Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
SOUNDS OF seaplanes
Old December 19th 03, 07:34 PM
Default SOUNDS OF seaplanes
greetings
i don't know a lot about aviation but sure someone here does
so the question is
why do seaplane motors sound heavier? and more distinctive
than their land based counterparts?
live near water and i can tell by the sound if it has floats or wheels
must be a reason for this
thanks
bill
Old December 29th 03, 12:30 AM
Mike O'Malley
greetings
so the question is
Generally, seaplanes will be fitted with larger diameter propellers than
their land counterparts. This translates to higher prop tip speeds, some
approaching supersonic. Higher speed at the tips relates to more noise.
Mike O'Malley
Old December 29th 03, 04:42 AM
Vern
"Mike O'Malley" wrote in
Mike O'Malley
Is there a trade-off somewhere else in the perfomance envelope that makes
the larger prop less desireable on the land based versions?
Old December 29th 03, 08:24 AM
Scott Skylane
Mike O'Malley
Yes, ground clearance (esp. with deflated nose strut and/or tire).
Old December 30th 03, 06:27 AM
Vern
Scott Skylane wrote in
makes the larger prop less desireable on the land based versions?
Hee hee...why is it always the obvious one's that stump me?!
Old December 30th 03, 02:51 PM
QDurham
Perhaps because this isn't necessarily correct. Prop blade impact with water
is every bit as damaging to the prop as asphalt -- if not worse. I bet
seaplanes sound different from landplanes (if indeed they do) because of the
sound reflectivity of water vs asphalt/concrete/whatever.
Quent
Old December 31st 03, 01:35 AM
Mike O'Malley
"Vern" wrote in message
ble.rogers.com...
This is just an assumption, but my educated guess would be that a larger
diameter propeller will create more static thrust, at the expense of cruise
seed. This is my experience flying a a 150hp Super Cub that went from a
standard 74" climb prop to an 84" seaplane prop (made it easier to hand prop
as well) The sea plane has more drag to overcome because of the floats in
the water versus wheels on the ground. Seaplanes have already sacrificed
speed for utility, what's a little more.
FWIW, some land planes DO have larger seaplane props, mainly aircraft that
need better shortfield performance. Bush planes, and banner tow aircraft
come to mind. Cruise speed is less of an issue, second to short field
performance, or extra thrust. The Super Cub lost about 5 knots off the top
end in cruise, but required 150 rpm less to pull the same banner, and had a
much shorter prop.
Old December 31st 03, 12:42 PM
Vern
larger diameter propeller will create more static thrust, at the
expense of cruise seed. This is my experience flying a a 150hp Super
Cub that went from a standard 74" climb prop to an 84" seaplane prop
(made it easier to hand prop as well) The sea plane has more drag to
overcome because of the floats in the water versus wheels on the
ground. Seaplanes have already sacrificed speed for utility, what's a
little more.
that need better shortfield performance. Bush planes, and banner tow
aircraft come to mind. Cruise speed is less of an issue, second to
short field performance, or extra thrust. The Super Cub lost about 5
knots off the top end in cruise, but required 150 rpm less to pull the
same banner, and had a much shorter prop.
Very good points...thanks for enlightening. I've only ever flown the land
based buggers myself.
Old January 25th 04, 11:20 PM
PJ Hunt
Because 'real' seaplane motors are round.
a beaver pilot.
"Mike O'Malley" wrote in message
Mike O'Malley
Plans for seaplanes David Findlay Home Built 5 January 4th 05 09:49 AM
Question about Seaplanes Sami Aviation Marketplace 11 September 23rd 04 02:04 AM
Air Force Chief Sounds Off as Service Birthday Approaches Otis Willie Military Aviation 0 September 18th 04 03:54 AM
P47 Sounds for combat footage Regnirps Military Aviation 0 April 26th 04 07:04 AM
sounds of aviation navigation equipment as head on a scanner radio Dan Jacobson Instrument Flight Rules 5 December 4th 03 07:27 PM
