Wing-walk cleaning
Old October 28th 03, 07:16 PM
Mike Noel
Default Wing-walk cleaning
My Cherokee's wing-walk has a few oil stains after coming back from an oil
pump impeller gear replacment session with my mechanic. Regular washing
doesn't touch it. I tried hitting it with Windex and that didn't lift it.
I've currently got some wheat-based kitty litter lying on it and haven't
seen the results yet. Anyone else successfully done this?
Regards,
Mike
Old October 28th 03, 07:28 PM
Jay Honeck
Castrol's "Super Clean" should do the trick. The stuff degreases better
than any other spray-on cleaner I've used.
If the cosmetics aren't the best once you've removed the oil, you may find
it best to simply repaint the wing-walk. A quart of that stuff is pretty
reasonable, and it goes on nicely over your existing wing-walk (as long as
it isn't all chunky from multiple re-applications.)
It really makes everything look "finished" to have that area good and black.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 29th 03, 12:17 AM
But be careful to keep it away from the flap hinges or any other item that
needs to remain lubricated.
-Elliott Drucker
Old October 29th 03, 12:30 AM
Michelle P
Mike,
de-natured alcohol works great for de-greasing. We use it at work for
the Turbo-props and jets. It dissolves just about anything and does not
harm our paint. We buy it by the 55 gallon drum.
Michelle
Regards,
Mike
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Osan’s 51st Fighter Wing to get its own coin Otis Willie Military Aviation 0 April 5th 04 10:44 PM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
