Engine Questions
Old January 20th 04, 04:47 PM
Marvin Barnard
I agree with your choice, and fly VW myself.
If you don't mind a redrive, VW Gene Smith offers an
excellent version for type 1 VW which will turn a big prop and produce
100 hp at 200 lbs. installed. If you build it the cost is aproaching
$3000.00 bucks.
A direct drive (for aircraft like Texas Parasol, Teenie, M-19, or
VP-1 etc.) can be built for 700.00 bucks if you start from a good core.
VW type 1 is the most proven engine in the world considering it's
billions of hours time in ground vehicles and a lot of airtime as well.
No engine design ever built even comes close to the aftermarket
development data, performance data, endurance data, cost economics, and
parts availablility as the type 1 VW. ..........None.
Old January 20th 04, 04:53 PM
jls
"Bill A." wrote in message
On Mon, 19 Jan 2004 21:21:06 -0500, " jls"
link.net...
I'm still trying to select an aircraft to build from scratch and it's
starting to look like it's coming down to the engine (budget reasons of
course). I really like the Pietenpol Aircamper but from what I've read
you
need a Rotex
Rotax? Nope. Pietenpols use old Ford A-Model engines, Corvair
engines,
and affordable old Continentals like the A-65 and C-85. If you are on a
tight budget in Southern California, the Pietenpol Aircamper may be the
way
to go. Do a google and you'll find all kinds of Piet groups. The Piet
clan gather every summer in Brodhead, Wisconsin for a fly-in. It is
said
that if you visit with them a spell will be cast over you and you'll be a
Piet-head for the rest of your life.
I've done a bit of searching online but I can't seem to find
any Continentals for sale that aren't already attached to
something. Where would I find some and what's the ballpark
price? Are Corvair engines still around with as few
Corvairs that were produced I would think the supply would be
limited (along with parts) and can you still find Ford Model
A engines any more, much less parts? What would be the most
economical, commonly used engine out there now a days?
Try Barnstormers.com, Trade-a-Plane, and Ebaymotors.com for old
Continentals. We just found one, an A-65 we can convert to A-80, nearby
for just over 1k and will put about 2k in it for rebuild. For 3k you can't
beat it. Subarus will work too, as someone suggested. You probably need
a redrive for a high-turning Soob engine. Corvair engines are plentiful
and parts are not hard to find. And believe or not there are plenty of old
A-Model Ford engines, but I don't know the price. I'll ask a friend who
just bought one.
I do recall an A-65-powered Piet with a big lead weight bolted to the front
of the engine. I wouldn't want that so when you build the Piet designed
for the heavy Ford engine, you have to be careful about W&B.
Just keep shaking the bushes and you will find it. Get somebody to send
you the old articles from Mechanix Illustrated where Bernie Pietenpol said
he could have you flying for about $500 and you'll be sold. Or was that
$200? 50?
Old January 20th 04, 05:09 PM
jls
"Marvin Barnard" wrote in message
$3000.00 bucks.
I put around 100 hours on a VW-powered Karatoo with redrive. We never
really got it dialed in but I was impressed with that big prop out there
ticking over and acting like an airbrake on final. And when you shoved the
throttle in, that thing could do some climbing too. The redrive used a
cogged belt which gave some trouble but could have been tweaked out with
time and effort. It was not my project but I enjoyed flying it. One time
I was out over Lake James when the VW engine seized from overheating and
barely made it to dry land. Plenty of power from an EA-81, and then an
1835cc VW. The VW engine always got too hot, but now that I look back on
it, it was because they hadn't cowled and baffled it right and should have
used a bigger oil sump and oil cooler. I had a 3-liter Porsche Targa which
held about 10 or 15 qts. oil and a big cooler up front for cooling it. You
have to educate yourself and look around, be circumspect.
Yeah, I'm sold on those type 1 VW engines --- simple, durable, light, cheap,
fun to rebuild and tinker with and you can run them forever. But if you
turn one up to 3k-3.5k rpm, you're going to have to be especially careful to
cool it. Have you seen the Piet with that huge radiator up front to cool
the Ford engine? If I were building a Piet I'd go with the Ford and be
patriotic about it. Besides, that low-revving guttural engine purr is,
well, indescribably sonorous.
Old January 20th 04, 05:45 PM
Jay
I suppose if the VW is lighter and more powerful than the model A
engine, you could always mount it in the same place put lead weights(a
car battery?) up front.
I'd vote for the longer nose/lighter plane though, you can always
enlarge the rudder. Also as far as strait line stability, the
fuselage area in front of the CG may be offset to some degree by the
gyroscopic effect of the spinning mass being further from the CG.
Regards
I fly a VW.
But it won't swing enough prop to fly an Air Camper.
The Piet Air Camper was designed around the Ford engine.
The plane needs that mass of metal up front to balance properly.
With a lighter, a longer mount is needed to keep the plane in balance.
Longer noses usually mean less yaw stability.
A Contenental A-65 - A-85 seems to work out ok.
At least you see them flying now and then.
Richard
Old January 20th 04, 09:29 PM
For more information on Pietenpol engine options, try the Buckeye Pietenpol
Page at: http://users.aol.com/BPANews/www.html.
B/R
Mike B.
ink.net...
course). I really like the Pietenpol Aircamper but from what I've read you
need a Rotex or other "aircraft" engine and of course that's expensive. I
was also thinking of the Volksplane, which I don't like as much but it can
use a VW engine which I can find cheap and I've torn down and rebuilt a
couple of them so I'm more familiar with them.
So the question's are.does anyone have experience (good or bad) with a VW
engine in an Aircamper? What other scratch build planes work well with VW
engines other then the Volksplanes? What other engines would fall into the
same price range has a VW (which I would be getting used and rebuilding
myself)?
Thanks all
Bill A.
Canoga Park, CA
PS. If anyone has a Pietenpol, Volksplane, or similar plane in the LA area
I
sure would like to take a look at it.
Old January 20th 04, 09:58 PM
Ron Webb
Everything you ever wanted to know about Corvair engines
http://www.flycorvair.com/
I've read that Bernie Pietenpol never used anything else after he tried one
on a Piet. Forged crank, been flying since the early '60's. Nobody has ever
seen a cracked jug or broken crank. Much smoother than a 4 cylinder. Lots of
really cheap parts available from
http://www.corvair.com/user-cgi/pages.cgi?category=home
I picked up a running Corvair engine for $50, Machined a prop hub, and that
was all that was needed to get one running on my airboat. Not optimum, but
good enough to work. You can spend a lot of money, or almost none at all.
Old January 20th 04, 10:19 PM
Tom Cummings
" jls" wrote in message news:j7dPb.38883
Corvair engines are plentiful as well as the parts. We are talking rebuilds.
Use '64 through '69 engines and view http://www.flycorvair.com/
and http://www.corvaircraft.com/ for more specifics on selective cases and
heads to use.
Corvair College V was just held this past weekend at Hanover, CA.
Tom
Old January 21st 04, 02:28 AM
Marvin Barnard
Be nice!........;-)
Old January 21st 04, 03:52 AM
Greg Piney
And if you really want to see what you can do with a Corvair engine,
take a look at: http://www.visionaircraft.com/CorvairCraft
Greg Piney
Vision#33
heads to use.
Tom
Old January 21st 04, 03:53 AM
Morgans
Cough cough, sputter, cough.
Is there a full loon, err- moon out?
Jim in NC
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
