KX-155 LEDs
Old November 20th 03, 01:50 AM
John Purner
Aaron,
Thanks so much for the very detailed explanation. I will be at the 'port
tomorrow to try this on one of my KX-155. I really am grateful!
Send your snail mail address to me and I'll send along a copy of The $100
Hamburger or a t-shirt you pick!
John Purner
Editor - The $100 Hamburger
http://www.100dollarhamburger.com
"Aaron Coolidge" wrote in message
John Purner wrote:
: Aaron,
: I hate to press to much but I really need the help. How exactly do you
: remove the displays?
: Thanks very, very much
John, this is for the King Crown equipment (KX155, KN62, etc).
Take radio out of plane. Remove front bezel, there are small philips
screws on the sides or top & botton of the radio. You don't need to remove
the knobs and switches (in fact, you can't until you've removed the
bezel).
Now, you'll be looking at the display. It's the very fragile, very
expensive
glass thingy. On the bottom, you'll see a row of 20 to 60 bent silver
metal
fingers - these are the radio side of the contacts. The display contacts
are the dull silver squares that these bright metal fingers are touching.
To remove the display, carefully slide it away from the fingers. This is
hard to explain without graphics, but the display will slide a small
distance
directly away from the fingers (toward the top, on a KX-155), and then
the bottom (again on a KX-155) will pivot slightly inward and the top
slightly outward. This pivoting will allow you to take the display out
of the radio, moving it up and away from the radio.
There is a little stub on the back of the display; this is how Dale fills
them with neon. The stub is exceptionally fragile! The rest of the display
is pretty solid, though.
Now, you'll see those 20-60 silver-plated fingers on the bottom edge of
display. You can "burnish" them to remove the tarnish with a business
card,
a pencil eraser, or whatever your favorite burnisher is. Be careful, the
silver isn't very thick! NEVER use abrasives of any sort (well, a pencil
eraser is technically an abrasive, but it's very fine). Try not to touch
these silver-plated contacts as your finger oils & acids will tarnish
them again. Do a final cleaning with alcohol.
Now is the time to put a bead of dielectric grease on top of those silver
square contacts. If you don't have dielectric grease, you may be able
to get it at Radio Shack, a good auto parts store, or a boating store.
Don't use "white lube", it's lithium based and conductive. Don't use
"heat sink grease", or anything but silicon-based dielectric grease!
To put the display back in, reverse the process. Drop it into the plastic
carrier with the bottom angled in and the top angled out. Push the top
down
while guiding the bottom into contact with those shiny metal fingers. You
can push the left a little, then the right a little, back & forth. Soon,
display will pop back into place. You'll have a big glop of dielectric
grease on your dining room table, and on the front of the display.
Make sure that the display contacts and the radio shiny fingers are
properly
aligned, and not touching 2 contacts, etc.
Clean the display face with alcohol (rubbing, not bourbon). Takes off
the fingerprints, too!
Put the front bezel back on, and the radio back in the plane. Presto!
No more funky digits! (Probably.)
What if this doesn't work? Then, the display itself is probably no good.
The neon gradually leaks out, and the display gets dimmer and dimmer.
When it's cold, the display is dimmer yet. If this describes the problem
you're having, you need a new display, which will cost around $200.
Good luck! (PS, to email, remove 'spam' and 'off')
Aaron Coolidge (N9376J)
Old July 11th 13, 09:04 AM
EdwardRuiz EdwardRuiz is offline
Junior Member
First recorded activity by AviationBanter: Jul 2013
Quote:
Originally Posted by John Purner View Post
Aaron,
John Purner
John Purner
: Aaron,
bezel).
expensive
metal
To remove the
led lighting display, carefully slide it away from the fingers. This is
distance
card,
down
properly
it was indeed awesome information.. Just looking to capitalise on it now.. Thanks again for sharing it..
More LED's Veeduber Home Built 19 June 9th 04 10:07 PM
LED tail strobe Jeff Peterson Home Built 41 May 15th 04 03:13 PM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
LEDs with Strobe lights pekka1510 Home Built 11 August 31st 03 11:36 PM
LEDs Morgans Home Built 6 August 19th 03 03:49 AM
