Saftey of exposed wheel at 41,000 feet
Old December 6th 03, 02:18 AM
stephen
Default Saftey of exposed wheel at 41,000 feet
Hello,
How safe is Eclipse Aviaion's decision to expose the wheel on jet that
cruises at 41,000 feet?
Has this been done before? On what airplane?
Old December 6th 03, 02:31 AM
EDR
In article , stephen
Hello,
What difference does it make how high the airplane flies?
The Cessna Citation has had exposed wheels since it was developed in
the late 60's/early 70's.
Old December 6th 03, 02:48 AM
Don Tuite
Hello,
I think he's asking about either excess tire pressure bursting the
tire or the tire expanding and getting stuck in the wheel well.
Some sort of variation on the question comes up a couple to times a
year here. The answer is usually that no, the maximum pressure
differential is about 15 psi, which is trivial for a tire.
Don
Old December 6th 03, 03:08 AM
Tom
"stephen" wrote in message
m...
Hello,
Cessna Citation's have half open wheel bays. They cruise FL410 and up.
Old December 6th 03, 03:13 AM
Tom
"Don Tuite" wrote in message
Hello,
Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose
wheel and 98 PSI on the mains. They are filled with dry nitrogen.
Old December 6th 03, 03:16 AM
Paul Tomblin
Yes, and at sea level it's pushing against 15 psi, and in vacuum they're
pushing against nothing, which means the maximum pressure differential
between ground and cruise is 15 psi.
Paul Tomblin http://xcski.com/blogs/pt/
"We choose to go to the moon in this decade and do the other things, not
because they are easy, but because they are hard...." - John F Kennedy
Old December 6th 03, 03:21 AM
Tom
"Paul Tomblin" wrote in message
nose
Your math doesn't add up (how cliche' )
Old December 6th 03, 03:26 AM
Tom
nose
I believe he's talking about the differential between the air in the tires
and the outside air.
Old December 6th 03, 03:27 AM
DaveSproul
Apparently, another "sorry" would be in order. What he's saying is that the
difference between sea level and outer space is only around 15psi, which is
PROBABLY an almost insignificant fraction of the pressure usually existing
inside a properly inflated tire. Besides, it doesn't make any difference if the
wheel is behind a wheel well door if it is still not in the pressure vessel of
the fuselage.
An extrapolation of this discussion: the tires on the Space Shuttles. To the
best of my knowledge, they stay inflated the whole time, even in near zero
pressure on orbit.
David Sproul, Bethesda, MD
Old December 6th 03, 04:12 AM
Steven P. McNicoll
m...
Perfectly safe. What is your concern?
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
Ta-152H at low altitudes N-6 Military Aviation 16 October 13th 03 03:52 AM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 10:29 AM
