Why does the KDR-510 datalink receiver use two input wires for power and two for ground? The schematic looks like this KDR-510 3A 10-30 VDC---()-------------Power positive 1 \------------Power positive 2 Ground-------------|-------Power ground 1 |-------Power ground 2 Is the power positive 2 and power ground 2 wires just for redundancy? I've never seen any avionics that use two wires both for power and ground. Do both 1 and 2 need to be hooked up or just power and ground 1? |
Chad Lemmen writes:
Why does the KDR-510 datalink receiver use two input wires for power and two for ground? The schematic looks like this KDR-510 3A 10-30 VDC---()-------------Power positive 1 \------------Power positive 2 Ground-------------|-------Power ground 1 |-------Power ground 2 Is the power positive 2 and power ground 2 wires just for redundancy? I've never seen any avionics that use two wires both for power and ground. Do both 1 and 2 need to be hooked up or just power and ground 1? I've seen this used in computer wiring where more power is needed on "one" lead than on the others. This lets them use a smaller connector (with one or two additional pins). Power and ground are the things that's likely to be the issue for with avionics, so maybe that's the purpose? -- David Dyer-Bennet, , www.dd-b.net/dd-b/ RKBA: noguns-nomoney.com www.dd-b.net/carry/ Photos: dd-b.lighthunters.net Snapshots: www.dd-b.net/dd-b/SnapshotAlbum/ Dragaera mailing lists: dragaera.info/ |
Chad Lemmen wrote:
: Why does the KDR-510 datalink receiver use two input wires for power and : two for ground? The schematic looks like this snip : Is the power positive 2 and power ground 2 wires just for redundancy? : I've never seen any avionics that use two wires both for power and ground. : Do both 1 and 2 need to be hooked up or just power and ground 1? Chad, the King equip I have (KX-155, KN-62) also have 2 pins each for power and ground. These pins are connected together internally in both units. They are hooked up using 22ga wire, so I suspect that some limit on current in a 22ga wire is exceeded with a single wire. I would hook up both pins. -- Aaron Coolidge (N9376J) |
I use a rule o'thumb of 5 amps for 22 awg and 7 amps for 20 awg (tefzel or
equiv.) The double power lead method bothers me because if one of the wires broke, the equipment might then try to pull a full load thru a single (undersized) wire...unless there is some special circuitry inside the box that prevents that. Same thing for grounds... "Aaron Coolidge" wrote in message ... Chad Lemmen wrote: : Why does the KDR-510 datalink receiver use two input wires for power and : two for ground? The schematic looks like this snip : Is the power positive 2 and power ground 2 wires just for redundancy? : I've never seen any avionics that use two wires both for power and ground. : Do both 1 and 2 need to be hooked up or just power and ground 1? Chad, the King equip I have (KX-155, KN-62) also have 2 pins each for power and ground. These pins are connected together internally in both units. They are hooked up using 22ga wire, so I suspect that some limit on current in a 22ga wire is exceeded with a single wire. I would hook up both pins. -- Aaron Coolidge (N9376J) |
| Wiring KX 175 TSO | Tore B. | General Aviation | 0 | May 6th 04 11:02 PM |
| King KMA-26 Wiring Diagram | Keith Dobbins | General Aviation | 0 | August 23rd 03 05:03 AM |
| wiring diagram requests | Rick Pellicciotti | Home Built | 2 | August 5th 03 03:39 PM |
| Kawasaki TA-440 2B wiring diagram. | jackthepilot | Home Built | 1 | August 4th 03 07:33 PM |
| Narco AT-50A Wiring Diagram Needed | Jerry | Aviation Marketplace | 0 | August 4th 03 12:07 AM |
