Can you mix oil weights?
Old January 2nd 04, 09:50 PM
Ben Jackson
Default Can you mix oil weights?
Let's say you're at a point where you need to add a quart of oil.
You've decided you would like to finish this oil change interval at
a lighter weight (eg you put in AeroShell W100, SAE-50, and now it's
freaking cold). Can you add a quart of a (substantially?) lighter
weight oil (presumably in the same 'series')?
Ben Jackson
http://www.ben.com/
Old January 2nd 04, 10:13 PM
Dave
"Ben Jackson" wrote in message
news:CQkJb.261117$_M.1211945@attbi_s54...
Ben Jackson
why not just change the whole lot and do the job properly?
Dave Stadt
Ben Jackson
http://www.ben.com/
Aeroshell says it is just fine to do so:
"All approved SAE J-1899 (former MIL-L-22851) and SAE J-1966 (former
MIL-L-6082) AeroShell oils are compatible."
Old January 2nd 04, 10:35 PM
Kyle Boatright
Ben Jackson
http://www.ben.com/
Absolutely. All aviation oils are compatible, and have to be to meet the
appropriate spec's. Otherwise, you'd be SOL if you needed to add a quart of
oil and the FBO on the airport you stopped at didn't carry *your*
brand/weight of oil.
KB
Old January 2nd 04, 10:40 PM
Ron Natalie
"Dave" wrote in message ...
Ben Jackson
Shell says you can mix grades of AeroShell as long as both grades
are allowed for your engine.
Old January 3rd 04, 01:16 AM
Ben Jackson
Did I mention it's freaking cold?!
Heck, with the weather around here I don't even want to go to my Shell
distributor to get the oil, one quart or a whole case.
Ben Jackson
http://www.ben.com/
Old January 3rd 04, 02:44 AM
Mike Rapoport
Yes you can, but it might take a lot to make a meaningful difference unless
your engine is a big leaker.
Mike
MU-2
Ben Jackson
http://www.ben.com/
Old January 3rd 04, 05:03 AM
G.R. Patterson III
Yes.
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 3rd 04, 03:45 PM
Dave S
heheh..
too cold to drive and get oil.. but not too cold to fly and burn it
off.. thats a die hard pilot.
Dave
JSF/F-22 weights John Cook Military Aviation 2 September 11th 04 07:32 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 07:19 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 08:35 AM
Engine weights Salem Farm & Garden Home Built 5 July 22nd 03 05:27 AM
