Assuming it's time for overhaul . . .
With a 1967 H-model Skyhawk, does anyone on this NG know what the most powerful replacement/upgrade can be added to this airframe? I have the 145 HP Cont O-300 . . . would LOVE to get to 180 HP . . . can it be done? www.Rosspilot.com |
In article , Rosspilot
wrote: I have the 145 HP Cont O-300 . . . would LOVE to get to 180 HP . . . can it be done? Why would you want to go from a smooth running, fuel sipping six cylinder to a vibrating, fuel gulping four cylinder? |
be done? Why would you want to go from a smooth running, fuel sipping six cylinder to a vibrating, fuel gulping four cylinder? I have a friend with a '74 and the 160 HP ram upgrade . . . his Hawk climbs out so much faster than mine . . . I just thought logically that 25 more HP (180) would really improve performance. Although I love the smoothness of my own engine, I do not notice any "vibration" in his Lycoming, and our fuel burns are similar. www.Rosspilot.com |
look for an STC to upgrade to 180-200HP CSpeed.
There is an old ARMY T-41B (C-172XP) that has a 210HP, (no time limit), high lift leading edge cuffs and stall fences (STOL performance), long range tanks with a pony tank in the aft baggage area. It took a beefier nose strut to support the engine, and larger main wheel tires to match the height of the nose gear... Looks and flies GREAT !!! The civil C-172XPs that came out in the late 80s (??) were 195HP and limited to max power for 5 minutes (initial climb out) BT "Rosspilot" wrote in message ... Assuming it's time for overhaul . . . With a 1967 H-model Skyhawk, does anyone on this NG know what the most powerful replacement/upgrade can be added to this airframe? I have the 145 HP Cont O-300 . . . would LOVE to get to 180 HP . . . can it be done? www.Rosspilot.com |
The air Force had a Bunch of them, Some made it to the CAP AFIK.
Bill Higdon BTIZ wrote: look for an STC to upgrade to 180-200HP CSpeed. There is an old ARMY T-41B (C-172XP) that has a 210HP, (no time limit), high lift leading edge cuffs and stall fences (STOL performance), long range tanks with a pony tank in the aft baggage area. It took a beefier nose strut to support the engine, and larger main wheel tires to match the height of the nose gear... Looks and flies GREAT !!! The civil C-172XPs that came out in the late 80s (??) were 195HP and limited to max power for 5 minutes (initial climb out) BT "Rosspilot" wrote in message ... Assuming it's time for overhaul . . . With a 1967 H-model Skyhawk, does anyone on this NG know what the most powerful replacement/upgrade can be added to this airframe? I have the 145 HP Cont O-300 . . . would LOVE to get to 180 HP . . . can it be done? www.Rosspilot.com |
"Bill Higdon" wrote in message
... The air Force had a Bunch of them, Some made it to the CAP AFIK. Bill Higdon they might have... but most have been replaced with C-182s, fixed gear BT |
Thielert Engine 135HP (diesel)
http://www.dieselair.com/ One option. -- Montblack ("Rosspilot" wrote) Assuming it's time for overhaul . . . With a 1967 H-model Skyhawk, does anyone on this NG know what the most powerful replacement/upgrade can be added to this airframe? I have the 145 HP Cont O-300 . . . would LOVE to get to 180 HP . . . can it be done? |
Yes you can put in a 180 ph engine. I have one in my '65 model and
turning a C/S prop. Check http://www.airplains.com/. The downside with our models is that you cannot get a GW weight increase and we are still limited to 36 gallons of LL. I love my configuration. But, my conversion is a Bush/Doyn and I would not recommend that only because of the owners. I am not sure it is even still available. Contact me if you would like more information. Rosspilot wrote: Assuming it's time for overhaul . . . With a 1967 H-model Skyhawk, does anyone on this NG know what the most powerful replacement/upgrade can be added to this airframe? I have the 145 HP Cont O-300 . . . would LOVE to get to 180 HP . . . can it be done? www.Rosspilot.com |
Ross Richardson wrote in message ...
Yes you can put in a 180 ph engine. I have one in my '65 model and turning a C/S prop. Check http://www.airplains.com/. The downside with our models is that you cannot get a GW weight increase and we are still limited to 36 gallons of LL. I love my configuration. But, my conversion is a Bush/Doyn and I would not recommend that only because of the owners. I am not sure it is even still available. The other downside is the conversion cost. Going from the Continental to the Lycoming requires the replacement of just about everything forward of the firewall, including the nose gear. Converting Lyc. 150/160 hp 172 to 180 hp is a lot easier and less expensive. I had a 145 hp 172 and this was my dream conversion. I needed the extra climb performance in the backcountry. Unfortunately, the price was way out of my ballpark. For the Continental conversions, I've found that it's usually cheaper to buy one that's already been converted. John Galban=====N4BQ (PA28-180) |
Dream Airplane poll | Bob Babcock | Home Built | 39 | December 24th 04 02:20 AM |
Dream Airplane poll | Bob Olds | Home Built | 1 | November 19th 04 04:35 AM |
STRAFING AS IF IN A DREAM | ArtKramr | Military Aviation | 13 | March 3rd 04 12:32 AM |
FS: Upgrade Compaq iPaq H3650 | Juan Jimenez | Aviation Marketplace | 1 | October 3rd 03 09:39 PM |
STRAFING AS IF IN A DREAM | ArtKramr | Military Aviation | 0 | September 2nd 03 04:30 AM |
