A person told me it is better to push the primer slowly rather
then quick shots. Slower is better on pulling out the primer as this allows the primer cylinder to draw in all the fuel it can take. Pushing the charge in quickly is probably best as the velocity may help in atomizing the fuel ..Another person said I should hesitate before going back to both mags when checking the mags. He says that I should let it run on one mag for 3 or 4 seconds. All I am checking for is the drop. When doing the mag check whichever mag you are on you want to let the RPM fall until it stabilizes. At that point you note the drop. Depending on the engine and magneto this could be anywhere from 50 to 150 RPM. Typically it is 50 RPM and anything over 100 is worth looking into even if you think the engine is running fine and making RPM at power. The point is to let the engine RPM stabilize while running on each mag individually. If you quickly flip from left to right and back to both as soon as you see the RPM decay you might miss something crucial like an entire magneto not even working or a drop of 200 or more in RPM or even fouled spark plugs. John Dupre' |
I have an old tired engine in my plane that requires 7 strokes of prime
no matter what, cold hot or warm. No biggie, as it starts everytime within 3 turns of the prop. I don't have to crank for any period of time. A person told me it is better to push the primer slowly rather then quick shots. Mechanically inclined I am not, but does it make a difference? I have not noticed any difference trying it either way. Mag check. On runup, I check both mags by flipping the switch to mag one and mag two. Another person said I should hesitate before going back to both mags when checking the mags. He says that I should let it run on one mag for 3 or 4 seconds. All I am checking for is the drop. Is there a benefit to letting the engine run on one set of mags for a period of time during the runup? Thanks for any input. Allen |
just noting the "Drop" you'll know the "ground" is working.. not that the
remaining mag can support the engine.. BT "JDupre5762" wrote in message ... A person told me it is better to push the primer slowly rather then quick shots. Slower is better on pulling out the primer as this allows the primer cylinder to draw in all the fuel it can take. Pushing the charge in quickly is probably best as the velocity may help in atomizing the fuel .Another person said I should hesitate before going back to both mags when checking the mags. He says that I should let it run on one mag for 3 or 4 seconds. All I am checking for is the drop. When doing the mag check whichever mag you are on you want to let the RPM fall until it stabilizes. At that point you note the drop. Depending on the engine and magneto this could be anywhere from 50 to 150 RPM. Typically it is 50 RPM and anything over 100 is worth looking into even if you think the engine is running fine and making RPM at power. The point is to let the engine RPM stabilize while running on each mag individually. If you quickly flip from left to right and back to both as soon as you see the RPM decay you might miss something crucial like an entire magneto not even working or a drop of 200 or more in RPM or even fouled spark plugs. John Dupre' |
A Lieberman wrote: A person told me it is better to push the primer slowly rather then quick shots. The primers on the two aircraft I have owned both were slow to fill. If you pulled the primer out rapidly, you wouldn't get much (if any) gas into the primer. Once the primer is full, however, I don't think it makes any difference whether you push it rapidly or slowly. Is there a benefit to letting the engine run on one set of mags for a period of time during the runup? You should let it run on one for a few seconds (I count 4 when I do a runup). This lets you make sure that the drop is not excessive. I switch back to both for a few seconds before changing to the second mag. George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
The priming question has been answered
However on the mag drop---- If there is a bad or fouled plug, you will see a drop as soon as the good mag is switched off. If however there is a timing error which can be caused by the points wearing, or the magneto itself slipping position due to loose hold down nuts---then the drop will be much slower taking several seconds to stabilize. If you switch too quickly during the mag check you might miss this. Cheers: Paul |
clyde woempner wrote:
I would think, the question should be, where do I get an old tired engine rebuilt?? Clyde Clyde, I might be making it sound worse then what it may be. The engine has 2017 hours. (Lycoming 360 180 hp) The compressions are 76/76/76/78 out of 80. I bought the plane in January of this year and at that time the engine had 1940 hours. So, you can see, it has been flown much more in the past 6 months then it has in quite some time. The engine does purr like a kitten, and is easy to start (after figuring out I need to prime it so much). My A&P is saying for now, with the compressions so high, and no metal in the oil, not to fix what is working. He said he has replaced engines with lower compressions then what I have in. Figuring he is the expert, who am I to question. Allen |
G.R. Patterson III wrote:
The primers on the two aircraft I have owned both were slow to fill. I think this is the same experience I am having. In the training airplanes, I "primed" by pushing the throttle in and out. I never had to use the primer knob. In my own plane, when I pull the primer out, I don't feel resistance until the 4th or 5th pull of the primer. After that I feel some resistance. You should let it run on one for a few seconds (I count 4 when I do a runup). This lets you make sure that the drop is not excessive. I switch back to both for a few seconds before changing to the second mag. I did this for the last 3 flights I took, and didn't notice a drop after the 50 rpm drop. Generally, when I do this, and there is carbon on the sparks, I get a dramatic drop. I then go back to both mags, lean it out til the engine runs rough, let it run for 5 to 10 seconds, and that clears up my mag check. The mixture is not like a Cessna where I can "fine tune" it by turning the knob. It is a lever like the throttle where I push it in or pull it out. I will continue to run the mag check as you suggested for 4 seconds. I posted this question as I wanted to be sure I wasn't doing more damage then good by letting it run longer then needed on one mag. Allen |
rebuilt?? Clyde "A Lieberman" wrote in message ... I have an old tired engine in my plane that requires 7 strokes of prime no matter what, cold hot or warm. No biggie, as it starts everytime within 3 turns of the prop. I don't have to crank for any period of time. A person told me it is better to push the primer slowly rather then quick shots. Mechanically inclined I am not, but does it make a difference? I have not noticed any difference trying it either way. Mag check. On runup, I check both mags by flipping the switch to mag one and mag two. Another person said I should hesitate before going back to both mags when checking the mags. He says that I should let it run on one mag for 3 or 4 seconds. All I am checking for is the drop. Is there a benefit to letting the engine run on one set of mags for a period of time during the runup? Thanks for any input. Allen |
"Paul Millner" wrote in message ...
