Idea for Jim Weir
Old February 9th 04, 01:25 AM
Don Tuite
Default Idea for Jim Weir
Hey Jim. How about an antenna-line pad (maybe 40 dB or so) that you
could switch in when listening to unicom? The local guys would still
break squelch, but the guys 100 miles away wouldn't. And even with
step-ons, I suspect the hetrodyne squeal would be reduced. Make it
selectable by a pushbutton on the intercom. For safety, maybe it
could automatically switch itself out when you changed frequency or
radios. (How? I dunno. Maybe sense a change in the L.O. freq?)
Don
Old February 10th 04, 03:59 AM
could switch in when listening to union? The local guys would still
Well, I'm not Jim, but what the hey, it's a public forum.
Like you, I am often frustrated by congestion on unicom frequencies in and
around urban areas, BUT...
Unfortunately, the difference in received signal level from equal power
transmitters 10 miles away and 100 miles away is only 20 dB (assuming
line-of-sight). There is probably 10 dB variability in effective unicom
station transmit power owing to different antenna gains, cable losses, etc.
That leaves only a 10 dB "window" to separate "desired" signals from
"undesired" ones, and only about 4 dB if the undesired is a more realistic
50 miles away. An additional negative would be the two coax relays or other
type of RF switches required to switch the pad in and out. These would add
considerable cost and reduce reliability, but most significantly would hurt
receiver sensitivity (since there will be some signal loss in the switches.
It's an imaginative idea, though.
-Elliott Drucker
Old February 10th 04, 05:44 AM
Tom Pappano
Don
You can also just tighten the squelch. The heterodynes will still be
there though, even if you rigged up a pad.
Tom Pappano, PP-ASEL-IA
Building chasing airport lights -- Attn: Jim Weir? Jay Honeck Owning 79 February 29th 04 02:10 PM
Jim Weir and radio racks Matthew M. Jurotich Home Built 4 November 13th 03 03:51 AM
A Brilliant Idea nafod40 Home Built 4 September 9th 03 10:33 PM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
B is for Governor candidate Jim Weir Montblack Owning 9 August 13th 03 12:45 AM
