#71
On Tue, 10 Feb 2004 02:43:34 GMT, Paul Folbrecht
wrote: So that $15.2K is for a remanufactured engine or to remanufacture _your_ engine?? Cause I thought doing the latter (tearing it down and replacing most of the parts) was the 'usual' method, and I thought (had been told) that around $10K for everything for a 235 was about right. (No, not told by the FBO that's selling the plane.) Factoryengines.com lists O-235s for 15.2k, 17.9k, and 22.5k (overhaul, remanufactured, and new respectively). Plus, you will have install costs and have accessories to overhaul or replace. You could hit $20k easily for an installed overhauled engine. Factoryengines usually has pretty good prices, but I was surprised about the $15k for a O-235 overhaul. I have a O-360 in my Cherokee, and its overhaul is only $13.8k. Regarding the differences between overhauls - I'm not an expert at this by any means, but here's my take... Overhauled engine: Engine parts are replaced or reworked as necessary to be within overhaul limits. You need to be careful about what type of overhaul is specified. There are two main kinds of overhauls, service limits, and new limits. Service limits are the absolute minimums as specified by the engine manufacturer (a bad idea in my opinion). There are also overhauls to new limits, ie the components of the engine have the same tolerances as a new engine. Either way, the engine comes out with the same logbook, and total time is not reset. It is however 0 hours since major overhaul. Blueprinted engines: There are speciality shops that match/balance components to provide a smoother and more powerful engine. These typically cost more than a regular overhaul, and perhaps more than a remanufactured engine. Regardless, the engine will not be zero timed. It is essentially an overhaul to super-specifications. Remanufactured. Engine components are reworked/replaced to new limits. Engine is issued a new logbook and is 0 TT / 0 SMOH. Many question the value of the reman besides having a zerotimed logbook. New engine: This the easy one. It is brand new from Lycoming. O TT, 0 TSMOH. Avweb has a good article on engine overhauls: http://www.avweb.com/news/maint/182826-1.html -Nathan |
#72
Jaaaaaaaaaaaaaaaaaaay, come in here and teach this foundling about the Grapes of
Wrath. Jim Paul Folbrecht shared these priceless pearls of wisdom: -But I can't seem to get autogas at most airports. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
#73
![]() Paul Folbrecht wrote: So that $15.2K is for a remanufactured engine or to remanufacture _your_ engine?? Cause I thought doing the latter (tearing it down and replacing most of the parts) was the 'usual' method, and I thought (had been told) that around $10K for everything for a 235 was about right. That outfit will sell you an overhauled engine for $15.2K. You will have to remove yours, install theirs, and send them yours as a "core". You re-use all the old peripherals, such as the carb, alternator, etc.. There are lots of extra goodies that you should replace at this time, such as the cooling baffle material. Now, an overhauled engine is one in which the engine is disassembled, every part is checked to make sure it meets the specs for *return to service*, and the engine is put back together with any part that doesn't meet those specs replaced with one that is *serviceable*. A remanufactured engine is one in which every part meets the specs for a *new* part, not just a *serviceable* one. A new engine is just that. What you're describing is generally referred to as a "field overhaul". There are pluses and minuses to doing it this way. If the mech is good and you opt for replacing unserviceable parts with new ones, you can wind up with a better engine than swapping for a major shop overhauled engine, but if you do that, it'll likely cost you in the 15K range anyway. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
#74
![]() "Paul Folbrecht" wrote in message link.net... Wow, Chris, we could've ended up there together. :-) MTW is where we went for lunch yesterday. Yeah, but my instructor would never stop for lunch... ![]() And, as for the weather, I can't say you were being overly cautious, cause it was indeed MVFR at times. Well, ATW-MTW turned out to be not bad (around 6 miles in haze most of the way, cig about 2500agl), but back to MKE I hit several bad spots. I had to go to 1500agl over OSH and considered landing right there for a moment, but it got better shortly thereafter. (This was about 4PM.) Hmm.. We started out around 4, and the ceilings were already down to 1200' - we didn't get more than 1000' agl the entire flight. (well, we didn't really try to, either, just held 2000 MSL.) 6 miles visibility sure ain't much at that height. Got a nice spooky view of Holy Hill in the haze though. Do run up there sometime and visit Joe's, across from the airport. Well worth it. ~Paul Will have to do that - on my SOLO x-country. :P |
#75
Have you even asked an insurance company for a quote?
