How many hours? Copper Cable Kit for '78 Warrior
Old October 6th 03, 08:03 AM
Bud Patterson
"Sandy Mustard" wrote
If your warrior has the braided grounding strap at the battery box, I'd
spring for the Bogert battery box mod also.
It's about $50.
Bogert is faxing the instructions to my A&P for consideration.
Meanwhile, I went flying today. Same old thing, first blade
fails to turn, so I let it back off and bump it again to get it
over the 'hump'. This produces the usual labored rotations,
but then, something new. Electrical power quit, just as if I had
turned off the master switch, in mid start.
Now, I had asked my A&P to check every connection for excessive
voltage drop while cranking, for the purpose of ruling out other
issues than the aluminum cables themselves. He indicated
that the check had been performed by his 'electrical system Guru'
and they had found no excessive delta V while cranking.
Imagine my surprise when I inspect the positive battery terminal
and find that the fastener nut is loose. After tightening, the
starter spins like a top!
We'll see how this holds up over time and hold off on the copper
cable installation.
-Bud
N235PA
San Diego MYF
To reply via email, remove B4FLIGHT
Old October 7th 03, 09:07 PM
Jay Masino
cable installation.
If that terminal has been loose for several flights, it may have been
arcing a bit. You might want take it apart and clean the terminals really
well.
-- Jay
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino/ ! ! !
Checkout http://www.oc-adolfos.com/
for the best Italian food in Ocean City, MD and...
Checkout http://www.brolow.com/ for authentic Blues music on Delmarva
Old October 8th 03, 07:42 AM
Bud Patterson
well.
-- Jay
Good point Jay.
Thanks,
-Bud
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
