![]() "Mike Rapoport" wrote in message k.net... "Dave" wrote in message m... "Bridgadoon" wrote in message ... Lance: straight wing, T-tail, retract, older(78-79) Saratoga: tapered wing, straight tail, retract or fixed, newer(80 onward) A LOT of pilots are against the T-tail for the alleged instability at low speeds, and I think that's the biggest reason for the lower value. It flies and carries roughly the same as the Saratoga, though, so all other things considered about equal, I might have gone with a Lance, until...... Funny that you never hear Gulfstream pilots complaining about the location of the tail on their aircraft, or King Air 200 pilots. Mike MU-2 What is funny about it? |
I flew the DA-20 Katana with a T-tail and it was sweet as could be at speeds
as slow as it could be gotten. I guess "alleged" is the key word. "Mike Rapoport" wrote in message k.net... "Dave" wrote in message m... "Bridgadoon" wrote in message ... Lance: straight wing, T-tail, retract, older(78-79) Saratoga: tapered wing, straight tail, retract or fixed, newer(80 onward) A LOT of pilots are against the T-tail for the alleged instability at low speeds, and I think that's the biggest reason for the lower value. It flies and carries roughly the same as the Saratoga, though, so all other things considered about equal, I might have gone with a Lance, until...... Funny that you never hear Gulfstream pilots complaining about the location of the tail on their aircraft, or King Air 200 pilots. Mike MU-2 |
I haven't flown one but read in the "Aviation Consumer guide" that at slow
speeds with high angle of attacks, the tail does not get enough air because it is in the area behind the main wings. Makes sense to me, but you want to read up on it. Losing elevator control in a slow speed, high angle of attack situation is something I don't want from a plane. And I guess there are a lot pilots who don't like that kind of behavior. If you fly the plane by the numbers it doesn't matter but things happen, and then...??? |
It is funny, or at least interesting, that well trained pilots have no
problem with T-taill airplanes. Since a T-tail Lance will rotate the airplane, even with the cg beyond the forward limit, at a speed below stall, how can anyone say that it lacks "elevator authority" or that the stabilator is too small? I have flown a T-tail Lance with trim only as a training exercise and I have flown without trim when the trim cable failed, neither presented any control problems. Mike MU-2 "Nobody" wrote in message om... "Mike Rapoport" wrote in message k.net... "Dave" wrote in message m... "Bridgadoon" wrote in message ... Lance: straight wing, T-tail, retract, older(78-79) Saratoga: tapered wing, straight tail, retract or fixed, newer(80 onward) A LOT of pilots are against the T-tail for the alleged instability at low speeds, and I think that's the biggest reason for the lower value. It flies and carries roughly the same as the Saratoga, though, so all other things considered about equal, I might have gone with a Lance, until...... Funny that you never hear Gulfstream pilots complaining about the location of the tail on their aircraft, or King Air 200 pilots. Mike MU-2 What is funny about it? |
It loses elevator control in slow flight with high angles of attack, not at
take off. Then the tail comes down and gets no air because it is in the horizontal axis right behind the main wings. That makes the tail less effective, because the airflow it gets is partly deflected by the high angle of attack of the main wing and the airflow does not even reach the tail and is also turbulent. The use of flaps makes this even more pronounced! A straight tail in comparison would be way lower in totally undisturbed airflow and more effective in this kind of flight envelope. This happens when you have to ad power to fly slower, it's called getting behind the power curve. This does NOT happen when you take off. Other airplanes don't have the same problem because of their different geometry. (Longer fuselage and higher or lower t-tail.) It really has nothing to do with 'well trained pilots'. If you were well trained you would know that! Maybe you should find somebody who can draw you a picture. No offense... "Mike Rapoport" wrote in message ink.net... It is funny, or at least interesting, that well trained pilots have no problem with T-taill airplanes. Since a T-tail Lance will rotate the airplane, even with the cg beyond the forward limit, at a speed below stall, how can anyone say that it lacks "elevator authority" or that the stabilator is too small? I have flown a T-tail Lance with trim only as a training exercise and I have flown without trim when the trim cable failed, neither presented any control problems. Mike MU-2 "Nobody" wrote in message om... "Mike Rapoport" wrote in message k.net... "Dave" wrote in message m... "Bridgadoon" wrote in message ... Lance: straight wing, T-tail, retract, older(78-79) Saratoga: tapered wing, straight tail, retract or fixed, newer(80 onward) A LOT of pilots are against the T-tail for the alleged instability at low speeds, and I think that's the biggest reason for the lower value. It flies and carries roughly the same as the Saratoga, though, so all other things considered about equal, I might have gone with a Lance, until...... Funny that you never hear Gulfstream pilots complaining about the location of the tail on their aircraft, or King Air 200 pilots. Mike MU-2 What is funny about it? |
absolute bull****....
