Testing your glide. Are people doing this?
Old October 28th 03, 06:19 PM
markjen
They glide better because they have much less drag. They're slick and
don't have
landing gear and other cruft sticking out (and what antennas and stuff
they do have
are much smaller in ratio to the overall area).
I had heard that airliners will generally glide a 3 degree glideslope, clean
and power off. Something that GA airplanes have no hope of doing.
It is a FAST ILS though - less than a minute at 250K.
- Mark
  #32
Old October 28th 03, 06:22 PM
markjen
... as was done on my 4th lesson for my PPL with my instructor.
Not only stopped the engine, but made me slow down to actually stop the
prop.
There is always controversy about how realistic to make emergency training.
I think the risk of doing this training outweighs the benefit.
Engine out and windmilling (low pitch if CS) - yes. Stopping the prop - no.
- Mark
  #33
Old October 28th 03, 06:49 PM
Robert Moore
glideslope, clean and power off. Something that GA airplanes
If we were on the glideslope "way out", and clean power off, our
biggest problem in the B-707 was slowing to the "gear/flap" speed
without using the speedbrakes which shook the Pax too much.
In the 727, because of the T-mounted horizontal stabilizer, we just
yanked the speedbrake.
Bob Moore
  #34
Old October 28th 03, 07:05 PM
Kevin McCue
My instructor was one of them. He did it until the day it became a real
emergency. The FAA's reaction was such that he decided not to do it anymore.
On the other hand, I have gone out to a large mudflat near Tucson in my
Rans and shut it down from 2000' or so and dead sticked it in numerous
times. The flat is about a mile in diameter, Rans uses about 200' to land.
Learned that it glided far better than I was led to believe.
Kevin McCue
KRYN
'47 Luscombe 8E
Rans S-17 (for sale)
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
  #35
Old October 28th 03, 07:13 PM
Robert Moore
stop the prop.
emergency training. I think the risk of doing this training
What experience do you have that indicates that this is a risky
maneuver. I made it a point to do it with every one of my students
at 4-5,000' over the not-too-busy airport. With a few hours of
C-172 gliding time, the worst thing that could happen was to land
like any other glider. My homebuilt MiniMax had a 1/2 VW engine
that could not be restarted in-flight. I regularly practiced landing
with the prop stopped in it. Practice builds confidence!
What do glider pilots do when the prop stops? :-) I certainly don't
concede them any basic skills that I don't possess.
Bob Moore
ATP CFI USN
PanAm (retired)
  #36
Old October 28th 03, 07:21 PM
Jay Honeck
NOT TRUE!! A B-747 has about the same glide ratio as the B-707s
that I flew for 17 years, 20:1 or better. From 35-37,000'(6nm),
we could do 125nm easily.
Wow -- that's really impressive. (Of course, it's what happens at the END
of the glide that's ulimately the most important, eh? :-)
Thanks for the education, Bob!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #37
Old October 28th 03, 09:26 PM
markjen
maneuver.
C'mon, common sense says that stopping the prop on an powered airplane is
maneuver that has some risk. As I said there is a tradeoff. Let's not get
into arguing over the tradeoff or what risk is acceptable. This is just a
rehash of the old spin training debate.
And certainly the airplane and environment matters. There is little risk in
practicing very realistic engine-one scenarios in a low-traffic environment
with a plane like a C-172 or VW-powered homebuilt. But it's a whole
different deal in a Bonanza or T210 at a busy field.
You make your own tradeoff, but if I ever have a CFI that wants to practice
the maneuver to the point of stopping the engine, I'll decline and find
another CFI.
- Mark
  #38
Old October 28th 03, 10:56 PM
Pat Thronson
Wow, sure did not realize this, thanks
Mike and all.
Pat Thronson PP
"Mike Rapoport" wrote in message
ink.net...
"Jay Honeck" wrote in message
newsLunb.50518$HS4.232034@attbi_s01...
A few disparate points to help you understand the situation better:
- Little planes tend to glide a lot better than big planes.
- Where you lose your engine is important. A little plane losing its
engine
over Iowa might make the local newspaper, but everyone will walk away.
The
same engine failure over downtown Chicago is going to make national
news.
- Smoking holes are created when planes glide into something -- hard.
No
matter how well you can glide, sooner or later Mother Earth reaches up
to
smite you. If there is a big building or mountain in the way when you
run
out of glide, well...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Big planes glide much better than small planes. An airliner has about
twice
the glide ration that your Pathfinder does.
Mike
MU-2
  #39
Old October 28th 03, 11:19 PM
In rec.aviation.owning Robert Moore wrote:
: NOT TRUE!! A B-747 has about the same glide ratio as the B-707s
: that I flew for 17 years, 20:1 or better. From 35-37,000'(6nm),
: we could do 125nm easily.
I thought I heard somewhere that one of the reasons the "glide
ratio" on the bigguns is so high is that it's tested with the turbine's
power pulled all the way back. The engines, however, have a great deal of
idle thrust, which aids in the glide ratio.
I don't know this for sure, but I've heard it's partially true.
Any thoughts?
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
  #40
Old October 29th 03, 01:00 AM
Mike Rapoport
No, it is because the airframes are designed for high speed which means low
drag.
Mike
MU-2
Any thoughts?
-Cory
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 10:46 PM
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 09:45 PM
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Naval Aviation 5 August 21st 04 12:50 AM
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Military Aviation 3 August 21st 04 12:40 AM
God Honest Naval Aviation 2 July 24th 03 04:45 AM
