PA32-260
Old January 28th 04, 09:24 PM
Greg Esres
Default PA32-260
The Cherokee 6-260 has a shorter book takeoff roll than the -300. Any
suggestions as to why? The gross weight is the same. Props slightly
different.
Old January 28th 04, 10:52 PM
Ben Jackson
different.
Better test pilot that day?
Ben Jackson
http://www.ben.com/
Old January 29th 04, 01:37 AM
Mike Rapoport
Seems unlikely. What are you using for a data source?
Mike
MU-2
"Greg Esres" wrote in message
different.
Old January 29th 04, 03:31 AM
Greg Esres
That occurred to me as well. ;-)
Old January 29th 04, 03:40 AM
Greg Esres
Nothing authoritative. I don't have the POH's. But a pilot of my
acquaintance first asserted the difference to me. He claims to have
researched the issue thoroughly before he bought his -260. He claims
that bush pilots prefer the -260 for that reason.
The only supporting evidence I have found is a web site that had
performance specs on the a/c and it validated what he said.
I agree that it seems unlikely, but I'd prefer to be able to show the
guy some data. Every now and then, something unlikely turns out to be
true. ;-)
Old January 29th 04, 04:13 AM
G.R. Patterson III
According to _The Illustrated Buyer's Guide to Used Airplanes_, by Bill Clarke,
the takeoff roll for the 300 is 110' *shorter* than that of the 260. Since that's
what one would expect, I tend to believe him.
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 29th 04, 04:15 AM
Greg Esres
There seem to be a scattering of web sites that supply the same data.
I suspect they're using one common data source. However, I found one
web site that showed the -260 as a worse performer, as you would
expect. I'm going to see if I can acquire a -300 POH so I can compare
with my acquaintance's -260. Maybe whoever created the original
database used for the internet info got it wrong.
Old January 29th 04, 05:03 AM
Greg Esres
Since that's what one would expect, I tend to believe him.
So do I. Thanks for that.
Old January 29th 04, 07:02 AM
Max T, CFI
My really old copy of the Aircraft Bluebook Price Digest shows the following T/O ground runs:
PA28-300 '73 and later 900'
PA28-300 '72 and earlier 1050'
PA28-260 '74-'78 1200'
PA28-260 '73 and earlier 740'
All four show a gross weight of 3400 lbs.
Max T, MCFI
Greg Esres wrote in message ...
different.
Old January 29th 04, 07:11 AM
John Godwin
"Max T, CFI" wrote in
news:Fl1Sb.138398$nt4.616428@attbi_s51:
PA-28? ... did you mean PA-32?
John Godwin
Silicon Rallye Inc.
(remove SPAMNOT from email address)
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 01:35 AM
