Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
"Squawk standby"
Old March 22nd 04, 02:40 PM
Roy Smith
Default "Squawk standby"
I had a wierd thing happen a week or so ago.
We were VFR, and called up POU tower (class D satellite of NY Approach),
10 southwest landing with blah, blah. The tower controller told us to
squawk standby. After confirming that instruction, we did so and a
little while later he told us to squawk vfr.
When we asked what that was all about, he said it was for radar
identification. A little while later, he did the same thing to another
incomming flight.
Any idea what might have been going on? The only thing I can think of
is some sort of equipment malfuction which let him see that there was a
secondary return, but not read the code or see idents. Is that possible?
Old March 22nd 04, 03:58 PM
SD
The Only time I have ever had a controler tell me to squawk standby
was when I was in a flight of 2 bringing a plane back after we had an
engine overhauled. He did not want 2 transponders next to each other
because the computer would go nuts having two so close to each other.
He then communticated with the lead pilot and I was to follow the same
directions.
Scott
incomming flight.
Old March 22nd 04, 06:04 PM
Steven P. McNicoll
"Roy Smith" wrote in message
Approach), 10 southwest landing with blah, blah. The tower
controller told us to squawk standby. After confirming that
instruction, we did so and a little while later he told us to squawk vfr.
incomming flight.
What code were you on when you initially called?
Old March 22nd 04, 08:28 PM
Roy Smith
In article et,
incomming flight.
1200.
Old March 22nd 04, 11:56 PM
Dave Stadt
In article et,
vfr.
another
incomming flight.
a
possible?
1200.
Happens 'round here all the time. He sees a 1200 squawk and thinks it is
you. You go to stand-by and you disappear from radar. He now knows it is
you when you squawk 1200 again. Seems to always happen at Class D airports.
Can they assign unique Xponder codes? Seems to me they can't.
Old March 23rd 04, 12:20 AM
Bob Fry
Why don't they simply ask you to ident? I'm thinking maybe the mode C
wasn't working and they wanted him to recycle is transponder.
"Dave Stadt" writes:
Old March 23rd 04, 02:49 AM
Jürgen Exner
it is you. You go to stand-by and you disappear from radar. He now
knows it is you when you squawk 1200 again.
But isn't that what 'ident' is for?
jue
Old March 23rd 04, 03:44 AM
Steven P. McNicoll
1200.
I suspect he saw multiple targets squawking 1200 in the same general
location. He had you squawk standby to see which one you were. Depending
on the equipment in use and how it's set up, he may or may not see an ident
on a 1200 code.
Old March 23rd 04, 03:46 AM
Steven P. McNicoll
"Bob Fry" wrote in message
Depends on the equipment and how it's set up. He may not be able to see an
ident on a 1200 code.
The Mode C would have no effect on the target itself.
Old March 23rd 04, 05:34 AM
RK
I guess it depends on the ATC equipment. The Class D airport I fly out of (VNY)
can assign unique squawk codes and does all the time when it gets busy.
Ron Kelley
When does IFR begin in VFR? Wizard of Draws Instrument Flight Rules 62 February 13th 05 11:19 PM
Radar contact before squawk David Brooks Instrument Flight Rules 20 March 25th 04 01:34 AM
Non-radar transponder codes Michael Instrument Flight Rules 16 February 13th 04 01:15 PM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
