Garmin audio panel question
Old September 10th 03, 07:02 PM
Brinks
Default Garmin audio panel question
I've got a friend with a Garmin GMA-340 audio panel with the marker beacons.
It's got a high and low sensitivity switch on it for the marker receiver.
When it's on High Sensitivity, everything works OK. When it's on low
sensitivity, he can only pick up the outer marker. We pulled the antenna
off and cleaned up the connections, but it didn't seem to help. He just got
it back from Garmin, where they replaced a backlight and put in some
updates. Could he be having an antenna problem? Should he replace the
antenna? Any idea? Any help would be appreciated!
Old September 10th 03, 08:41 PM
Marco Leon
If this only started happening after he got it back from Garmin, then I
would call them up to see if they had changed any sensitivity settings.
Why not just keep it at the high sensitivity setting? Are the markers
activating too early?
Marco
"Brinks" wrote in message
beacons.
got
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Question on Garmin GNC 250XL Ron Home Built 1 October 24th 04 08:26 AM
Question for Fellow CFII's regarding Partial Panel Training Brad Z Instrument Flight Rules 16 May 26th 04 11:25 PM
FS KMA20 TSO Audio Panel with Marker Beacon Maik Aviation Marketplace 0 March 18th 04 04:59 PM
FS: KMA20 TSO Audio Panel Maik Aviation Marketplace 0 February 25th 04 07:52 PM
Panel on C-130 vertical stab question B2431 Military Aviation 22 September 27th 03 07:47 PM
