Cessna 150 Price Outlook
Old October 10th 03, 01:00 AM
Dan Thomas
David Megginson wrote in message ...
"Steve House" writes:
Unless you're training for the PPL here in Canada, where spins and
recovery are part of the required syllabus at about lesson 11.
Transport Canada removed spin training from the syllabus in the late
1990's (I don't know the exact year). It was not part of my PPL
training in 2002.
As far as I understand (*not* confirmed from an official source),
there were two problems with spin training:
1. The stall/spin accident rate was slightly higher in Canada than the
U.S., despite the fact that all Canadian PPL holders had spin training
and most U.S. PPL holders did not.
2. There were occasional training fatalities during spin training,
including one where the rudder in a 152 jumped its stop and jammed
past full deflection.
Given #1, there was no justification for the deaths in #2 (even if
they were fairly rare).
All the best,
David
The 152 problem was due to maintenance neglect: worn rudder
hinges, bent bellcrank, and so on. An AD has forced replacement of all
rudder stops on 150s to prevent further occurences.
Stall/spin accidents most often occur near the ground, such as in
the circuit, as I understand it, and spin training isn't going to save
you there. There won't be enough altitude for recovery. Learning to
recognize the situations that lead to spins is another thing and
should be taught thoroughly. We teach spins and spin recoveries even
in PPL training, using different real-life scenarios (with lots of
altitude) and lots of wing-drop stall recoveries.
Some guys spin into the ground by being stupid: buzzing a friend
and pulling up sharply and entering an accelerated stall at low
altitude. They weren't paying attention in groundschool, I guess.
Dan
  #73
Old October 10th 03, 01:11 PM
David Megginson wrote:
: In my Warrior, I have yet to see a wing drop in a stall at all. I
: don't want to risk a spin or snap roll by stalling severely
: uncoordinated, but nothing that I am willing to do -- various
: combinations of fast stall, slow stall, power-on, power-off, wings
: level, banked -- will drop a wing or really do anything other than
: make the nose buffet up and down a little.
The Cherokee I fly has more or less the same tendencies, but it's
heavily dependent on the CG. The PA-28's have a very forward CG, which
makes them "auto-recover" so to speak from the stall. A bit of
buffetting, nose drops slightly and breaks the stall. Try it with a more
aft CG (than the usual full tanks and 1 or 2 people up front) and it gets
a bit more aggressive. I wouldn't recommend anything but a simple stall
in that more aft (Still in Normal, but more aft than Utility)
configuration, as spinning could be bad.
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
  #74
Old October 10th 03, 06:13 PM
Andrew Boyd
I trained in 2002 in rental 172's
We didn't do spins at all
About 5 years ago, Transport Canada Aviation removed the
requirement for spins from the Cdn Private licence. Spins
are still required for the Commercial licence in Canada.
Given the definition of "aerobatic maneuvre" in CAR 101.01(1)
a fully-developed spin is pretty clearly an aerobatic maneuver,
and in a perfect world, perhaps fully-developed spins (upright,
inverted, accelerated, flat, etc) would best be taught by aerobatic
instructors in aerobatic aircraft, with the occupants wearing
emergency parachutes. IMHO.
That said, I think every pilot should know how to deal with
a dropping wing, either on departure or turning final, long
before it has a chance to develop into a full spin below 500 AGL.
ATP www.pittspecials.com
  #75
Old October 10th 03, 08:03 PM
Dan Thomas
I trained in 2002 in rental 172's, before buying my Warrior. We
didn't do spins at all (except that my instructor demonstrated one
incipient spin), but we tried hard to get wing-drops on stalls -- I
succeeded well under 50% of the time, even in a power-on, 30-deg-bank
departure stall.
Too much bank. Try ten degrees, and outside wing will drop fairly
promptly, especially if banking right.
Dan
  #76
Old October 11th 03, 08:15 PM
Steve House
Am in temp hiatus in my lessons due to financial shortages but I understood
from my instructor that it was just around the corner, lesson immediately
after stalls. Let's see - lesson 13 in the FTM Aeroplane, 4th edition.
http://www.tc.gc.ca/civilaviation/ge...13747/menu.htm
however it's not in the flight test standards.
Lesson 13 in the online version of the flight training syllabus talks about
incipient spins and recoveries but the downloadable PDF file still calls for
full spin training. Wonder what the real story is.
"David Megginson" wrote in message
training in 2002.
All the best,
David
  #77
Old October 11th 03, 08:46 PM
Ron McKinnon
"Steve House" wrote in message
training in 2002.
understood
about
for
The real story is you still do spin training - you don't have to enter
a full spin - incipient spins and recoveries are sufficient, and
you don't have to demonstrate spins/recoveries on your PPL flight test.
  #78
Old October 14th 03, 03:05 AM
David Megginson
understood from my instructor that it was just around the corner,
lesson immediately after stalls. Let's see - lesson 13 in the FTM
The fourth edition of the FTM was published in 1992, when spin
training was still part of the Canadian test standards (every PPL
candidate had to demonstrate a spin recovery). They have not
published a new edition since then, to my knowledge, but any spinning
your instructor does with you is an optional extra nowadays.
All the best,
David
Floridians Are Hit With Price Gouging X98 Military Aviation 0 August 18th 04 04:07 PM
Cessna buyers in So. Cal. beware ! Bill Berle Home Built 73 June 25th 04 04:53 AM
1977 Cessna 182 Special Price Bill Davidson Aviation Marketplace 0 June 7th 04 11:25 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
