Partnerships (again)
Old September 23rd 03, 01:13 PM
Jim Howell
Default Partnerships (again)
Thanks to everyone for the information, I think I have a basic idea of
how to structure the partnership, but the pont of reserves for the
avionics, and paint/interior. Any ideas on how to calculate those?
Also what about prop overhaul?
Old September 24th 03, 02:21 AM
A good paint job on a typical single will probably run about $6,000 at
today's prices. Interior could be anywhere from a few hundred to a few
thousand depending upon what you replace and what materials you use. The
"need" for new paint, and even much of the wear and tear on the interior, is
related more to calendar time than to hours flown, so If you really want to
establish a reserve fund for paint and/or interior work you should charge
yourselves so much per month based upon how long you think it will be before
the work needs to be done.
For a fixed pitch prop the per hour cost will be pretty minimal. For a
typical constant speed figure a cost of around $1500 to $3000, with 2000
hour TBO. Prop overhaul is often (but not necessarily) done at the same
time as engine overhaul.
Remember that when you acquire the plane it is "as is". If you figure it
has 1000 hrs to go before engine and prop overhaul, and you figure, for
example, that the overhauls will cost a total of $20,000, then you need to
charge yourselves $20/hr for overhaul reserves even though the actual
per-hour cost is only $10/hr assuming 2000 hr TBO.
-Elliott Drucker
Advice on Partnerships Jay Moreland Home Built 1 December 31st 03 12:39 AM
Partnerships Jim Howell Owning 6 September 23rd 03 12:11 AM
