Building chasing airport lights -- Attn: Jim Weir?
Old January 21st 04, 09:57 PM
Jay Honeck
Default Building chasing airport lights -- Attn: Jim Weir?
Today a pilot-guest had the coolest idea for the side-entrance to our lobby:
"Chasing" lights recessed in the drop-ceiling tiles, leading to the main
lobby area, that look just like the "rabbit" lights that lead to the
approach end of a runway!
(Background: Over half of our guests come in the "wrong" door to our lobby,
which leads more directly to the pilot's lounge than to the reservation
desk. As a result, we've often got people milling around looking "lost" in
the pilot's lounge. These chasing lights would "lead" them to the correct
area, and be really cool looking, too.)
So, I stopped at the local Rat Shack, and found the perfect little 12 volt
blue lights, 1/2 inch in diameter. (Blue would be a bit toned-down from
white strobes!) It would be a simple matter to drill 1/2 inch holes in the
ceiling tiles, every 12 inches or so, and push them through the tiles from
above so that only the blue "dome" was sticking out through the hole. I
think 12 volt lighting would be safer in the ceiling than 120 volt Christmas
lights, as a couple of people have suggested...
Here's the problem: How to sequence them? The guys at Radio Shack had NO
advice at all -- they were all stumped. The lights should flash
sequentially pretty fast, but I think they'd look pretty stupid if they
weren't coordinated properly. I'd also want to incorporate a motion
detector on/off switch, so that they weren't running all the time.
Anyone got any ideas? Are there affordable electronic "sequencers"
available? Is this something RST Engineering could build for me, Jim?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 21st 04, 10:10 PM
Ron Natalie
"Jay Honeck" wrote in message news:GBCPb.117569$xy6.376015@attbi_s02...
Shouldn't be very hard. How many of these bulbs you going to use?
Old January 21st 04, 10:13 PM
Roy Smith
In article GBCPb.117569$xy6.376015@attbi_s02,
The guys at most radio shacks these days can't change the batteries in a
flashlight without a training video and a map.
25 years ago, I would have grabbed a 555 timer, a 4-bit counter, and a
4-to-16 demux out of my TTL collection and built a sequencer in an
afternoon for about $10 in parts. The breadboard it was built on would
have cost more than the chips. Of course, if I told you I was going to
use it to drive a series of blue LED's, you'd look at me like I was nuts
(everybody in those days knew it was theoretically impossible to build a
blue LED).
I wish I knew were all that stuff went. I can only guess it got tossed
when mom sold the house a few years back.
Old January 21st 04, 10:23 PM
Jay Honeck
Not sure, but I'd guesstimate between 20 and 30.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old January 21st 04, 11:00 PM
You mentioned Christmas lights, some of those have sequencers attatched.
Maybe you can adapt the controller off of something like that.
Jim Burns III
Remove "nospam" to reply
lobby:
lobby,
in
Christmas
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old January 21st 04, 11:11 PM
Don Tuite
On Wed, 21 Jan 2004 21:57:58 GMT, "Jay Honeck"
You might search on rope lights. Here's an example:
http://www.all-lights.com/IBS/Simple...rchy/0401.html
Don
Old January 21st 04, 11:29 PM
C J Campbell
This sounds like a horrible idea, actually. Someone is going to have a grand
mal seizure right there in the lobby.
Old January 21st 04, 11:46 PM
plumbus bobbus
Here is my very brilliant idea of the week: why don't you send Jim Weird
(Mr. Fantastic) a private e-mail?
I need to take a ****, everyone! I just thought I would let the whole world
know.
lobby:
Old January 21st 04, 11:59 PM
C J Campbell
OK. Back when I was in college I worked part time for a company called
Coastal Sales NW. They manufactured and distributed sign parts. Their rotors
were especially good. What you want is called a "chaser." These devices were
once very expensive, but now they can be had for less than $100. Digital
Lighting Systems makes good ones. http://digitallighting.com/index.html You
probably want the BC series for your low voltage system. A guy could go nuts
wandering through their on-line catalog. Christmas light chasers are
probably too low voltage for your application, although blue LED Christmas
lights might work well and the whole string only uses 5 volts.
If the lights are too bright they will indeed induce seizures in the
susceptible. Red lights and white lights are worse than the blue lights you
propose. This is a problem at theme parks where a lot of rides have flashing
and chasing lights. You will often see signs warning epileptics of the
danger, but under the right circumstances these lights have induced seizures
in persons not known to have had epilepsy. I suspect that having the lights
overhead will increase the level of discomfort.
Old January 22nd 04, 12:01 AM
C J Campbell
"plumbus bobbus" wrote in message
news:MbEPb.97212$Rc4.586923@attbi_s54...
world
| know.
Yes, we can all see that you are full of it.
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
