Hi Mr. Borchert:
Hmm. The SUPR light comes on with signals from your own aircraft. Could it be that your DME has contact to a ground station in the PHX area and that's the reason for SUPR? DME and XPDR use similar frequencies, and the DME will trigger the SUPR light. After I posted my reply, I realized I should have anticipated this question. When the ATD came back from the shop, I noticed the SUPR light was on a lot more than it had been. (In the Phoenix area. When out in "no man's land" it only comes on in synch (delayed) with our xponder's REPLY). So I turned off our xponder (and rarely run the DME, but it was off too) and still the SUPR light would light up in the Phoenix area. So it seems the SUPR light is responding to other (strong?) targets in the area. Mike Palmer Excellence in Ergonomics |
![]() "Thierry" wrote in message om... A new higher performance system will be available soon at a nearly same price of the VRX unit which will display simultaneously 3 threat aircraft information including the aircraft SQUWAK. This new device will also integrate an altitude alerter. Intriguing news, but I must be missing something. Why do I care what code my traffic is squawking? It's never mentioned except on initial contract with ATC. |
#24
CriticalMass,
Intriguing news, but I must be missing something. Why do I care what code my traffic is squawking? I'm interested in the group's opinion on this. Also, would you care to look at the display tracking three targets? When three other aircraft are out there, I'd want to be looking outside for them. Oh wait, my RIO can do the tracking ;-) Seriously, though: What do you guys think of these features? -- Thomas |
#25
"CriticalMass" wrote in message ...
"Thierry" wrote in message om... A new higher performance system will be available soon at a nearly same price of the VRX unit which will display simultaneously 3 threat aircraft information including the aircraft SQUWAK. This new device will also integrate an altitude alerter. Intriguing news, but I must be missing something. Why do I care what code my traffic is squawking? It's never mentioned except on initial contract with ATC. Hello, First of all if a traffic is following you, could identify it by its squawk number. If you don't have the SQ displayed you may think this is a new traffic crossing your path. If you have it you could also ask your ATC more info about a specific SQ. This will greatly help the ATC to answer precisely. You could also check if it's a VFR or not (1200, etc). Displaying three threats simultaneoulsy will help you take the proper flight level in order to avoid them all. ie : One threat "A" 200 ft below, one 200 ft above "B". To avoid "A" You climb 200 ft and risk a collision with "B". Our device also distinghish threats squawking mode A only (no altitude reported). Check if the other do the same. Check also our receiver dynamic : 60 db typical compared to 40 db which allow us to offer a maximum range of 10 Nm instead of 5 Nm. This parameter gives you a good indication of the overall quality of our radar receiver. Our typical power consumption is 1 watt compared to 5 to 12 watts for the TS. This is a large difference. Imagine this small box on your dashboard during a sunny day. Internal temperature will quickly exceed the functional limit. This will also impact the reliability of the device. Electronic devices don't heat. Last but not least you get an altitude alerter for free + free lifetime software upgrade thru our web site. I recommend you double check the exact level of performance of the competitive device(s). I was reported a number of inaccuracy concerning their previous generation device. Finally you get all these functionalities for nearly the same price. Rgds, Proxalert |
#26
Hi Mr. Knox:
As for the LSB (least significant bit) that also doesn't quite make sense. First off is the question of whether it even SEES the LSB (I personally do not think that it does). But even if it did, comparing the grey code LSB between your xpndr and a received one tells you nothing (other than your altitudes are not exactly equal). You two could be 100 feet off, right on a transition level for the bit, and the bits would be different. Or (I need to look, but I think the most significant digits are last) you could be 10,000' apart and have the same LSB. I thought about this too (briefly) when Jose' first mentioned it. Assuming he means the LSB in the usual sense, I didn't see how you could garner much info from one bit in a Gray Code. (Gets philosophical with a Gray Code - I suppose one could argue that, by definition, any one bit change in a Gray Code is an "LSB.") When I (briefly) started looking into this two years ago, I