"Renzoni Papaloni" wrote in message om... It loses elevator control in slow flight with high angles of attack, not at take off. Obviously, you've never flown one of these things. If your statement were true, it would be impossible to stall the plane. Elevator control is just fine in all phases of slow flight, landing configuration stalls, and accelerated stalls - exactly as required for FAA certification. Also exactly as any pilot is trained when checked out on a new type. Then the tail comes down and gets no air because it is in the horizontal axis right behind the main wings. Now, you're really showing your innocence. The stabilator does *not* hold the back of the airplane up, it holds it *down*. If you really lost elevator control for the reason described, the airplane would pitch down, not up. That makes the tail less effective, because the airflow it gets is partly deflected by the high angle of attack of the main wing and the airflow does not even reach the tail and is also turbulent. The use of flaps makes this even more pronounced! A straight tail in comparison would be way lower in totally undisturbed airflow and more effective in this kind of flight envelope. You better go look at one of these things on the ramp. If you were to get the nose so high, that the T-tail stabilator were totally behind the main wing, you'd have an angle of attack of about 30 to 40 degrees, which is about 3 times greater than the stall. The condition you describe is impossible. You'd be in a spin long before you reached that angle of attack. This happens when you have to ad power to fly slower, it's called getting behind the power curve. This does NOT happen when you take off. I hope you're not an active pilot. Do you really think that getting behind the power curve is limited to the tail design of the plane? You can get behind the power curve in any airplane, especially any piston airplane. You need to get some training on that phase of flight, soon. Other airplanes don't have the same problem because of their different geometry. (Longer fuselage and higher or lower t-tail.) It really has nothing to do with 'well trained pilots'. If you were well trained you would know that! Maybe you should find somebody who can draw you a picture. No offense... Better look at your own picture. With a much longer fuselage, the angle of attack required to get the T-tail down behind the main wing, is reduced. don |
k.net... "Dave" wrote in message m... "Bridgadoon" wrote in message ... Lance: straight wing, T-tail, retract, older(78-79) Saratoga: tapered wing, straight tail, retract or fixed, newer(80 onward) A LOT of pilots are against the T-tail for the alleged instability at low speeds, and I think that's the biggest reason for the lower value. It flies and carries roughly the same as the Saratoga, though, so all other things considered about equal, I might have gone with a Lance, until...... Funny that you never hear Gulfstream pilots complaining about the location of the tail on their aircraft, or King Air 200 pilots. Mike MU-2 I notice, too, that Cessna changed the tail on the CJ/CJ1/CJ2 (early 90's) as well as the Citation X, to a T-tail from the earlier cruciform (and on the earlier 650 series C-III/VI/VII) and left it in place on the Bravo/Encore/Excel. |
Read it the Aviation Consumer Guide you ****ing ignorant know-it-all Car
Salesman. If elevator control is fine, there would be no problem and they would still build it like that, wouldn't they. I haven't seen a Saratoga with a T-tail, have you? If I look at an airplane rotating to climb or take off, the tail comes down and moves in the axis behind the wings. I never said why. I very well know that the tail generates downforce to reach equilibrium - but the issue is the tail moves down relative to the axis to climb. Period. And yes, it does it by generating even more downforce than is needed at level flight. And you don't loose total elevator control, only some authority if you get near the area, if you want the details. And the area is more than 3 ****ing degrees in bumpy air. And the plane should pitch down and it does if you approach the stall slowly. Yes it should (FAA) and does. But if you compensate and hence get into the area of extreme high attack (of the main wings), the elevator moves down even further, into the full airflow BELOW and the plane pitches up violently. Why? Because you compensate for some loss of elevator control and pull real hard. I know you shouldn't do it but people did and didn't like how it felt, ok? Your statement about 30 to 40 degrees would lead to a stall is totally wrong without connecting