I had a stuck valve cause a lot of vibration and power loss once.
Lucky me, I was on the ground when it happened. Thanks for the post. Glad you made it out safe. $3k is painful but you walked away. Eric |
Great post, Allen. Glad everything worked out okay.
Just for the heck of it, I'd file the NASA form. Even though you did absolutely nothing wrong, there is no reason NOT to file one. And, if for some bizarre reason someone got a bean up their butt about something, you'd have your "get-out-of-jail-free-card" in your hip pocket. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" I have not gotten the final cost in yet, since the carberator needs to be ordered and installed, but I think I am looking at close to $3000.00 after all is said and done for parts and labor. I may get a small rebate should the company be able to re-use the cylinder (not likely from the damage I saw). Allen |
Thought I would share my first emergency....
I was flying from MBO (Madison MS) to L31 (Covington LA) to meet my sister for dinner, and get some night time hours on the return trip. I have done this trip many times. Left Madison at 5:00 p.m. with an expected arrival at 6:15. I am starting my IFR training, so figured to really focus on holding altitude and heading working on "precision flying". I was doing great all along the trip, and looking ahead, saw major buildups in my path. Called 122.00 and asked for an inflight advisory. Weather was moving SSW and though close, they said I should make my destination. Little did I know the weather would be the least of my concerns. 15 miles from my destination cruising at 3500, I got a horrible vibration throughout the engine. First thing I did was put the carb heat on. Made the vibration even worse. I held the carb heat for about 10 seconds, and turned it off. Immediately saw a "target farm field" should I need it and never let it leave my sight. Next, switched tanks, no change in vibration. Next fuel pump, no change. Next, checked my mags, left, then right, no change in vibration. Next, turned to 121.5 and said, This is Sundowner 12345L declaring an emergency, anybody monitoring the frequency. As I am doing this, I am setting myself up for the "best glide" speed of 78 knots. Guard responds with Sundowner 12345L, go ahead with your emergency. I replied back, I have an extremely rough running engine, I am 12 miles from destination, I have an alternative field in site should I need it, I will be sqawking 7700. I then turn the transponder to 7700. In this short time, I lost 500 valuable feet altitude. As I reduced my power, and enriched the engine, trying different "power" settings, I noticed the vibration reduced somewhat. I watched my VSI, and noticed that I was able to "maintain" a 200 foot descent. Quick math in my head said, I had "15 minutes" flying time if I left my configuration the way it was, and now I was 10 miles from destination. 121.5 gets New Orleans approach, and New Orleans approach gets on 121.5 and tells me to squawk 4026. I acknowledge New Orleans approach, change my transponder to 4026, and said to New Orleans approach, that I have a stable 200 foot descent rate, engine is running rough, and my intentions is to proceed on to L31. Once I made my decision, I pretty much left what I had going alone. 4 miles out, I said "New Orleans approach, Sundowner 12345L request to change to 122.80. New Orleans approach said frequency change approved, please call FSS to let us know you are safe on the ground. I said Sundowner 12345. will call FSS after touchdown. I set the radio to 122.80, called in Unicom and said, St Tamminy Sundowner 12345L declaring an emergency, inbound for runway 18 straight in approach. In my nervousnous, New Orleans approach says, Sundowner 12345L, you are still transmitting on 121.5. Duh, helps to change the button from Com 1 to Com 2. So, I switch coms, and repeat my broadcast. 2 miles out, see that I am way too high for straight in, I decided instead of a straight in approach, that I would enter on the downwind leg, and proceed to use runway 36 to lose my altitude. I announce on 122.80, Saint Tamminy, Sundowner 12345L declaring emergency, changing intentions, entering downwind for 36. I left my power settings the way I had it, for the first half of downwind, and then abeam the numbers, I reduced the power ever so slowly, and also enriched the mixture ever so slowly. Engine got rougher, but kept running. Trimmed for landing, extended first set of flaps, and the second set of flaps on downwind. I did this so all I had to do was realy concentrate on flying the plane for base and final rather then "finess the plane". Kept my downwind closer to the runway then normal and turn base much sooner then normal. On final, I was 1200 feet above field elevation. On final, I heard that little voice say, better to hit the trees at the end of the runway then the beginning, so I made sure, that I had a higher then normal approach. Seeing I was way high, I put in full right rudder, full left aileron, and pretty much turn the plane perpendicular to the runway. Slip worked great, ears starting popping on descent, and when I cleared the trees, turned forward. Saw I was still too high, returned to the slip, for another 5 to 10 seconds, and then straightened out. Cross the numbers about 25 feet AGL, speed, just above glide speed, cut the throttle to a fast idle. I get major vibration in the engine Started to lower the nose, felt my speed increase, and then raised the nose. Hit ground effect, halfway down the