Bonanza Model 35 Landing Gear Question
Old November 8th 03, 03:05 AM
Eric Ulmer
Default Bonanza Model 35 Landing Gear Question
Anyone know if the later model 35 nose gear can be installed on the
earlier model 35 Bonanzas? My B35 nose gear was damaged in a little
MX mishap and I'm in need of a new assembly including the casting.
The availability of the older style is pretty scarce and I've seen
at least one bonanza C35 with the heavier nose gear before but not
sure if it was legal or not..
--Eric
Old November 8th 03, 02:58 PM
JDupre5762
I am not sure but have you researched for superseding part numbers? It may be
that with the original unavailable Beech allows the later style to be fitted as
a replacement. If you are not a member join the American Bonanza Society. If
anyone would know they would.
John Dupre'
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
WTB: Nose Gear Assembly for Early Model Bonanza Eric Ulmer Aviation Marketplace 4 November 16th 03 11:50 PM
