taxi in reverse?
Old February 4th 04, 05:19 PM
Corky Scott
Mostly just amusing and idle speculation... But I've seen some cold rainy
days when it would sure be nice to preflight in the hangar, climb in, and
just drive out. G
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Two things: 1. Some hangars have slightly slanted floors such that
when the chocks are removed, the airplane wants to roll out. They
have to be winched in of course but lots of hangars have winches to
reel the airplane in without a slanted floor.
2. If it's cold and rainy, you're flying? ;-)
Corky Scott
Old February 4th 04, 08:49 PM
Jay
Thats a cool idea even if it goes counter to the homebuilt creed "Keep
it simple stupid." Maybe you compromise on the brake function,
keeping your brakes on the mains, and put the motor on the castering
nose gear. Steer like usual with differential braking.
That might be a lot of juice stopping a 1,000 lb airplane from 60mph
to 0 in 10 seconds. Loads are easy though, you don't have to dump
that power into your battery. Think of it the other way around, how
much power would you need to accelerate 1,000lb to 60MPH in 10
seconds?
Modern jet fighters dump waste heat from the hydraulic system into
their wing tanks. Worst case scenario, heavy manuvering on low tanks.
"James M. Knox" wrote in message ...
(Malcolm Teas) wrote in
om:
I always figured if I was building a homebuilt I would investigate
some relatively small motor/brake assemblies that are used on smaller
electric automobiles.
My first thought when reading this was, "sounds cool!". And I started
to think it through.
All true. Of course, I was thinking primarily in terms of taxiing only a
short distance - into or out of a hangar, for example. I haven't done the
brake calculations, but I *think* (back of the hand calculations) that the
amount of power generated stopping the plane on the runway and taxiing in
is small enough that even a "fully charged" battery can easily absorb it.
just drive out. G
James M. Knox
Austin, Tx 78721
Old February 5th 04, 04:04 AM
Capt.Doug
"James M. Knox" wrote in message I haven't done the
The electric motor on my hybrid car is 6 cm thick and the diameter is larger
than some homebuilts' tires. It's rated for 10 hp and it's hooked into a 144
volt battery which weighs more than I do. The motor goes into regenerative
mode for braking. It recharges the battery in quick order, but it doesn't
stop the 2800 pound car very well. Based on this, I'm inclined to think that
you will still need traditional brakes.
D.
Old February 5th 04, 12:14 PM
arcwi
What one should use is to replace the front weel hub wtih a hub-motor
http://www.goldenmotor.com/ .
I am sure that this would not add that much weight and if the hub-motor is
selected corectly, the original tyre used, one could not distinguish it form
original.
Now, I wander if this could be installed on a certified aicraft with some
field approval as a minor modification...
om:
just drive out. G
James M. Knox
Austin, Tx 78721
Old February 6th 04, 03:08 AM
Ernest Christley
original.
The largest one is 500W, a little less than 1Hp. (Is that right?) Just
barely enough power to push a light aircraft out of the hanger? Now how
much does it weigh (along with the 500W voltage converter to go from 12
to 36V)?
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old February 18th 04, 04:16 AM
David Lesher
I once, on a flight from Bogota to MIA, sat next to an ex-FBI agent,
ex-Customs pilot, then MD for PHS.
He talked about making short field landings in a King Air by going
into reverse pitch while still 50 ft above the dirt.... ARGH!
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old February 18th 04, 04:17 AM
David Lesher
You can put a small winch at the back of the hangar to pull
you in, but yes, you must get out to attach it.
Old February 18th 04, 12:23 PM
Bushy
Known as Beta Mode in a Porter, and was used to drop from the sky at a great
rate of knots when you wanted to get down in a hurry. It has been used for
parachuting and allows the aircraft to get down faster than the jumpers.....
Also good for taxi operations.
I am considering a Storch, www.storch.com.au and have just had a great chat
with the designer about this and a few other things. Looks like I'm about to
take a trip down to see him......
Peter
Old February 18th 04, 03:13 PM
G.R. Patterson III
The technique was commonly used by CIA pilots for short field insertions in SEA.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
Old February 21st 04, 12:25 AM
Blueskies
That's funny!
Dan D.
"Boogerz" wrote in message ...
Shortly after I first got my ticket, I took my wife and kids to see family
in a 172. At the other airport, we were told to back up to a fence. So, I
shut down and pushed the plane into place.
My wife was furious about something as we walked thru the terminal to meet
family...finally she blurts out "I've never been so embarassed in my life!
I'm not going anywhere with you again until you learn to use the reverse."
"David Lesher" wrote in message
Reverse scoop Paul Lee Home Built 9 April 13th 04 01:58 AM
taxi in reverse? Malcolm Teas Home Built 10 February 21st 04 12:26 AM
Pilot log book and taxi testing Bob Olds Home Built 1 February 11th 04 03:32 PM
Reverse NACA duct Chris W Home Built 22 October 28th 03 10:59 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
