"Tom" wrote in message ... I cannot seem to control the high CHTs on my 1958 C175 with a Continental GO300 engine. The CHT probes are on the two rear cylinders run about 450F degrees on left and 400F on right on takeoff with 100 mph climb out and 400F left and 375F right at cruise. This differential still looks like a problem with the baffles. It doesn't take much of a hole to really mess up the cooling (been there, done that). But you say you have new cyl's. What's the oil consumption like (and what oil are you using now)? |
GO300 engine. The CHT probes are on the two rear cylinders run about 450F degrees on left and 400F on right on takeoff with 100 mph climb out and 400F left and 375F right at cruise. When I purchased the aircraft it had just had all new cylinders put on but the baffle seals where bad so I put on new baffling seals and installed a Airwolf remote oil filter before I flew it. I now have about 50Hr on the cylinders and 3 oil and filter changes but temps are still high. Does anyone out there have a solution for this problem or know someone I could talk to that knows Continental GO300 engines. |
"Ron Natalie" wrote:
It doesn't take much of a hole to really mess up the cooling (been there, done that). True - I've been dealing with this problem, too. Seemingly insignificant leaks can add up to a big problem. Accept NO leaks of ANY size. -- Dan C172RG at BFM |
| Cessna buyers in So. Cal. beware ! | Bill Berle | Aviation Marketplace | 93 | December 20th 04 03:17 PM |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| Cessna buyers in So. Cal. beware ! | Bill Berle | Home Built | 73 | June 25th 04 05:53 AM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 01:57 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
