A36 Bonanza turbo prop
Old December 31st 03, 02:19 PM
Dan Luke
"Viperdoc" wrote:
I had the opportunity to see the Bonanza conversion that was
featured in Plane and Pilot magazine this month-it now belongs
to a friend of mine. The plane is truly beautiful and immaculate,
Yep, it's beautiful all right, but the payload with full fuel is 360
lbs - nearly 300 lbs. less than my C172RG.
For equal costs, I would definitely consider a turbine Bonanza
a serious competitor for a new B-58 Baron, particularly...
....if you like flying alone, or only for short distances. I'd be very
interested to hear how an owner who's had one a few years uses the
airplane.
Dan
C172RG at BFM
Old December 31st 03, 04:33 PM
Mike Rapoport
For the @$&*^! time, who cares what the "full fuel" payload is? It is
totally meaningless.What matters is the payload with enough fuel to fly the
same mission. This may be the same thing in your example with the 172 and
Turbo Bonanza but the notion of "full fuel payload" is one of my pet peeves.
If the plane can carry more than one pilot with full fuel, then the tanks
are too small.
Mike
MJ-2
"Dan Luke" wrote in message
airplane.
Dan
C172RG at BFM
Old December 31st 03, 07:21 PM
Dan Luke
I do, if I'm considering a turbine Bonanza.
It is totally meaningless.
Not in an airplane that has to have tip tanks added to give it practical
range.
with the 172 and Turbo Bonanza...
Which is why I brought it up.
then the tanks are too small.
So Cessna should have put 138 gal. tanks in Cutlass RGs?
Dan
C172RG at BFM
Old December 31st 03, 07:40 PM
Ray Andraka
Or your bladder is too large ;-) My Six will fly 5+ hours on full tanks, and
will carry my whole family(4 kids, with a 5th due next month), the dog and bags
for a few days without leaving any fuel behind (I have a 1555 lb useful load).
Since 3.5 hrs is about all any of the passengers, including the dog, can go
without crossing the legs, I can't imagine what I'd do with bigger tanks. I get
condensate in the gas if I don't keep the tanks full in the hangar, and it would
be a b*&$h to have to drain off fuel before going on a trip.
are too small.
Mike
MJ-2
airplane.
Dan
C172RG at BFM
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old December 31st 03, 07:49 PM
EDR
In article , Ray Andraka
My Six will fly 5+ hours on full tanks, and will carry my whole family
(4 kids, with a 5th due next month), the dog and bags for a few days
Sounds like it's about time to move up to that Cessna Caravan!
Old December 31st 03, 08:15 PM
Mike Rapoport
Well:
The range on your 172 RG is 600nm according to
http://www.risingup.com/planespecs/i...plane280.shtml
The turbine Bonanza burns 21GPH block speed to produce 190kts
http://justsaytheword.home.mindspring.com/articles.html
So the turbine Bonanza needs about 66 gallons to fly 600nm which weighs 444
lb. The piston A36 Bonanza has a useful load of 1400lbs
http://www.risingup.com/planespecs/i...rplane98.shtml leaving 956lbs of
useful load on a 600nm flight which is roughly 50% more that your 172RG.
Presumably the turbine is lighter and the advantage is even greater.
I don't know if the 600mn range figure for the 172RG includes a reserve, but
even if it does, the Turbine Bonanza has significantly better payload over
ANY distance.
Mike
MU-2
range.
Dan
C172RG at BFM
  #28
Old December 31st 03, 08:59 PM
Ron Natalie
"Dan Luke" wrote in message ...
range.
Isn't the fuel in the tips "free" with respect to the original gross weight of the
Bo?
  #29
Old December 31st 03, 09:32 PM
Dan Luke
Nope. 135 KTAS @ 10 GPH, 62 gal usable = 810 NM absolute range @ 75%
power.
weighs 444 lb.
So it needs 90 gal. to go 810 NM., about 610 lbs.
leaving 956lbs of useful load on a 600nm flight which is roughly
The turbine Bo' in the article has a useful load of 1160 lbs., leaving a
useful load over the same range of 550 lbs.; 100 lbs. less than my
172RG.
Evidently not.
a reserve, but even if it does, the Turbine Bonanza has significantly
better payload over ANY distance.
Nope.
Dan
C172RG at BFM
  #30
Old December 31st 03, 09:40 PM
Dan Luke
practical range.
weight of the Bo?
Pretty close, but the point is you need it all to get useful IFR range,
and then you can't carry much load. The poster I was originally replying
to compared the aircraft favorably to a Baron 58. I think it comes off
pretty poorly in the comparison.
Dan
C172RG at BFM
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Turbo prop AT-6/SNJ? frank may Military Aviation 11 September 5th 04 02:51 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Early Bonanza or Apache? Brinks Owning 11 July 16th 03 06:01 PM
