Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Need info on aircraft separation
Old December 4th 03, 02:29 AM
Al B
Default Need info on aircraft separation
According to FAA regulations, is there any restriction on the
horizontal separation of aircraft?
I was unable to find anything in the FAA regs:
http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet
Part 91, Section 111 ("Operating near other aircraft") doesn't seem to
answer this. Part 91, Sections 159 and 179 deal with the vertical
flight deck concept based on compass direction, but doesn't indicate
any required horizontal separation.
The real question I'm trying to get an answer to has to do with
whether there is any required horizontal separation of passenger jets
that are flying at different flight decks.
If anyone knows the answer to this, I would really appreciate your
answer. Thanks!
-Al B.
Al B.
"That's jazz. Jazz is weird. Kinda like the same thing that goes on in my head."
- Alex Lifeson's rant during La Villa Strangiato in Rush's "Rock In Rio" concert
Old December 4th 03, 01:04 PM
Robert Moore
jets that are flying at different flight decks.
If adequate vertical separation exists, no lateral separation is
required.
Vertical separation between airliners flying under instrument flight
rules (IFR) is normally 1,000'. The vertical separation of IFR
jetliners and general aviation aircraft flying under visual flight
rules (VFR) is normally 500'.
There is NO separation required for two VFR aircraft except to not
cause a collision hazard.
Bob Moore
ATP CFI
Old December 4th 03, 02:27 PM
Gary Mishler
"Robert Moore" wrote in message
. 7...
Above FL290 vertical sep is 2,000', at least until domestic RVSM is
implemented. But, just as a slight correction, it's not just between
airliners. It's between any traffic (air carrier/gen av/military).
Mish
Old December 4th 03, 02:58 PM
Steven P. McNicoll
"Al B" wrote in message
answer. Thanks!
If you're asking if there is any regulatory separation minima placed upon a
pilot, the answer is no. Separation minima is established for controllers
and it varies with the Class of airspace and the type of operation; IFR,
VFR, or SVFR.
Old December 4th 03, 03:05 PM
Steven P. McNicoll
. 7...
Vertical separation between aircraft flying under IFR is 1000' at and below
FL 290, 2000' above FL 290. It doesn't matter if they're airliners or not.
IFR/VFR vertical separation is 500' in Class B and Class C airspace, it
doesn't matter if they're jetliners or general aviation. There is no
IFR/VFR separation in Class D or Class E airspace.
VFR/VFR separation is required in Class B airspace.
Old December 4th 03, 03:31 PM
Robert Moore
. 7...
flight rules (IFR) is normally 1,000'.
at and below FL 290, 2000' above FL 290. It doesn't matter if
Yes Steven, I took into consideration the knowledge level of the
person requesting the information.
flight rules (VFR) is normally 500'.
airspace, it doesn't matter if they're jetliners or general
aviation. There is no IFR/VFR separation in Class D or Class E
airspace.
not cause a collision hazard.
Yours truly, Bob Moore
Old December 4th 03, 03:52 PM
Steven P. McNicoll
. 7...
By providing inaccurate answers?
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
