#21
Jim Weir writes:
Yeah, but then you've got to find a compliant A&P to sign it off {;-) Hard to come by ![]() BTW, why not post the website of your installation. That has GOT to be the most sanitary ham radio installation I've ever seen ... other than MINE, of course {;-) I suppose: http://www.kjsl.net/~javier/phpix/in...ze=800&start=0 The 2m antenna is the one on top of the tailcone, the 70cm one is on the bottom, photos 9 and 10. -jav |
![]() "Jim Weir" wrote in message ... No doubt about it...even though it is one of ... sniff ... THOSE intercoms {;-) Oh well. I managed to pick up my SPO for $25. The only RST intercom I ever got to use was assembled by a guy who barely knew which end of the iron to hold on to. (His piloting skills weren't much better by the way), so I'll not judge yours by that instance. No, Ron, interfacing it through an intercom or audio panel removes a lot of the folderol with interfacing it directly to the headset. However, you STILL need to know the mic voltage and impedance levels (three different kinds in popular use) for your parTICular ham rig. Yeah, but it's within the realm of tweaking. I can say that I could drive my FT470 directly from the "to the aircraft radio" side of my SPO. Of course, the other quick and dirty is to just use ICOM as their aviation and amateur gear share the same accessories and they've already built a aviation headset converter box. |
If you use your aeronautical-mobile ham radio to order a pizza so that
it's ready for you when you land, is there a geographical limit beyond which it's considered a commercial transaction? Don |
#24
On Mon, 07 Jul 2003 06:36:47 -0700, Jim Weir wrote:
Because there are those of us who see clipping a handheld to a window with a rubber duckie is not the way we want to do things. Why buy a $300 headset and an audio panel to get the best possible audio into your aircraft transceiver if you aren't willing to do the same thing for your ham rig? Lord, no! :-)) I guess you'll have to define "best possible audio" Jim. I want "communications" quality where the band width is tailored to the best for getting information across on both the aircraft and ham rigs. Now and example of what I don't want is something that sounds like one of those expensive Heil mikes used for contesting. The lapel mike has excellent quality along with noise canceling and works great which was a real surprise when I compare it to the prices some of the guys spend on mikes. No, the earpiece doesn't sound like hi-fi, but then again, I can't hear anything above 8K anyway. In the airplane I'm lucky to hear anything above 4K with the extra noise. The ANRs do help out there. I can hear the higher frequency sounds much better while wearing them. To top it off there is no discernable aircraft sound picked up by the mike. It's the little Kenwood combo. I tried the speaker mikes from Yaesu, Icom, and Kenwood, but never found one I liked, or that had half way decent sound. Probably the best sounding one was the Icom compact headset with the boom mike, but then I had to remember to turn off the VOX. I called approach on 146.52 more than once using that setup. What I didn't like was the little head band that went over the top. It really wasn't long enough and even with the big Telex head set on the little one felt like it was falling off. It never did, but it always felt that way. So far I've found the little Kenwood to be easy to use/convenient, comfortable, and sound good, which gives me little incentive to try and wire it in. Now, when I get the G-III together it'll have either a duoband VHF/UHF FM rig, or a VHF/UHF all mode rig in the panel and that will be wired in through the audio panel. Actually, I'd like to put that little Yaesu 100 watt HF/VHF/UHF all mode rig in the G-III...but haven't figured out how to make a trailing wire work in a plastic airplane. I'd also have to wire in an auto retrieve to prevent aerobatics and landing with the thing extended, or I'd probably use it as an arresting hook over the power lines just short of the field. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) It really ain't rocket science, and besides, somewhere I read that "fostering advancement of the state of the radio art" had a place in Part 97. Jim - -They are inexpensive so why bother messing around with a good head set -when you don't have to. - -Roger Halstead (K8RI EN73 & ARRL Life Member) -www.rogerhalstead.com -N833R World's oldest Debonair? (S# CD-2) Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
#25
Aviation radios do NOT have to be TSOed. King even sold a line of non-TSOed
radios. "H. Adam Stevens" wrote in message ... When using a handheld I just connect an ear plug headset and wear it under my normal headset. As far as HF, I worked KJ5CB on 14.347 MHz from my mobile in Austin while he was driving a Boeing over the Amazon. HK3SA was aboard the Amazon Queen on the Amazon River and they even flashed lights at each other. Aeronautical mobiles check into the Maritime Mobile Net on 14.3 MHz frequently. I think the problem is connecting non-TSO'd radios to an aircraft's system, not operating an aircraft HF radio on a ham frequency. H. N502TB, NQ5H "Cy Galley" wrote in message news:PrqNa.105458$R73.12132@sccrnsc04... Why not wire one ear cup for your aviation and the other cup for ham operations? If there are no connections then you should be able to hear both. Use a hand held mic for one or the other. -- Cy Galley - Bellanca Champion Club Newsletter Editor & EAA TC www.bellanca-championclub.com Actively supporting Aeroncas every day Quarterly newsletters on time Reasonable document reprints 1-518-731-6800 "Jim Weir" wrote in message ... There was a question the other day about an amateur radio (or any other two-way radio, for that matter) aboard the airplane. At least for amateur radio (part 97) I got an answer back from an old time FCC person who was in this business for a whole bunch of years. Names are omitted for reasons of privacy. Herewith the exchange...my questions, his answers. 97.101(b) says that an amateur station aboard an aircraft must be "...independent of all other radio equipment...". I've been having some discussions about this, especially my PERSONAL discussion because of what I do for a living (manufacture aircraft electronic devices). My interpretation of RADIO devices means that I can't run my 2-meter ham rig audio through a RADIO (transceiver) or use the RADIO audio to modulate the rig. That is about the extent of the "separation". It's not a real problem for most small aircraft where the aircraft (VHF) radio is AM and the 2 meter rig is FM. Where it becomes a problem is when the a/c is equipped with a HF rig and it gets tuned to the ham bands. More than one ham-licensed air transport pilot has done that and openly bragged that that's what is necessary to relieve the boredom of flying a large plane over the ocean. It does NOT preclude me from using my aircraft headset and microphone, even if that headset and microphone goes through an audio switching device (audio panel) to switch select between the aircraft RADIO and the ham rig. That's how I see it as well. As a matter of fact, it would seem to me dangerous to design a system where I would have to pull the headset plugs out of the aircraft radio and plug them in to the ham rig. This, of course, prevents me from monitoring any of the aircraft radios while using the ham rig. Not good, especially in a crowded environment where monitoring the aircraft radio is an item of safety. Agreed. I guess the question really is where the aircraft RADIO equipment stops and the rest of the aircraft systems start. Battery? Audio? The common sense definition of "the radio" would include the COMM transceiver(s) and any NAVAID devices. Electrical and audio panels should be excluded. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 05 07:29 AM |
What airplane would fill this mission? | John B | Aerobatics | 23 | January 5th 04 09:10 PM |
Marine Radio using Aviation Antennae | Jim Weir | Home Built | 13 | August 12th 03 10:05 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
