Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Are sectional paths correct across "long" distances?
Old March 17th 04, 01:51 PM
vincent p. norris
The rhumbline is a straight line drawn on a chart (or at least that's my
intuitive definition; I'm not sure what the formal definition is).
If I'm not mistaken, a rhumb line is a line that crosses all meridians
at the same angle.
So a rhumb line is not a straight line on a sectional chart, except in
a few special cases (e.g., the equator). Notice that on the chart
Kyler posted, the meridians are closer together at the top of the
chart than at the bottom, so that straight line crosses each meridian
ast a slightly different angle.
Of course, once you get into the whole concept of representing the surface
of a sphere(oid) on a flat piece of paper, and the different chart
projections used to do it, the definition of "a straight line" becomes a
little hard to pin down.
I don't see why. A straight line is one that can be drawn using a
straightedge. As Euclid would say, it's the shortest distance between
to points on the chart. I believe one reason the Lambert chart was
invented was to make it possible to use a straightedge to draw a great
circle route.
vince norris
Old March 17th 04, 01:59 PM
Kyler Laird
"Peter Duniho" writes:
There is absolutely no basis for Center ever asking you to justify your
choice in flight planning.
My use of "explain" was apparently ambiguous. I've not been asked to
justify my route (that I recall), but I have been asked to elaborate on how
I'm going to deal with airspace barriers. I got the feeling that they
wanted more than "I'm going to avoid them."
But frankly, that's just a red herring anyway. There's no way in hell that
any controller would want to know why you flew a sectional straight line
instead of a great-circle route or vice a versa. The difference is just
noise to them.
Again, that's off the subject. I don't know that I'm capable of providing
further clarification on my preference to have all of my maps (and paths)
be aligned.
That's my own laziness though. I'm perfectly happy justifying the use of
Great Circle paths for the tools I build solely because it's The Right
Thing to do.
--kyler
Old March 18th 04, 02:12 AM
Roy Smith
at the same angle.
OK, now you gone and done it. You made me go look it up. Bowditch says:
RHUMB LINE. A line on the surface of the earth making the same oblique
angle with all meridians; a loxodrome or loxodromic curve spirals toward
the poles in a constant true direction. Parallels and meridians, which
also maintain constant true directions, may be considered special cases
of the rhumb line. A rhumb line is a straight line on a Mercator
projection. Sometimes shortened to RHUMB. See also FICTITIOUS RHUMB LINE.
So, yup, you're right.
The last time I remember flying a loxodromic spiral, I was practicing
NDB approaches for my CFI-I ride :-)
Old March 18th 04, 02:58 PM
vincent p. norris
Thanks--and thanks for introducing me to the word "loxodromic," which
I had never heard.
And BTW, I do know how to spell "two."
LOL! I know exactly what you mean!
vince norris
Old March 20th 04, 02:27 PM
Kyler Laird wrote in message ...
Awhile ago I pointed out in rec.aviation.piloting that one of my
tools will generate a map using stitched sectionals for a given
route.
http://groups.google.com/groups?hl=e....edu.au#link10
Ben Jackson mentioned that it didn't look correct to just draw a
straight line between two points so far away (across multiple
sectionals). I have looked into it a few times but I haven't
come up with a definitive answer.
So...anyone know the answer? Pilots are certainly accustomed to
drawing straight lines on a sectional to find the shortest path
between two points, and I've never been taught to do anything
other than align sectionals by sight to plan multi-sectional
flights. Does this not work over long distances?
One path I know fairly well is LAF-MER. The Great Circle path
happens to go right near Denver (where I usually stop). If that
path is plotted as a straight line on the sectionals
https://aviationtoolbox.org/Members/...selected.x=411
it appears to follow the path I'd expect.
https://aviationtoolbox.org/Members/...selected.x=427
Also, there's an easily-identified area on that path where Iowa,
Illinois, and Missouri meet. Take a look at the Great Circle
route.
http://gc.kls2.com/cgi-bin/gcmap?PAT....380N+120.568W
Again, this seems to match the area on the straight-line path
drawn on the sectional.
https://aviationtoolbox.org/members/...selected.y=324
Anyone know for sure whether or not this is an accurate way of
depicting Great Circle paths in the conUS?
