Joining this in mid-thread as an interested onlooker.
Was working a similar problem on my van recently. I'd see a difference of 1.5 volts depending on where I tapped into the circuit, the ground location, and load in the system. That's the one item, load, not mentioned in the previous posts. When I'd fire up my gps, laptop, and cell phone charger the voltage on that circuit would become 12.2 volts while it read 13.5 at the battery. Be thinking of what load you are drawing as the voltage will drop as it pushes more amps down the wire. MAH |
Yep... that's the issue. I'm attempting to use the readings on the JPI
and the Davtron to ascertain the condition AT THE BATTERY. Because of these differences (probably due to different grounds; maybe due to voltage drop from main bus to avionics bus), I need some way to calibrate JPI readings to battery voltage; best easy way for me is to measure the main bus, at the cigar lighter. I got the plug in voltmeter and calibrated it using the HP power supply and a real nice digital shop multimeter. To my surprise, the plug in unit was VERY accurate... right on below 10 volts, and maybe 0.1 low at 12 volts (some lag, though... a second or two to stabilise). Sufficiently close for my purposes. Too busy (Christmas) and too cold (Michigan) to check it out right now. Further reports to follow. Rich mah wrote: Joining this in mid-thread as an interested onlooker. Was working a similar problem on my van recently. I'd see a difference of 1.5 volts depending on where I tapped into the circuit, the ground location, and load in the system. That's the one item, load, not mentioned in the previous posts. When I'd fire up my gps, laptop, and cell phone charger the voltage on that circuit would become 12.2 volts while it read 13.5 at the battery. Be thinking of what load you are drawing as the voltage will drop as it pushes more amps down the wire. MAH |
Helicopter headset plug - help needed | NewsGroups | Home Built | 4 | September 8th 04 05:21 PM |
Hubble plug to be pulled | John Carrier | Military Aviation | 33 | March 19th 04 04:19 AM |
OV-10A Bronco Shameless ebay plug | DavidG35 | Military Aviation | 0 | November 7th 03 06:17 AM |
WTB: Turbine ignition exciter unit, single plug | Juan E Jimenez | Aviation Marketplace | 0 | August 25th 03 12:48 AM |
spark plug question | Bill T. | Owning | 0 | July 3rd 03 07:08 PM |