runway, ballooned to about 5 feet above the ground, I raised the nose to bleed off the speed, landed on the last third of the runway. Runway is 2999 feet, so I knew I wasn't stopping at the end of the runway, applied firm brakes, rolled off the runway, with the yoke clear to my chest. I was able to stop about 50 feet after leaving the end of the runway in hard ground with about knee high grass. Engine was really rough, I turn around and limp back to the ramp, airframe and gear fully intact. Go to shut down, and the engine did not want to shut down. It finally shut down. My brother in law was waiting for me at the airport (he is a pilot), we decide to start up the engine to see if he could figure out the problem. Engine was rough on idle, tried to increase RPMs, but the best we could get is 1800, so we shut down. We start calling A&P's around the area, and finally found one that could come out the next day. After describing the symptoms, first thing she thought was a fuel related problem, and asked me the usual questions, did I sump, did I see water, and so on. Nothing in the fuel, I told her runup was absolutely normal. She pokes around the engine, pulling all fuel related hoses, saw lines and screens were clear, so next, she pulled the prop through and found that a cylinder lost all compressions. So, now the obviouse occurred, now to find why.... She pulled the cylinder out, and after opening the cylinder, we saw an unbelievable sight. Piston head had shards of metal pounded in it from the exhuast valve, even more amazing was the cylinder walls were smooth, and rings remained intact! She suspected that most of the exhaust valve was ejected out the exhaust pipe as she found fragments of metal through the exhaust manifold but very little in the intake portion of the engine. Problem "solved" so we thought, replace the cylinder, and off I go. She comes back the next day, installed the cylinder, changed the oil, leak tested the engine and closed the cowling, she wanted to go up with me, as she had never been in a Sundowner. It is dark by this time, and while she was getting her tools together, I preflight. I taxi to the runway, call unicom to advise that I was backtaxing to 36. The runway has a runup area at the very end of the runway, I do the runup, all looks good. I get to the end of 36, and the A&P says, before departing, I need you to do a full throttle test. I hold the brakes, put the throttle full forward, and only get 2200 RPM. POH requires 2700. She says, lean it a tad, see what happens. No change to RPM. Lean it more, EGT and CHT goes up, engine starts running "normal rough". Needless to say, not good. She says taxi back to the ramp. No flying tonight. We taxi back, we pull the cowl. She says, the engine is acting like it is getting too much hot air for the RPMs not to go full throttle, reverifies the duct work, and all looks good. Last thing to look at is the carberator as the engine was purring like a kitten, just could not get 2700 RPM. We called it the night (11:00 p.m.) She said, I had a better chance at winning the lotto then what happened to me. The carberator was the top of the line carberator, and she said in the 19 years she has been an A&P, she has never pulled one from an engine. So, today, she pulls the carberator, and she tears it down. She noticed that the lever to the throttle would not push full forward. It would go it's full range. She felt that due to the severe vibration, something in the carberator shook loose, and is preventing the full extension of the throttle cable. So, now I need a new carberator put in. Seeing the forest through the trees, I figure the outcome was as good as it got, considering the catastropic engine problem I experienced. One thing I cannot thank my instructor enough was to instill the "what if scenarios", as when it really happened, I heard him in my mind say, make a decision, stick to it, but most importantly FLY THE PLANE. The only thing I could not do during this entire episode is to pull the POH for emergency procedures. I found as the real thing happens, you don't have time to pull a book, find the chapter, and go to the list. My first instinct was to do what I could remember (I studied my POH big time when I bought the plane, and refer to it frequently, to be sure I know what to do) and FLY THE PLANE. I have an emergency checklist seperate, but in reality, the time it takes to pull the list, get yourself oriented, you lose very valuable time when you are in the plane by yourself. It may have been different if I had a passenger, but when I was alone, I relied on my memory. (which as it turned out was not so bad *smile*. I could have possibley diverted to another airport in Slidell LA in "gliding range" with a longer runway, but the thunderstorms that I saw were over that airport, so I ruled out trying to make it to that airport. In "hangar" talk, I asked some pilots, should I file an ASR report. It was split down the middle, some said yes, some said no. I am leaning on filing a report. I have not gotten the final cost in yet, since the carberator needs to be ordered and installed, but I think I am looking at close to $3000.00 after all is said and done for parts and labor. I may get a small rebate should the company be able to re-use the cylinder (not likely from the damage I saw). Allen |
There's also the statistical value of a report of a mechanical failure which