visited the Airsport (?) web site (the guy who sells (sold?) the Altitude Nag?). He had some White Papers on xponder stuff. Seems it's not quite so easy to decode Mode C info? From http://www.airsport-corp.com/modec.htm [Each altitude code has an equivalent squawk code. The list of altitude codes shows how that same data would decode as a squawk rather than altitude. But each squawk code does not necessarily have an equivalent altitude. There are 4096 squawk codes but only 1280 altitude codes, one for each 100 foot increment from -1200 to 126,700 ft.] I've never seen the SUPR LED come on by itself. Curious. I *have* seen it go on and off semi-randomly while tracking what is obviously the same signal. Flew to and from Phx Corona Phx, turning off our xponder or Mode C during parts of the flight. SUPR LED still would come on with xponder off (and DME off). Unless Customs has installed a new xponder for us or there's something in the plane creating occasional noise that the ATD picks up (I didn't power down anything else), I assume this is caused by outside aircraft. (Is he rejecting TCAS interrogations?) I can try your test and test my theory by turning off our Mode C and seeing if suddenly I start getting Traffic Alerts on everyone. Let me know. I have NEVER seen ANY difference in terms of traffic alerts regardless of whether my transponder is on or off. I ran Mode A only during various traffic alerts and when the SUPR LED came on by itself. I concur - I cannot tell any difference in ATD operation when I'm running Mode C vs. running Mode A. (Or xpnder off for that matter.) So the plot thickens. Hope this helps, Mike Palmer Excellence in Ergonomics |
#27
(MikeremlaP) wrote in
: Flew to and from Phx Corona Phx, turning off our xponder or Mode C during parts of the flight. SUPR LED still would come on with xponder off (and DME off). Unless Customs has installed a new xponder for us or there's something in the plane creating occasional noise that the ATD picks up (I didn't power down anything else), I assume this is caused by outside aircraft. (Is he rejecting TCAS interrogations?) Check for that free xpndr from the DEA. G TCAS interrogations are not "rejected" - they aren't seen. Same as the FAA ground interrogations... different frequency. Basically the SUPRA light just comes on if it receives a reply that is above a certain very high power level (it then assumes it MUST be from your aircraft). A more common problem is for it to *miss* it (i.e. doesn't quite trigger the SUPRA sometimes) and it thinks that your own response is rather an aircraft VERY CLOSE BY. Lights all the range lights and starts shouting at you. Flying formation with anyone??? G ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
#28
To be up front I got a trafficscope and have been very pleased with
its performance. But your post made some points I felt I wanted to ask or address. "Check also our receiver dynamic : 60 db typical compared to 40 db: This parameter gives you a good indication of the overall quality of our radar receiver." Correct me if I am wrong, but doesn't dynamic ability indicate range of reception, not "quality" of the receiver? example 5NM or 10 NM? I have been a HAM operator for over 6 years and my experience is that S/N ratio is an indicator of "quality" not reception dynamics right? "Our typical power consumption is 1 watt compared to 5 to 12 watts for the TS." I run my trafficscope off of the adapter which uses aircraft power, so why should power consumption be of concern? even 20 watts is minimal power draw on a 14 volt system. Does your unit have a battery compartment or do you have to lug around a battery pack (like some headsets) because frankly battery packs are more clutter. As far as squawk goes most of the aircraft (I would say 90%) that I fly around are on 1200 "VFR" so adding this would not be much of an improvement to advisory conditions. I saw the website, and it shows an altitude of "65" do you have a way of showing how that is relative to my altitude? trafficscope gives me "UP 500 feet" which instantly shows me how far up or below to look, so by giving their actual altitude, wouldn't that leave the mathematics up to the pilot to perform? My last question is what is your company background in producing these types of devices? Is this the first product they will produce? Has it been Beta tested? (Thierry) wrote in message . com... "CriticalMass" wrote in message ... "Thierry" wrote in message om... A new higher performance system will be available soon at a nearly same price of the VRX unit which will display simultaneously 3 threat aircraft information including the aircraft SQUWAK. This new device will also integrate an