Are they phasing out the S-3 too?
Old January 29th 05, 02:44 PM
Pechs1
Lana- Which is why CVN's tend to stay in deep water far offshore.
BRBR
A CVN, is far more 'protected' in noisy shallow water than deep water, with
regards to a diesel sitting there, sonar recieve open.
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
Old January 29th 05, 02:46 PM
Pechs1
When the balloon goes up with China, hopefully we will destroy the diesels in
port before they end up in the straights.
If anybody thinks China is our best buddy, needs to get a clue.
P. C. Chisholm
CDR, USN(ret.)
  #29
Old January 29th 05, 11:56 PM
On Sat, 29 Jan 2005 23:47:16 GMT, Guy Alcala
On Sat, 29 Jan 2005 11:57:31 -0500, Andrew C. Toppan
On Sat, 29 Jan 2005 11:47:35 -0500, wrote:
Yup. And they are also slow and working against the clock
Slow is a relative thing; if one doesn't need to go far, speed is not
a problem. Time is not as much an issue as it once was; modern diesel
boats can stay under for quite a long time. This ain't WWII anymore.
Indeed. But once you go to battery you are working against a finite
limit. In WWII that limit may be been in the 24-36 hour range and by
'62 had progressed to the 96 hour range. I have no idea what it is
today. But that finite limit is still there.
For the AIP subs coming into service now, it's a looong time. See
http://www.chinfo.navy.mil/navpalib/...propulsion.htm
OTOH, I don't know how noisy they might be.
And therein lay an interesting question. :-)
I have some suspicians, but don't have any insider info.
If you are running on batteries then you are very quiet if you stay
slow. If you go fast you drain your batteries AND you cavitate.
Cavitation gives the hunder a detection opportunity.
Like I say, non-nuke subs are a real and substantial threat. They
are not, however, an ultimate threat.
Bill Kambic
