Do ADF antennas need replacing if changing the receiver?
Old December 10th 03, 05:28 PM
Default Do ADF antennas need replacing if changing the receiver?
We have an old KR85 ADF receiver which is giving problems. It may be
economical to fix but if not are the antennas specific to model or can
just the receiver be replaced?
Before you suggest GPS we still use NDB's in the UK!!!!
Thanks,
David
Piper Warrior G-BHJO
Scotland, UK
E-mail (Remove Space after pilot): pilot
Old December 10th 03, 10:31 PM
On Wed, 10 Dec 2003 12:29:36 -0700, mikem
The Sense wire is "matched" to the reciever, and there are many
different ways that the ferrite loops can be driven/sensed.
The best you could hope for would be that a later model of the same
brand might utilize similar antennas. You will have to talk to a
knowledgable avionics tech.
MikeM
Skylane '1MM
Thanks, I guessed there would be something different, there always
is-
It's only the pointer not working. Audio is ok so either sticking
pointer or driver circuit in the receiver. Hopefully repairable but
just wondered if a replacement would be economical or need the full
works!.
David
Scotland, UK
Old December 10th 03, 11:47 PM
Tom Nery
Funny you should add the last comment. My ADF (a Bendix T12C) also appeared
to have a stuck needle and I too could tune the radio. In trying to
identify the problem, I tried it without the engine on and low and behold it
would track (albeit very slowly) to my on field NDB. I also noticed it
would track quickest when tuned 2 Hz lower (as displayed by a Davidtron
frequency counter) than my field NDB frequency also at this frequency the
audio id seemed quite a bit nosier.
So what I have I got out of all of this? I think I actually have more than
one problem. First I think there is some engine noise that masks the
frequency (even though I can hear AM radio). Secondly I think I might have
a antenna cable connection corrosion problem. This primarily due to other
reports of similar problems. Soon I plan on executing the entire problem id
flow chart (although for the life of me I can't remember where I read it)
and then going off to my local (50 mile away) radio shop for a fix.
Hope my investigation provides some useful data.
Tom
MikeM
Skylane '1MM
is-
works!.
David
Scotland, UK
Old December 11th 03, 01:22 PM
Steve Beaver
works!.
Not really. The audio is generally dervived from the sense antenna and
receiver. A failure of any part of the loop
antenna/reveiver/resolver/driver/mechanics/winring (in other words just
about anything) could produce those symptoms.
Old December 11th 03, 10:13 PM
On Thu, 11 Dec 2003 13:22:42 GMT, "Steve Beaver"
works!.
I guess you're right. I'll have to wait and see what happens.
David
Scotland, UK
Replacing REM40E with REM37BY? Michael Horowitz Home Built 4 February 22nd 04 07:18 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 02:51 AM
Replacing Generator with Alternator Thomas Ploch Owning 2 October 11th 03 03:36 AM
Changing *BIG* Aircraft Tires [Was Coalition casualties forseptember] Stephen Harding Military Aviation 9 October 5th 03 06:42 PM
Changing Magnetos? smf Home Built 2 September 1st 03 01:48 AM