altitude alerter. Intriguing news, but I must be missing something. Why do I care what code my traffic is squawking? It's never mentioned except on initial contract with ATC. Hello, First of all if a traffic is following you, could identify it by its squawk number. If you don't have the SQ displayed you may think this is a new traffic crossing your path. If you have it you could also ask your ATC more info about a specific SQ. This will greatly help the ATC to answer precisely. You could also check if it's a VFR or not (1200, etc). Displaying three threats simultaneoulsy will help you take the proper flight level in order to avoid them all. ie : One threat "A" 200 ft below, one 200 ft above "B". To avoid "A" You climb 200 ft and risk a collision with "B". Our device also distinghish threats squawking mode A only (no altitude reported). Check if the other do the same. Check also our receiver dynamic : 60 db typical compared to 40 db which allow us to offer a maximum range of 10 Nm instead of 5 Nm. This parameter gives you a good indication of the overall quality of our radar receiver. Our typical power consumption is 1 watt compared to 5 to 12 watts for the TS. This is a large difference. Imagine this small box on your dashboard during a sunny day. Internal temperature will quickly exceed the functional limit. This will also impact the reliability of the device. Electronic devices don't heat. Last but not least you get an altitude alerter for free + free lifetime software upgrade thru our web site. I recommend you double check the exact level of performance of the competitive device(s). I was reported a number of inaccuracy concerning their previous generation device. Finally you get all these functionalities for nearly the same price. Rgds, Proxalert |
#29
Dear Sir,
Dynamic : Dynamic gives a good idea of signal to noise ratio so ability to 1) receive far transmitter or/and 2) have a better signal quality. By the way i'm an HAM for 10 years too. ![]() Power consumption : False : Drawing 1 or 15 watts is very different. Simply because at 15 watts the electronic will get very very hot and minimize life of the electronic components. Both TS and Proxalert have a small package. Battery : I don't understand your concern since your previously said that you operate the unit from the aircraft power !!! Anyway at 15 watts six NiMh AA battery will provide 18 watts so around one hour of autonomy. Our two AA NiMH battery are integrated in the cigar plug cable and will provide more than 2h30 of autonomy. Furthermore these batteries will charge automatically so you are ALWAYS sure that they are fully loaded. Because our batteries are outside the Proxalert total weight is well below other devices. Offering a better behavior during turbulences. Stability is also ensured by our patented fixing pods. Obviously The Proxalert R5 displays altitude in both absolute or relative. Some pilots prefer absolute some other relative. You simply have to set the proper option thru our intuitive menu. By menu you can also set the kind of rank you prefer by altitude or by distance as our device displays up to three threats simultaneously. All options are saved and recovered during the next power on. Concerning squawk i disagree with your statement. As you get controlled the ATC will assign a dedicated squawk to your aircraft. Not to add that you may be in conflict with VFR but also IFR. This is very frequent when flying cross country. Anyway you get all these advantages at nearly the TS price. At Proxalert we only announce products when they are mature so no fear to have. Our in-house Engineering Department is made up of talented engineers coming from the very big name in small and large computers .... Consequently the R5 is designed and manufactured to provide years of excellent services. My turn to ask some questions/remarks : 1) If the TS detects transponders answering mode A only ? Proxalert R5 does it. 2) What is the expected internal temperature when the TS is under a bright sun ? By the way you can actually check the Proxalert R5 internal temperature from the system menu option. 3) Is the TS fully certified as a rack mountable device ? where to get the official form ? 4) Is the TS got FCC Part 15 certificate ? 