AD on O-235-C2C?
Old July 8th 03, 06:13 AM
BTIZ
maybe he was trying to low ball the value of your airplane..
BT
et...
I was told by an aircraft appraiser that there's an expensive AD on the
108 hp
C2C version of the Lycoming O-235 that comes due at overhaul time. He
didn't
have the AD number or any details, and I haven't been able to find out
much
more. Does anybody know which one he was referring to?
Old July 8th 03, 10:02 AM
I don't think so. It was an airplane I was considering buying, and the
appraiser had no financial interest in the sale.
In article FosOa.69569$1e.28543@fed1read04, "BTIZ"
BT
. net...
108 hp
didn't
much
Old July 8th 03, 06:43 PM
Dennis O'Connor
My mechanic, who can read an AD including preamble and foot notes and
understand it, says he made more than a few bucks from customers who came in
an insisted that he 'do' the AD on the 320 oil pumps even after he advised
them that it did not apply to their engine... Says he told them once, then
if they still insisted that he make some easy money, he shrugged, and did
it...
Denny
m...
wrote in message news:zLvOa.4134$GL4.2199@rwcrnsc53...
Thanks for the reply! I think I had heard of the oil pump AD. Does it
only
apply to certain specific engines or is it an "across the board" AD? Do
you
have any idea how expensive a job it is?
It applies to certain engines (but there are a lot of them) and then even
not all
instances of a given engine are affected. If you can't tell by other
means, you
can pull one of the mags and visually the shaft to determine if you need
to change
things.
Have your A&P carefully read the AD including the PREAMBLE as it appears
to
many that it applies to more situations than it actually does. There as
also
clarifyication sent out that affirms the more narrow application of the
AD.
