Autopilot Question
Old December 3rd 03, 11:37 PM
Jay Honeck
Default Autopilot Question
We have the Piper Autocontrol IIIB in our '74 Pathfinder. It has worked
fairly well since Day One, failing only when our vacuum instruments each
went Tango Uniform, in the space of six weeks.
However, the "heading bug" on our DG has always off by about 10 degrees. If
we wanted to fly 180 degrees, we had to set the bug to 170 on the DG. This
was mildly annoying, but easy to work around.
When the DG died, and we got our newly rebuilt unit (from the Gyro House), I
was expecting the heading bug to be PERFECT. Well, imagine my surprise when
the NEW heading bug is ALSO off -- by exactly the same amount! We *still*
have to set the bug on 170 to fly 180!
It's apparent that there is some other adjustment out of whack. But what?
Even my A&P (who admits he's no autopilot expert) was completely surprised
that our new DG didn't fix the problem.
What the heck is up? What needs to be adjusted, if not the DG?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 4th 03, 01:09 AM
Aaron Coolidge
Jay Honeck wrote:
: However, the "heading bug" on our DG has always off by about 10 degrees. If
: we wanted to fly 180 degrees, we had to set the bug to 170 on the DG. This
: was mildly annoying, but easy to work around.
Jay, did you try asking the folks at Autopilots Central? There are numerous
adjustments on the Autocontrol autopilot, some on the autopilot unit with
the on/off switch, and some on the input selector (Nav/Loc/BC/Hdg switch).
Aaron Coolidge (N9376J)
Old December 4th 03, 01:44 AM
JimC
Jay,
You can adjust the bug centering. I posted a note several months back
(maybe more than a year) regarding the Autocontrol IIIB and its various
adjustments. Do a search on "Autopilot Oscillation Fixed" and you'll find
the whole posting. I've attached part of the post below covering the
location of the bug centering adjustment potentiometer.
JimC
start
Making the Adjustments:
The adjustments required access to 4 potentiometers located on the
front of the autopilot, behind the faceplate. Removal of the
faceplate required two tools. One Allan wrench to first remove the
roll knob, and a small screwdriver for the faceplate screws. The roll
knob screw is on the bottom of the knob, and the two faceplate screws
are visible after the roll knob is off.
The potentiometers are quite small, arranged horizontally, and are
found directly under the right rocker switch. These pots will not be
visible if you are of normal height and are sitting up in the pilot
seat. A small jeweler-type flat screwdriver is required to adjust
these pots. The pots are 20 turns for full range.
From left to right, the potentiometers adjust the following functions:
gain/threshold, left roll, heading bug centering, right roll.
end
"Jay Honeck" wrote in message
news:dtuzb.213271$Dw6.776220@attbi_s02...
If
This
I
when
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 4th 03, 02:33 AM
John Clonts
Great post JimC-- do you know where I could get the same information about
my Century 2000?
Thanks!
John Clonts
Temple, Texas
N7NZ
"JimC" wrote in message
Jay,
JimC
start
end
If
This
House),
I
when
*still*
what?
surprised
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 4th 03, 02:47 AM
Tom Jackson
Jim,
Sounds like you know a thing or two about autopilots.
I have a '74 Warrior, with an Autocontrol IIIB. I find the unit to be
somewhat intermittant at times, when slaved to the heading bug (I don't have
the piece that ties it into the VOR.)
Sometimes, it holds for a while, then "lets go" and the plane starts a very
slow circle to the right. If I cycle the autopilot switch on/off several
times, sometimes it starts to hold again (sometimes it doesn't.) It also
seems that the more I use it, the more reliable it gets.
I made a similar post once before, and about the only real comment I
received was someone thinking it may be in the connector on the back of the
DG.
Would any of these potentiometer adjustments help here (specifically the one
that has to do with gain/threshold?) Any other ideas?
Thanks
Jay,
JimC
start
end
If
This
House),
I
when
*still*
what?
surprised
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 4th 03, 02:39 PM
Jay Honeck
adjustments.
Jim, you da MAN!
I'm curious, however: You say you can't see the adjusters while sitting in
the pilot's seat, yet you also say that you adjusted them in flight, with a
safety pilot flying.
How'd you see what you were doing? I'm 6 feet tall, and less flexible
every day -- so I don't want to try anything potentially dangerous.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 4th 03, 02:42 PM
James M. Knox
"Tom Jackson" wrote in
news:Qexzb.408939$HS4.3307083@attbi_s01:
very slow circle to the right. If I cycle the autopilot switch on/off
several times, sometimes it starts to hold again (sometimes it
doesn't.) It also seems that the more I use it, the more reliable it
gets.
the one that has to do with gain/threshold?) Any other ideas?
"Let's go"? Does it actually drop off line, or just stop holding the
heading? If the former, it's probably a problem with the electromagnet
behind the switch. It can build up enough crud to keep the pull plate from
making good contact. Then the slightest vibration can sometimes cause it
to switch HDG mode off.
But I suspect that you mean that it just sometimes starts "going it's own
way." If so, and coupled with the "the more I use it the more reliable it
gets" comment, then I suspect you have an electrolytic that is shot (a very
common problem with these older units). That's going to need standard
electronic troubleshooting skills - i.e. figure out which one and replace
it.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Old December 5th 03, 12:57 AM
JimC
All the information I shared came directly from those knowledgeable and
helpful folks over at Autopilots Central in Tulsa. I wish I could remember
the name of the gentleman that helped me over the phone so I could give
credit where it is due.
Give them a call and they'll likely help you out.
JimC
"John Clonts" wrote in message
my Century 2000?
Thanks!
John Clonts
Temple, Texas
N7NZ
Jay,
find
JimC
start
end
worked
each
degrees.
If
This
House),
I
surprise
when
*still*
what?
surprised
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 5th 03, 01:03 AM
JimC
That could be caused by a number of factors. Someone else already pointed
out the capacitors going bad with age. I usually try to start with the
least expensive "fixes" and work my way up if the problem persists. The
first thing I'd do in your situation is remove and clean all the connectors
to make sure you aren't getting intermittent connections. I have see the
IIIB do what you described due to a dirty connector on the AI. I've also
seen worn cables so that intermittent shorts were developing. If you can
reach under the panel and affect the autopilot performance by wiggling wires
you should carefully inspect the cabling.
JimC
"Tom Jackson" wrote in message
news:Qexzb.408939$HS4.3307083@attbi_s01...
Jim,
have
very
DG.
one
Thanks
Jay,
find
JimC
start
end
worked
each
degrees.
If
This
House),
I
surprise
when
*still*
what?
surprised
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 5th 03, 01:06 AM
JimC
If you crunch down a little you will be able to see the openings in the
metal that align with the potentiometers. You can fit the screwdriver, have
the safety pilot confirm that you have the correct slot, have the safety
pilot assist with flying as you make the adjustments.
Good luck,
news:cGHzb.424935$Fm2.427640@attbi_s04...
adjustments.
Jim, you da MAN!
a
Jay Honeck
Iowa City, IA
Pathfinder N56993
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
IMC without an autopilot Jon Kraus Instrument Flight Rules 101 April 18th 04 07:17 PM
Phoenix AIM-54A (QUESTION) Krztalizer Naval Aviation 10 February 23rd 04 07:22 AM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
