Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
scanning issue
Old June 26th 04, 10:13 PM
Mark Tomlinson
Default scanning issue
Was just wondering if anyone could provide insight as to why when I
scan the posted Seattle Center ATC approach and departure frequencies
on any of my mobile or base scanners I can only pick up transmissions
from the aircraft and not ATC?
Thanks!
MT
Old June 27th 04, 01:30 AM
Bob Moore
zatatime wrote
Because FM band is a "Line of Sight" communications band.
That's true, but aviation band transmissions are Amplitude
Modulation (AM). Aviation transmissions are line-of-sight
because of the frequency, not the modulation type.
Bob Moore
Old June 27th 04, 03:20 AM
Mark Tomlinson
zatatime wrote in message . ..
If you're close to wherever the ATC facility is (you can see it) you
should get all transmissions.
HTH.
z
Thank you. Found this answer in another group after my posting here.
MT
"United WILL Stand"
Old June 27th 04, 04:32 PM
zatatime
On Sun, 27 Jun 2004 00:30:12 GMT, Bob Moore
Bob Moore
Can you explain? 122.6 (for example) is an FM frequency, how does ATC
transmit on the AM band?
z
Old June 27th 04, 05:24 PM
Stevenatherton
why do you say 122.6 is a fm freq
122.6 is a vhf freqency,it can also be either am or fm modulation , fm or am
means the way the signal is transmitted not the frequency
steve
Old June 27th 04, 05:30 PM
Dave Stadt
"zatatime" wrote in message
Bob Moore
z
Frequency and modulation type are totally unrelated. There is no such thing
as "an FM frequency." VHF aviation transceivers transmit and receive
Amplitude Modulated (AM) signals. VHF communication is typically but not
always line of sight. Signal propagation is frequency dependent not
modulation type dependent (with exceptions here and there).
Old June 28th 04, 02:45 AM
zatatime
On Sun, 27 Jun 2004 16:30:11 GMT, "Dave Stadt"
Bob Moore
z
Thanks. I always thought VORs/Comm were FM and NDBs were AM. Need to
learn more about the VHF band. Appreciate the post, what you say
makes sense (mostly, but because of my need to learn, not because I
think you aren't right).
z
September issue of Airman available Otis Willie Military Aviation 0 September 2nd 04 04:39 AM
Bogus Issue jls Home Built 2 August 15th 04 04:47 AM
October issue of Airman available Otis Willie Military Aviation 0 October 7th 03 10:39 PM
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! Bill Mulcahy General Aviation 3 October 1st 03 05:39 AM
September issue of Afterburner now on line Otis Willie Military Aviation 0 September 9th 03 09:13 PM
