Kitfox 7/Rotax 914 Performance Questions
Old January 21st 04, 05:46 AM
Jim Carriere
Default Kitfox 7/Rotax 914 Performance Questions
Well folks, I hope I'm not opening up a can of worms on this. I searched
the usenet archives on google about this, and nothing quite answered my
question, so...
I emailed Skystar, but want to ask here too.
The kit manufacturer claims a 150mph cruise and 160mph top speed. This
seems a little optimistic. This is a side-by-side 2 seater, 100-115hp
engine (turbo maintains output to 16,000 feet), approx 1500lbs gross weight
(about 750 empty). The 100hp normally aspirated engines list 120 and 125mph
for cruise and max respectively. So it doesn't quite add up...
Has anyone backed this up in practice?
I did some rough calculations on scratch paper. The short answer is it
_might_ be possible. Taking into account the turbo engine's higher output
at high altitude, and that the non-turbo aircraft probably max out TAS at
about 5,000ft compared to over 10,000 for the turbo, air density's effect on
profile drag vs induced drag, air density effect on the normally aspirated
engines... Again, my best answer is... maybe.
Thanks for any help.
Old January 21st 04, 05:54 AM
Richard Lamb
That's about what the Wittman Tailwind does with 100 hp.
It too is a side by side high wing - with a wing strut.
question, so...
Old January 22nd 04, 05:55 PM
Ronald K. Stevens
question, so...
Yep, 150mph is possible in a KitFox. I've got one. You've gotta' go
high to get the TAS up there, but with the turbo is doable. (I've got a
turbo, but not flying yet). The SkyStar demo ship put up those numbers
on the way to Sun N Fun. Other turbo drivers report about the same
thing. Down low though, you're TAS will be in the 130+ mph range.
Hope this helps,
Ron
KitFox Series 6, NSI turbo, CAP 140
Ronald K. Stevens
The MITRE Corporation
Center For Advanced Aviation System Development (CAASD)
Air-Ground Simulation Development
7515 Colshire Drive M/S N420
McLean, VA 22102-7508
http://www.caasd.org
Voice: 703-883-6629
Fax: 703-883-1917
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
Hair on the palm of my hand; was Jets: Takeoff performance questions pac plyer Home Built 1 July 2nd 03 03:14 PM
