Tiny vacuum pump
Old January 16th 04, 05:41 PM
Jim Weir
Default Tiny vacuum pump
Does anybody have an idea on how to make a tiny little vacuum pump on the order
of an aquarium pump or so that will draw just a few inches of water? Preferably
110, but I can rig up a 12 volt supply if necessary.
The reason I say this is that I'm getting ready to pack a fairly large number of
bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like
to put each part in a "baggie" (sandwich bag or equivalent) along with a little
preservative oil, and then suck the baggie down with a football needle stuck
into the top closing mechanism just before sealing.
Thoughts?
http://www.rst-engr.com
Old January 16th 04, 05:45 PM
Thoughts?
If it is just the suck that has to be tiny and not the pump, how about
a toilet paper roll and some duct tape to make an adapter to your shop
vac?
Jim Pennino
Remove -spam-sux to reply.
Old January 16th 04, 05:46 PM
Ron Natalie
"Jim Weir" wrote in message ...
Why don't you just get a foodsaver? (www.foodsaver.com). It will do the
vacuum pack as well as sealing the bag (and you can make arbitrary sized bag
as long as it's narrower than the roll of "bag stock." I've got one in the kitchen.
If that's too pricey for you, then there's always this one $14.94, not sold in stores....
http://www.pump-n-seal.com/
Old January 16th 04, 06:21 PM
Ben Jackson
You just need a surplus dental spit sucker. Perfect for removing air
from the corner of a plastic bag.
Ben Jackson
http://www.ben.com/
Old January 16th 04, 06:25 PM
Jim Weir
Because the pump has to fit on a bench that is already overcrowded. If I was
going to use a shopvac, btw, it would be with a pvc waterpipe fitting glued to a
barbed fitting with plastic tubing. I thought of that and then the hassle for
each part of reaching down to turn the vacuum on for each part you want to seal.
-If it is just the suck that has to be tiny and not the pump, how about
-a toilet paper roll and some duct tape to make an adapter to your shop
-vac?
Old January 16th 04, 06:26 PM
Jim Weir
Because Foodsaver requires you to use their special bags. Besides being WAY
overpriced, the bags ain't cheap either. Yeah I knew about pump'n'seal, but
that seems to be a kluge way of doing it. I was looking for elegant.
"Ron Natalie"
-Why don't you just get a foodsaver? (www.foodsaver.com). It will do the
-vacuum pack as well as sealing the bag (and you can make arbitrary sized bag
-as long as it's narrower than the roll of "bag stock." I've got one in the
kitchen.
-If that's too pricey for you, then there's always this one $14.94, not sold in
stores....
-http://www.pump-n-seal.com/
Old January 16th 04, 06:28 PM
John Mireley
If you have a compressor, use a venturi vacuum generator.
Harbor freight has them for about $10 from time to time.
Old January 16th 04, 06:32 PM
mikem
Thoughts?
My wife bought a vacuum bagging freezer food storage system. It sucks
down the bag containing the food, and then heat seals the edge of the
bag. I have used it to seal electronic parts into bags. Should work fine
with a little preservative oil on mechanical parts.
MikeM
Old January 16th 04, 06:50 PM
Gig Giacona
How many are you doing? A drinking straw and your lungs will do a bang up
job with a zip-lock bag
order
Preferably
number of
I'd like
little
stuck
Thoughts?
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 16th 04 12:30 AM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 06:53 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 05:11 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 08:09 PM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 07:10 PM