Thank you.
--kyler
As a rule of thumb:
Use this equation to draw the bow. It gives the distance offset from
a straight line for the circle route.
A: Lat
A: Longitude
B: Lat
B: Longitude
A and B are the two locations.
C: km of rhumb line.
Nathanial Bowdich has an equation there for this method and is
forgotten, but available from his Navigation Book.
Except his method is to find the equation that fits the geometer's
rhumb line, meaning Bowdich only has a method of navigation and not
the true rhumbline solution.
Making my equation a constant for the earth sphere type, where only
the geometry of all spheres allows the applied line!! That is geometer
talk btw.
C*1.3 seconds= Alat
C*1.3 seconds= Blat
Two simulatanous equations to solve for C, the rhumbline. Longitude is
the reason for the 1.3 seconds of time arc, as a constant.
Meaning just take the time of the trip and lengthen until the A and
the B are equal latitudes!
That is it.
Douglas Eagleson
Gaithersburg, MD USA
Old March 20th 04, 05:04 PM
David Lesher
Roy Smith writes:
The GC route is indeed the shortest distance between two points. Try
plugging 38N/77W to 38N/122W into
http://www.aeroplanner.com/calculators/avcalcrhumb.cfm
to get the rhumbline of 2128 nm, and into
http://www.csgnetwork.com/marinegrcircalc.html
to get the GC of 2099 nm.
And http://gc.kls2.com/ as it makes nice visuals.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old March 23rd 04, 01:43 AM
wrote in message . com...
route.
route.
Thank you.
--kyler
As a rule of thumb:
A: Lat
A: Longitude
B: Lat
B: Longitude
talk btw.
C*1.3 seconds= Alat
C*1.3 seconds= Blat
That is it.
Douglas Eagleson
Aslo note that to solve, the definition of seconds is a distance for
the place. A place on the map selected for the rhumbline. And here,
the 1/2, the distance of the straight route line is the selected
point.
This makes the time to go one half the route a time for the least
pleasent route to navigate. Does a new rhumbline for the half the
original route have to be mathematically converging??? Ha ha!
Never, because another system of equations would be encountered. A
short trip!!
So, the reason for the clarification is to cause the time to equal the
rhumbline. A simple rule of thumb. Time will equal distance
navigationally.
A nonphysics solution because it is caused by the relation of location
to the definer of location, as the time of rotation. The lattitude
and longitude are time locations!
Douglas Eagleson
Gaitherbsurg, MD USA
  #28
Old March 24th 04, 10:51 PM
F1
"Kyler Laird" wrote in message
how
that
noise to them.
be aligned.
Thing to do.
--kyler
When flying VFR, I've been asking about my planned route of flight before.
The controller is just doing his/her job and wants to get the heads up.
  #29
Old March 24th 04, 10:54 PM
F1
"Roy Smith" wrote in message
(Paul Tomblin) wrote:
snip
You've got to go pretty big distances before GC errors start to become
significant. For example, to go from 38N/77W to 38N/122W (roughly
Washington, DC to San Francisco, CA), the rhumbline is 270 and the GC is
284. 14 degrees on a coast to coast trip. If you're flying it nonstop
in a jet, it makes sense to take that into account. For most of us
flying spam cans, we just can't fly long enough legs for it to become
significant.
And it is all moot anyhow, since you'd be IFR and not using VFR charts...
  #30
Old March 25th 04, 12:13 AM
Peter Duniho
"F1" wrote in message
Did the controller ask you to explain why you chose one route versus
another? I doubt they did. That is the issue here, not a controller's
general interest in which way you're going.
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
AVIATIONTOOLBOX: how I convert sectional maps to map chunks Kyler Laird General Aviation 2 December 4th 03 01:09 AM
