#21
Yes, but in this instance he needed a DG to drive the autopilot for
flying desired or assigned course headings. On Sun, 30 Nov 2003 16:35:46 GMT, Kevin wrote: Jay Honeck wrote: WOW, sure is! Isn't the new STec DG around $2300? Yeah, for some reason electric DGs are outrageously more expensive than vacuum ones. Anyone know why? Probally a dumb question, but I have to ask. would a GPS not be more accurate than a DG ? |
"Jay Honeck" wrote in message news:%Hpyb.172161$Dw6.663993@attbi_s02...
Probally a dumb question, but I have to ask. would a GPS not be more accurate than a DG ? Yes, but many autopilots are "slaved" to a "heading bug" on your DG. This set-up pre-dates GPS by decades, and is much cheaper than the (seemingly simpler) GPS-autopilot connection. Again, there is no logic to this -- but what else is new? A DG gives heading, a GPS gives track. Two very different things. Dan |
"G.R. Patterson III" wrote in message ...
David Lesher wrote: Does garbage really migrate upstream into the expensive toys? If a dry pump fails, the carbon vanes may turn into powder. When this happens, the pressure on the instrument side is lower than atmospheric pressure, and you may wind up with some of this powder being blown back into the instruments. In normal use, however, garbage does not migrate back upstream. (And if so, you'd thunk someone would add a inline filter between the toy and the common vacuum line..) Some people do this as a preventative measure. Alternatives include prophylactic replacement of the dry pump to attempt to ensure it never fails, using a wet pump, and cleaning the instruments before using them after a pump fails. The filter is cheap insurance. George Patterson A failed vac pump isn't likely to send garbage back up the line. The instruments represent a significant vacuum leak, and the pressure will drop off almost instantaneously when the pump fails. The filters between the gyros and pump are more likely to keep garbage from a failed instrument from gettingn into the pump, failing it as well. Dan |
#24
"Jay Honeck" wrote in message news:E7nyb.369913$Fm2.367716@attbi_s04...
WOW, sure is! Isn't the new STec DG around $2300? Yeah, for some reason electric DGs are outrageously more expensive than vacuum ones. Anyone know why? So few made. Most general aviation aircraft use vacuum or air-driven attitude and heading indicators, and an electric turn coordinator to provide some redundancy if the vacuum fails. Electric DGs and horizons would be used as backups in much larger airplanes, like the small electric attitude indicators in the centre of most airliner panels. Dan |
#25
"Jay Honeck" wrote in message news:fXJxb.334160$HS4.2853565@attbi_s01...
A friend of mine says that the gyros inside ride on some sort of a "ruby bearing" -- and that they eventually wear out. Sometimes the rotor (or whatever) even falls right off the bearing. When that happens, everything just stops -- like mine did. Or something like that. Either way, it's just more money... Little wee tiny ball bearings. The lube dries out from all the air going through the instrument, cold weather hardens it, airborne pollutants get through old/cracked/nonexistent filters (cigarette smoke is a bad one) and bearings can't take it anymore. Dan |
#26
"Mike Rapoport" wrote in message hlink.net...
How old were your gyros? At 10,000 rpm (just a guess) a gyro revolves 600,000,000 times in 1000hrs. Mike MU-2 I think it's a lot higher than that, maybe as much as two or three or four times. Plenty, anyway. Dan |
#27
A DG gives heading, a GPS gives track. Two very different things. True. However, the illogic I was referring to is the incredible difference in price between an autopilot that is slaved to a DG, versus an autopilot that is connected to a GPS. The former is MUCH more difficult to achieve than the latter, yet the GPS connection is much more expensive to buy. This is due to demand, I suppose? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#28
#29
Jay Honeck wrote:
Again, there is no logic to this -- but what else is new? snip Jay, I joined this thread a bit late...after my local server flushed the original message, but I believe your original question was "what could cause premature gyro failure"? In my experience, two things: 1) If it fails within a few hours of being new, that's typically because of manufacturing, long-term storage, or shipping damage -- all of which can cause the bearings to "flat spot". Apparently the bearings are *that* soft. 2) If it fails after a few hundred (as opposed to a few thousand) hours, improper mounting or excessive vibration is usually the culprit. The problem is most severe in aircraft whose panels aren't shock mounted AND when those same aircraft don't have their props properly (dynamically) balanced. Our gyros were so damn expensive that when we had our panel apart last time I had the shop replace the mounts. Not only does the panel NOT sag like it used to, but as we encounter various (normal) harmonics in our particular engine/prop combination, the shock-mounted instruments simply don't shake like some of the other fixed mounted units (fuel gauges, etc). I forget if your airplane has a fixed or shock-mounted panel, but if it's shock mounted, I'd recommend replacing the shock mounts and getting the prop redressed / painted, then dynamically balanced for good measure. HTH, -Doug -- -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
#30
"Jay Honeck" writes:
Yeah, for some reason electric DGs are outrageously more expensive than vacuum ones. Anyone know why? They ARE direct drive, are they not? My guess is as follows. The air/vacuum motor is trivial; a series of vanes and a jet tube from the intake filter. Easy to make go fast. But a tiny DC motor is difficult; the rotor windings will want to fling themselves out at high speeds. The brushes and commutator will be near watchmaker-skill level. A new design would have a AC inductor motor with a squirrel-cage motor, and a small internal inverter. But does anyone make them like that? -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
