landing light replacement for TR182
Old July 20th 03, 06:16 AM
Mark Hudgens
Default landing light replacement for TR182
Has any one changed the landing and taxi lights on the tr182? I have 100w
28 volt lamps on my 82 tr182 and have temp replaced with 250W......any
comments?
Old July 20th 03, 10:51 AM
MikeM
comments?
This will cause the Landing light circuit breker to blow at the most
innoportune time!!!
I had this happen to me on our CAP TR182. I was flying a search dog
team to Escalante, UT at 3:00am. 1L7 has a black hole approach.
(http://www.airnav.com/airport/1L7). The landing lights went off
on short final, and I landed using only the runway edge marker lights.
Come to find out that some idiot had replaced the specified 100W
landing lamp with a 250 Watter.
My recollection (but it has been a few years) is that when the breaker
tripped it took out both the landing light and taxi light...
If you do the math, the current drawn by (250+100)/28 exceeds the 10A
rating of the breaker.
MikeM
Skylane '1mm
Pacer '00z
Old July 21st 03, 12:56 AM
Newps
comments?
Yep, that's a fire waiting to happen.
Old July 21st 03, 02:09 PM
Mark Hudgens wrote:
: Has any one changed the landing and taxi lights on the tr182? I have 100w
: 28 volt lamps on my 82 tr182 and have temp replaced with 250W......any
: comments?
Yeah, don't. It's things like this that the FAA maintenance
regulations were set up for. Put in the right bulb and do yourself (and
plane) a favor.
To use it, you'd need to verify (both through the service manual
and visually to ensure no previous wiring modifications) the wire gauge
through the airframe is adequate for the larger capacity. Then, change
out the breaker for one of adequate capacity. Then, check to make sure
the switch can handle the larger current. Then, verify that with
everything one you don't exceed the 80% capacity of the alternator.
Of course, before you do any of this, you need to do a 337 and get
it approved from your friendly, neighborhood FSDO.
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Landing Light Flasher Circuit ELIPPSE Home Built 1 January 12th 05 06:05 PM
Landing light Hankal Aviation Marketplace 0 July 14th 04 01:23 AM
Would a 3 million Candlepower spotlight make a good landing light? Legrande Harris Home Built 6 June 15th 04 06:32 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
