Dafoe, commenting on what it was like to sleep in a compartment just below the flight deck of an aircraft carrier. "w4okw" wrote in message ... I thought it was the "Subsonic Navy Bugsmasher" or Sneeb! You were doing that while I was scaring cows in South Texas in the Stoof, S-2F (actually TS-2F, all the ASW gear was removed - I assume to protect it from an SNA's smooth landing techniques!) tom USN Ret "Mike Kanze" wrote in message ... The "Secret Navy Bomber" (SNB / UC-45J) was still in service with VT-10 during the late 1960s when I was stooging my way through the SNFO pipeline. At VT-10 it was used for low-level day VMC nav training over scenic southern Alabama. -- Mike Kanze "It was like being a rat living under a bowling alley." - Willem Dafoe, commenting on what it was like to sleep in a compartment just below the flight deck of an aircraft carrier. "Frank" wrote in message m... Hope the SNB-5P made it. It was one of the planes we used for our photo training hops in the 50s - with Navy and Marine APs as pilots. Frank - 34 yrs USN "Thomas A. Hoffer" wrote in message ... I copied this article segment from a local Pensacola newspaper. Looks the exhibits suffered no damage with minor damage to the building itself. While it mentions some damage to static aircraft displays outside, it sounds like nothing was totally destroyed. I'm curious if the "significant" damage to some planes is fixable. " The National Museum of Naval Aviation was almost unscathed by the storm. Nichols said there were a few leaks in the roof, but the exhibits inside were unharmed. Some of the historic aircraft parked on the tarmac behind the museum were damaged, however. The canopy of an A-6 was sheared off. A couple of wings lay on the pavement and some planes, evidently blown off their moorings, had collided with other aircraft, causing significant damage." |
#40
: Several TS-2As remain flying today with the California Division of Forestry (CDF) as retardant bombers. These are being re-engined with turboprops. *Have* been re-engined. I believe the last one got done late last year. |
IVAN--Pensacola NMNA survived (unconfirmed report) | old hoodoo | Military Aviation | 38 | September 26th 04 04:34 PM |
NAS Pensacola vulnerability IVAN | old hoodoo | Military Aviation | 7 | September 24th 04 06:16 PM |
Hurricane Ivan and Pensacola | [email protected] | Naval Aviation | 14 | September 22nd 04 02:07 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