did not result in a NTSB reportable incident. "Jay Honeck" wrote in message news:86pSa.102464$N7.12511@sccrnsc03... Great post, Allen. Glad everything worked out okay. Just for the heck of it, I'd file the NASA form. Even though you did absolutely nothing wrong, there is no reason NOT to file one. And, if for some bizarre reason someone got a bean up their butt about something, you'd have your "get-out-of-jail-free-card" in your hip pocket. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" I have not gotten the final cost in yet, since the carberator needs to be ordered and installed, but I think I am looking at close to $3000.00 after all is said and done for parts and labor. I may get a small rebate should the company be able to re-use the cylinder (not likely from the damage I saw). Allen |
A Lieberman wrote: Thought I would share my first emergency.... Great job - sounds like you didn't miss a thing! George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
markjen wrote:
Allen, first off, you did great. I would be pleased if I had done so well. So don't take this as anything but monday-morning quarterbacking. Hi Mark, I appreciate your Monday morning quarterbacking, as I have been doing it myself. I think your story illustrates that you don't want to get so absorbed in a emergency that you end up having an accident for something unrelated to the condition that caused the emergency in the first place (in your case, almost overshooting the runway). You are right, not to get so aborbed in the emergency. When I saw that my initial approach into 18 wasn't going to happen, I broke off the approach and just moved to the downwind side of runway 35, and "flew the plane". The engine at this point had been running rough for 15 minutes, and not knowing if the noise would stop, I figured altitude was my friend. Knowing I was not getting full power, a go around was not an option, so my goal was to make the field. Like you said, the plane belongs to the insurance company should I bend it, and I figured hitting trees at ground speed rather then airspeed in the air would be better for my hide. The general rule-of-thumb in engine-running-poorly scenarios is to assume the insurance company owns the airplane at the first sign of trouble, then fly the airplane using the engine for whatever its got left, to as normal a landing as possible at the nearest airport with plenty of runway and good weather. When I was inbound to Covington, I had three choices for airports, Slidell (kasd), Covington (l31) and Hammond (hdc). When the cylinder ate the exhaust valve, Slidell I ruled out immediately due to the proximaty of the thunderstorm. Fligh****ch had reported thunderstorm in vacinity when I got my inflight briefing 10 minutes before. I could see the rainshaft was about 5 miles to the east of the Covington airport. Hammond is about 23 miles to the west.I considered this airport as I knew it had a much longer runway. I ruled this out, as I did not know "exactly" where the airport was in relation to where I was (I knew to head WSW, but this was not good enough for me), and in my mind, "fly the plane" did not include fiddling with the GPS. In addition, with a 200 foot loss per minute, I wasn't sure if I would had made the airport. Since I had Covington in sight just about 8 miles out, and I had been here many a times, I figured, not to fix what worked in the past. I knew exactly in the terrain where the airport was. It is very likely that your engine would have continued to make reasonable power for many, many minutes after the initial failure, perhaps indefinitely. (There are lots of reports when folks have been over water, had an engine drop an exhaust valve, and then flown for hours.) 20 minutes was long enough for me *smile*. After seeing the damage to the cylinder and piston head, and experiencing the vibration I did, I am amazed the engine ran as long as it did. advice would be to continue to fly the engine at whatever power it took (or would make) to get to the nearest airport with a reasonable runway and good weather. Then fly a normal approach and land, just as you always do. IOW, keep things as normal as possible. The main reason I flew a higher approach was simply I did not know if the noise would stop. When I rewind the events, I would have extended my downwind for about 10 seconds more. I knew I could lose altitude, and had I extended the downwind, and had a longer final, I would have done some shallow S turns to lose altitude. Something I did not consider, was that maybe in downwind, I should have done those shallow S turns to lose some altitude, but in my mind, I was focused on making the field. Once I knew the field was made, I figured, slip it down and work with what I got. Looking back, technically, the only thing I know I did "wrong" was to lower the nose over the runway. I recognized it real quick, but in that short time, I lost valuable runway real estate. If you go to http://www.airnav.com/airport/L31, you can see that off field options were not that many around this airport. I was able to stop and turn around in the grass before the white area on the north end of runway 18. My wheels I believe touched down just north of the "runway 18 aim points". After I get my plane back, what I will do for sure is practice more "power off" short field landings. Allen |
A Lieberman wrote: After I get my plane back, what I will do for sure is practice more "power off" short field landings. I make about 75% of my landings essentially "power off". If I ever have to do it for real, I will have done thousands of them by then. The difference might be the drag caused by a windmilling propeller with an engine making no power at all, or a locked up engine with a stationary prop, versus what happens with the engine at idle. Kinda hard to simulate the first two. MikeM Skylane '1MM Pa22/20 Pacer '00Z |
