Why are there no multi engine ultralight trainers?
I have about twenty hours behind a 912 and two forced landings already. It sure would be nice not depending on a single powerplant. Are two 40 hp engines unable to do the work of a 80hp? |
"jic" wrote in message news:Y4JIb.106419$ss5.61293@clgrps13... Why are there no multi engine ultralight trainers? I have about twenty hours behind a 912 and two forced landings already. It sure would be nice not depending on a single powerplant. Are two 40 hp engines unable to do the work of a 80hp? The question is will the aircraft fly on one 40HP engine when it really requires 80HP. Most ultralights don't have much excess power. The second engine, as they say, takes you to the scene of the crash. |
On 1-Jan-2004, "Ron Natalie" wrote: I have about twenty hours behind a 912 and two forced landings already. It sure would be nice not depending on a single powerplant. Are two 40 hp engines unable to do the work of a 80hp? The question is will the aircraft fly on one 40HP engine when it really requires 80HP. Most ultralights don't have much excess power. The second engine, as they say, takes you to the scene of the crash. This is particularly true if the propellers cannot be feathered. The drag of a windmilling prop driving a dead engine is enough to bring down even high performance twins. -- -Elliott Drucker |
You need to find a good mechanic and a pilot in command, to fly it. Larry |
It's a rental.
"Fitzair4" wrote in message ... I have about twenty hours behind a 912 and two forced landings already. You need to find a good mechanic and a pilot in command, to fly it. Larry |
Why are there no multi engine ultralight trainers? I have about twenty hours behind a 912 and two forced landings already. It sure would be nice not depending on a single powerplant. Are two 40 hp engines unable to do the work of a 80hp? FACT: Most multi engine airplanes lose 70% performance when they lose an engine. Skyking |
"jic" wrote in message news:Y4JIb.106419$ss5.61293@clgrps13... Why are there no multi engine ultralight trainers? I have about twenty hours behind a 912 and two forced landings already. It sure would be nice not depending on a single powerplant. Are two 40 hp engines unable to do the work of a 80hp? Not an ultralight but it does have a pair of engines. http://www.zenithair.com/gemini/index.html |
"Gig Giacona" wrote in message ... Not an ultralight but it does have a pair of engines. http://www.zenithair.com/gemini/index.html Fixed pitch (i.e. not featherable) props. |
Fixed pitch (i.e. not featherable) props. I've always wondered about "cheap" ways to get rid of prop drag on a multiengine plane when one engine goes tits up.... Anybody ever looked at explosive bolts for ditching a draggy prop? take care Blll |
| Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 05:46 AM |
| Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 01:04 PM |
| 1710 allison v-12 engine WWII p 38 engine | Holger Stephan | Home Built | 9 | August 21st 03 09:53 AM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
| Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 09:06 AM |