it to speed. I pull up a Cessna 152 to 90 degrees (vertical) if I have the airspeed and if I am crazy enough. (My instructor did). Before I run out of steam I push and avoid a stall. It's a nice ride but doesn't last long if you want to live. "CarSalesman" wrote in message ... absolute bull****.... "Renzoni Papaloni" wrote in message om... It loses elevator control in slow flight with high angles of attack, not at take off. Obviously, you've never flown one of these things. If your statement were true, it would be impossible to stall the plane. Elevator control is just fine in all phases of slow flight, landing configuration stalls, and accelerated stalls - exactly as required for FAA certification. Also exactly as any pilot is trained when checked out on a new type. Then the tail comes down and gets no air because it is in the horizontal axis right behind the main wings. Now, you're really showing your innocence. The stabilator does *not* hold the back of the airplane up, it holds it *down*. If you really lost elevator control for the reason described, the airplane would pitch down, not up. That makes the tail less effective, because the airflow it gets is partly deflected by the high angle of attack of the main wing and the airflow does not even reach the tail and is also turbulent. The use of flaps makes this even more pronounced! A straight tail in comparison would be way lower in totally undisturbed airflow and more effective in this kind of flight envelope. You better go look at one of these things on the ramp. If you were to get the nose so high, that the T-tail stabilator were totally behind the main wing, you'd have an angle of attack of about 30 to 40 degrees, which is about 3 times greater than the stall. The condition you describe is impossible. You'd be in a spin long before you reached that angle of attack. This happens when you have to ad power to fly slower, it's called getting behind the power curve. This does NOT happen when you take off. I hope you're not an active pilot. Do you really think that getting behind the power curve is limited to the tail design of the plane? You can get behind the power curve in any airplane, especially any piston airplane. You need to get some training on that phase of flight, soon. Other airplanes don't have the same problem because of their different geometry. (Longer fuselage and higher or lower t-tail.) It really has nothing to do with 'well trained pilots'. If you were well trained you would know that! Maybe you should find somebody who can draw you a picture. No offense... Better look at your own picture. With a much longer fuselage, the angle of attack required to get the T-tail down behind the main wing, is reduced. don |
Nobody wrote:
: I haven't flown one but read in the "Aviation Consumer guide" that at slow : speeds with high angle of attacks, the tail does not get enough air because : it is in the area behind the main wings. Makes sense to me, but you want to : read up on it. Losing elevator control in a slow speed, high angle of attack : situation is something I don't want from a plane. And I guess there are a : lot pilots who don't like that kind of behavior. If you fly the plane by the : numbers it doesn't matter but things happen, and then...??? This is called a "deep stall", and only can happen on T-tail aircraft. You might do a Google on "Trident Staines" to find out what happens when it is taken to an extreme. A deep stall is generally considered to be unrecoverable. This phenomenon has been experienced on B-727 airplanes as well. If memory serves, the last occurrence was in New York in 1974 or so (there were mitigtating features, having to do with pitot heat and erroneous airspeed indications). NTSB report AAR-75-13 has more details. I would have a hard time believing that any partially competent pilot in a piston single can get it into a deep stall situation. I haven't flown a T-tail lance, but I have flown a T-tail turbo arrow, and I didn't notice a big deal. Set the trim correctly and it flies off the runway. I didn't notice any untoward stall behavior, either, but I had only 70 hours of flight time at the time (I was considering buying it, but it was out of my price range at the time). -- Aaron Coolidge |
Aaron Coolidge writes:
This is called a "deep stall", and only can happen on T-tail aircraft. Is that the same as a tail stall? Those can happen on a low tail as well, especially if there's icing or if the CG is too far back. Here's a good description: http://www.av8n.com/how/htm/aoastab....ec-too-far-aft All the best, David |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