Hi there,
I have to disagree with the previous post... While I only have 75 hrs, I've been reading as many NTSB reports and rec.aviation.* posts for quite some time. If I were in that situation, I hope I would do as well. The OP said he had to make it 12 miles - this is 6min going 120mph. I'm guessing (total guess) that he was going = 120mph. I must say - 6 min of very rough engine (one cylinder blown) would pretty much freak me out, and I would expect silence at any moment. As for going off the end of the runway - at least in the fun browsing state on eBay (pure fun, I promise!) I'm amazed at how many airplanes have been involved in 'incidents' running off the runway. Usually there is no excuse other than pilot error - and most of the time (reported anyway) it involves significant damage to the nosegear, prop, cowling, possibly engine mount, etc. In this case, there was no damage, and the OP 'pulled the yoke all the way back' for good soft-field technique. The combo of this and low speed is probably what saved the plane from damage. In summary: Allan - you did everything from training, flew all the way to the ground, walked away, and (nice job) didn't break anything in the acft that wasn't already damaged in the engine. Blue Skies, Noah Allen, first off, you did great. I would be pleased if I had done so well. So don't take this as anything but monday-morning quarterbacking. I think your story illustrates that you don't want to get so absorbed in a emergency that you end up having an accident for something unrelated to the condition that caused the emergency in the first place (in your case, almost overshooting the runway). This is very common in twin-engine failure scenarios - the pilot shuts down an engine still making decent power but running poorly, then botches the approach, overshoots the runway, and stalls/spins in the single-engine go-around. The general rule-of-thumb in engine-running-poorly scenarios is to assume the insurance company owns the airplane at the first sign of trouble, then fly the airplane using the engine for whatever its got left, to as normal a landing as possible at the nearest airport with plenty of runway and good weather. It is very likely that your engine would have continued to make reasonable power for many, many minutes after the initial failure, perhaps indefinitely. (There are lots of reports when folks have been over water, had an engine drop an exhaust valve, and then flown for hours.) So my advice would be to continue to fly the engine at whatever power it took (or would make) to get to the nearest airport with a reasonable runway and good weather. Then fly a normal approach and land, just as you always do. IOW, keep things as normal as possible. - Mark |
On 20-Jul-2003, "markjen" wrote: It is very likely that your engine would have continued to make reasonable power for many, many minutes after the initial failure, perhaps indefinitely. (There are lots of reports when folks have been over water, had an engine drop an exhaust valve, and then flown for hours.) So my advice would be to continue to fly the engine at whatever power it took (or would make) to get to the nearest airport with a reasonable runway and good weather. Then fly a normal approach and land, just as you always do. IOW, keep things as normal as possible. I generally agree with your advice, except for your last statement. In the world of "as normal as possible" under VFR, one would typically approach the destination airport at or near pattern altitude in order to blend in with the traffic flow. In Mark's case, he had greatly reduced power, and it is not clear that he could have maintained altitude in a traffic pattern. In my opinion, he handled the landing portion just about right: arrive over the nearest usable airport at as high an altitude as possible. From that point, total power loss -- a very real possibility at any moment when the engine is already running very rough with vibration -- becomes almost a non-event. From that high perch, you can circle the field until you reach an altitude from which a power-off approach is a "sure thing". Use flaps and/or slips (as Mark did) to adjust glide path for a normal speed touchdown maybe 1/3 to 1/2 of the way down the runway. As Mark pointed out, going off the end of the runway at relatively slow speed is vastly preferable to hitting the trees short of the approach end. Any time engine power is questionable in a single, the last thing you want to do is voluntarily give up altitude until the landing is "made". The one exception would be to avoid entering IMC. -Elliott Drucker |
wrote in message ... I had a stuck valve cause a lot of vibration and power loss once. Lucky me, I was on the ground when it happened. Thanks for the post. Glad you made it out safe. $3k is painful but you walked away. That's what happened to me as well. I've still got the piston and cylinder around as a souvenir. Blasted a hole right through the top of the piston. |
| IO 360 Power down (danger, long, rambling post!) | Jim Harper | Home Built | 24 | July 11th 04 01:04 AM |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
| Re; What do you think? | Kelsibutt | Naval Aviation | 0 | September 29th 03 07:55 AM |
| PFC Lynch gets a Bronze Star? | Brian | Military Aviation | 77 | August 2nd 03 12:15 PM |