Well, that's really not evident from the data you shared... maybe it was flying 500 hours/year before you bought it? But compressions only tell you about the top of the engine. Is there any valve train wear, are you still getting full horsepower, or have the tappets worn so you're not getting full valve lift? Do you really want to run the engine until the $5,000 crankshaft starts machining its way through the main bearing backing plates, turning it into junk? These are imponderables, perhaps, but saying, "the compressions are good so I'm going to keep on flying" ignores some major factors in economic ownership. Figuring he is the expert, who am I to question. Well, you're paying the bills not him, and it's your butt in the air, not his... and who's pilot in command, anyway? :-) Paul The Type Certificate Data Sheets will give minimum and maximum static full-throttle RPMs for that engine/prop combination in that airplane, and if there is valve train wear the RPM will be out of the range. This isn't rocket science. If the crank is eating its way into something, there'll be metal in the filter. That's simple enough, too. If the oil pressure is well into the green, and doesn't drop to zero at idle when hot, the bearings are OK. If the compressions are as high as he's indicated, there isn't much wrong with the top end of the engine, other than perhaps corroded valve stems. Lycomings have been known to swallow valves when the head broke off the stem because of corrosion pitting in engines that have been run for short periods and left to sit. Similarly, the crankshafts in these engines build up water/oil sludge in the crank nose (unless it's driving a constant-speed prop) and this causes dangerous corrosion that can result in propeller departure. Lycomings run regularly on long flights have reached 4000 hours without overhauls. Tell me what airplane it's in and I'll look up the prop RPM range for you. Dan |
Allen,
I'd recommend contacting a lab that does Oil sample analysis for aircraft engines, and having them run a couple of samples. They should tell you what to do prior to taking your sample for analysis. Like "do a oil change, run the engine for x hours, drain, run x hours, and take sample. Bill Higdon A Lieberman wrote: Dan Thomas wrote: The Type Certificate Data Sheets will give minimum and maximum static full-throttle RPMs for that engine/prop combination in that airplane, and if there is valve train wear the RPM will be out of the range. This isn't rocket science. If the crank is eating its way into something, there'll be metal in the filter. That's simple enough, too. If the oil pressure is well into the green, and doesn't drop to zero at idle when hot, the bearings are OK. If the compressions are as high as he's indicated, there isn't much wrong with the top end of the engine, other than perhaps corroded valve stems. Lycomings have been known to swallow valves when the head broke off the stem because of corrosion pitting in engines that have been run for short periods and left to sit. Similarly, the crankshafts in these engines build up water/oil sludge in the crank nose (unless it's driving a constant-speed prop) and this causes dangerous corrosion that can result in propeller departure. Lycomings run regularly on long flights have reached 4000 hours without overhauls. Tell me what airplane it's in and I'll look up the prop RPM range for you. Thanks for answering Dan, It makes more sense what you say about metal in the oil, as I was going to post how would I know what is happening "below the top" without an overhaul. The engine is in a BE 23 (Beech Sundowner). I bought the plane for $38,000 knowing a major overhaul is in my short future, but wanted to get my learning curve behind me in this engine before overhualing it. Right now, I get the oil changed every 30 hours, and the A&P checks for metal every change. I plan to have the compression checked every other oil change. I fly it a minumum of one hour a week (even if just around the patch) weather permitting. (I have been averaging 6 hours a week). Once I get my instrument rating (I am starting ground school next week), I plan to fly much more a week, as my job takes me throughout the state of MS. Any other tips on maintaining this engine and airplane (or what to look for) is surely appreciated. I have not seen any FAQ's on this subject, and I am learning more from this group and hangar talk. Allen |