5) Wake turbulence : It is misleading to say that only big irons are equipped with Mode S transponders. More and more light IFR are also equipped. To my opinion this may lead to false wake turbulence adding stress for nothing. Whatever proximity device you fly i wish you good and safe flights, Regards, Proxalert (BHelman) wrote in message om... To be up front I got a trafficscope and have been very pleased with its performance. But your post made some points I felt I wanted to ask or address. "Check also our receiver dynamic : 60 db typical compared to 40 db: This parameter gives you a good indication of the overall quality of our radar receiver." Correct me if I am wrong, but doesn't dynamic ability indicate range of reception, not "quality" of the receiver? example 5NM or 10 NM? I have been a HAM operator for over 6 years and my experience is that S/N ratio is an indicator of "quality" not reception dynamics right? "Our typical power consumption is 1 watt compared to 5 to 12 watts for the TS." I run my trafficscope off of the adapter which uses aircraft power, so why should power consumption be of concern? even 20 watts is minimal power draw on a 14 volt system. Does your unit have a battery compartment or do you have to lug around a battery pack (like some headsets) because frankly battery packs are more clutter. As far as squawk goes most of the aircraft (I would say 90%) that I fly around are on 1200 "VFR" so adding this would not be much of an improvement to advisory conditions. I saw the website, and it shows an altitude of "65" do you have a way of showing how that is relative to my altitude? trafficscope gives me "UP 500 feet" which instantly shows me how far up or below to look, so by giving their actual altitude, wouldn't that leave the mathematics up to the pilot to perform? My last question is what is your company background in producing these types of devices? Is this the first product they will produce? Has it been Beta tested? (Thierry) wrote in message . com... "CriticalMass" wrote in message ... "Thierry" wrote in message om... A new higher performance system will be available soon at a nearly same price of the VRX unit which will display simultaneously 3 threat aircraft information including the aircraft SQUWAK. This new device will also integrate an altitude alerter. Intriguing news, but I must be missing something. Why do I care what code my traffic is squawking? It's never mentioned except on initial contract with ATC. Hello, First of all if a traffic is following you, could identify it by its squawk number. If you don't have the SQ displayed you may think this is a new traffic crossing your path. If you have it you could also ask your ATC more info about a specific SQ. This will greatly help the ATC to answer precisely. You could also check if it's a VFR or not (1200, etc). Displaying three threats simultaneoulsy will help you take the proper flight level in order to avoid them all. ie : One threat "A" 200 ft below, one 200 ft above "B". To avoid "A" You climb 200 ft and risk a collision with "B". Our device also distinghish threats squawking mode A only (no altitude reported). Check if the other do the same. Check also our receiver dynamic : 60 db typical compared to 40 db which allow us to offer a maximum range of 10 Nm instead of 5 Nm. This parameter gives you a good indication of the overall quality of our radar receiver. Our typical power consumption is 1 watt compared to 5 to 12 watts for the TS. This is a large difference. Imagine this small box on your dashboard during a sunny day. Internal temperature will quickly exceed the functional limit. This will also impact the reliability of the device. Electronic devices don't heat. Last but not least you get an altitude alerter for free + free lifetime software upgrade thru our web site. I recommend you double check the exact level of performance of the competitive device(s). I was reported a number of inaccuracy concerning their previous generation device. Finally you get all these functionalities for nearly the same price. Rgds, Proxalert |
#30
above a certain very high power level (it then assumes it MUST be from your aircraft). A more common problem is for it to *miss* it (i.e. doesn't quite trigger the SUPRA sometimes) and it thinks that your own response is rather an aircraft VERY CLOSE BY. Lights all the range lights and starts shouting at you. Sitting on the ground the other day (engine off, avionics off, just sitting in front of hangar watching planes), I noticed that the SUPR LED comes on even with only one bar on the range gauge lit. Not sure I know what the SURP light means any more when it's not announcing my xponder reply. Thought it meant traffic was being rejected outside the 2500' cylinder, but clearly, something else is going on here. Mike Palmer Excellence in Ergonomics |
Approach Plates on PDA (PIREP) | Stan Prevost | Instrument Flight Rules | 10 | December 18th 04 04:21 AM |
Cessna 182T w. G-1000 pirep | C J Campbell | Instrument Flight Rules | 63 | July 22nd 04 07:06 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) | Kyler Laird | General Aviation | 0 | March 1st 04 12:11 AM |
