![]() I'm wiring some avionics that use shielded wire that needs to have the shield terminated into a connector. Is it best to solder a wire to the shield or crimp a wire to the shield so that I can put a connector pin on it? |
The best way is to use a solder ferrule with a heat gun. It will connect
the shield to your black 22ga wiring going to the connector pin and also protect the connection from environmental effects. "Chad Lemmen" wrote in message ... I'm wiring some avionics that use shielded wire that needs to have the shield terminated into a connector. Is it best to solder a wire to the shield or crimp a wire to the shield so that I can put a connector pin on it? |
![]() Chad Lemmen wrote: I'm wiring some avionics that use shielded wire that needs to have the shield terminated into a connector. Is it best to solder a wire to the shield or crimp a wire to the shield so that I can put a connector pin on it? According to the "Acceptable Methods" manual (I can never remember the AC number), the disadvatage of a wire solder joint is that it might break due to vibration fatigue, but it is never acceptable to add connectors to extend wire. I would solder the wire to the shield. George Patterson A man who carries a cat by the tail learns something that cannot be learned any other way. Samuel Clemens |
Chad Lemmen wrote:
: I'm wiring some avionics that use shielded wire that needs to have the : shield terminated into a connector. Is it best to solder a wire to the : shield or crimp a wire to the shield so that I can put a connector pin on it? Chad, what I've seen done, and what I did, is: 1) Trim shield, twist, making it about 1/2 inch long. 2) Fold twisted shield back along the multiconductor wire, away from the connector. 3) Solder a short length of 22ga wire to the shield so that it extends in the same direction as the internal wires. 4) Use a piece of heat shrink over the folded back shield, solder joint, and the trimmed multiconductor outer insulation. This worked very well for me, and has been working for years now. PS, remember to connect the shield at ONE END ONLY unless it's being used as a ground (or the directions say to connect both ends). -- Aaron Coolidge (N9376J) |
Soldering is a very bad way to go in high vibration environments. I lost my
alternator due to an improper repair (solder rather than crimped connector). Vibrations eventually broke the strands. Soldered connections are very brittle. "G.R. Patterson III" wrote in message ... Chad Lemmen wrote: I'm wiring some avionics that use shielded wire that needs to have the shield terminated into a connector. Is it best to solder a wire to the shield or crimp a wire to the shield so that I can put a connector pin on it? According to the "Acceptable Methods" manual (I can never remember the AC number), the disadvatage of a wire solder joint is that it might break due to vibration fatigue, but it is never acceptable to add connectors to extend wire. I would solder the wire to the shield. George Patterson A man who carries a cat by the tail learns something that cannot be learned any other way. Samuel Clemens |
I would use crimp as much as possible. As has already been stated,
solder cracks under vibration and will eventually fail. *** Sent via http://www.automationtools.com *** Add a newsgroup interface to your website today. |