That might be a sobering experience with your hours. Also, if financed, the bank wont just finance any amount, they'll figure a value they'll work off and if the sellers asking too much, you'll come up with the difference. I almost did something like this right after I got my CFI, a C152, about half this much (but in 1983), but I was going to have it in a flying club and instruct in it. Even then I had doubts and didnt, and glad I didnt as the flying industry started sliding right after that. You may be average FAA size NOW, don't mean you'll stay that way, or your wife/girlfriend/friends. Kind of like buying a computer, reach a little further than you think you need NOW and you'll probably thank yourself later. As far as this hangar throw-in, see how much they'd lower the price if that's deleted. It's a trainer, it's probably fairly beat-up, being outside won't hurt it much more. I'm betting they wont lower the price at all. If not, then just turn and leave - it's a scam. And as far as the advice on a four seater, keep in mind most of the ones mentioned really are 2+2's. More room to recline back, throw a few things in the back, not overlap shoulders too much with the person on the right side, etc. But at least with those you can work towards your IFR, and build up hours in something a little faster and more comfortable. My advice: RENT. Buying was the best thing I ever did, but it doesnt work for every situation. Chris |
#76
Of course. Do you think I'm just some recently licensed pilot who thought about buying the first airplane he saw for sale and asked a bunch of people on the Internet if he should do it or not? AOPA quoted me a bit under $600 for hull & liability which was much lower than I was expecting. That might be a sobering experience with your hours. Also, if financed, the bank wont just finance any amount, they'll figure a value they'll work off and if the sellers asking too much, you'll come up with the difference. If I bought it I'd be paying cash. You may be average FAA size NOW, don't mean you'll stay that way, or your I pretty much plan on it. Bodybuilding/fitness is another interest of mine. I'm sure as heck not gonna gain 40lb of blubber in the next year or two, anyway. wife/girlfriend/friends. Kind of like buying a computer, reach a little further than you think you need NOW and you'll probably thank yourself later. That strategy definitely works well for computers. As far as this hangar throw-in, see how much they'd lower the price if that's deleted. It's a trainer, it's probably fairly beat-up, being outside won't hurt it much more. I'm betting they wont lower the price at all. If not, then just turn and leave - it's a scam. It actually looks surprisingly good. They've had it in the hangar the last couple times I've been there working on it and the exterior does look really good. And as far as the advice on a four seater, keep in mind most of the ones mentioned really are 2+2's. More room to recline back, throw a few things in the back, not overlap shoulders too much with the person on the right side, etc. But at least with those you can work towards your IFR, and build up hours in something a little faster and more comfortable. The 2-seat vs. 4-seat question is one of the most important for me right now. And I am heavily leaning (still) towards the former. 4 seats would be very nice, indeed, when I want them, but I need to be pragmatic here. I don't need them and won't use them most of the time. Thanks for the comments. ~Paul My advice: RENT. Buying was the best thing I ever did, but it doesnt work for every situation. Chris |
#77
If we compare a 152 to a 150, the 152 has a better engine (Lycoming) and
slightly better performance. However, the 150 has cheaper parts cost and a lower purchase price giving a lower TCO. I find 152's overpriced at the best of times and usually in worse shape than the 150's. Advantage, 150. I priced some 150s on aerotrader and you're sure as heck right. As a matter of fact I think right now a 150 might be my best bet. Other under-valued planes to look at would be the Grumman AA1, Beech Musketeer (parts are expensive but rarely needed), Piper Tri-Pacer or Colt (fabric so hangar recommended), Cherokee (even a two seater), or even a low time Tomahawk (bad rep by people who've never flown them). Good examples of all of these can be found for under 25K. My advise would be to sit back, let this one go, leave the nest (FBO), and check the classifieds. Not just the web based ones either. A lot of aviation is still run by old timers that have no interest in computers at all, so you'd be missing a large portion of possible deals. So when you go for that next $100 hamburger, ask around about what's for sale. |
#78
ATW-MTW turned out to be not bad (around 6 miles in haze most of the way, cig about 2500agl), but back to MKE I hit several bad spots. I had to go to 1500agl over OSH and considered landing right there for a moment, but it got better shortly thereafter. (This was about 4PM.) Hmm.. We started out around 4, and the ceilings were already down to 1200' - we didn't get more than 1000' agl the entire flight. (well, we didn't really try to, either, just held 2000 MSL.) 6 miles visibility sure ain't much at that height. Got a nice spooky view of Holy Hill in the haze though. Are you accusing me of scud-running just two weeks after getting my license?! Damnit.. you're right. The cigs were low. Hey, I got briefings out of both Timmerman and Appleton and did NOT get "VFR not recommended" either time (I would never not heed such a warning- never, at this stage of experience, anyway). And both times they told me again things looked to be "clearing up" which they most certainly did not. I have actually been thinking about that whole experience quite a bit. I always thought briefers would be erring on the side of caution but not this time- sometimes the weather just does not do what's expected. Of course all those low cigs and haze were completely unforecast for the whole day. It was supposed to be clear below 12,000' as of midnight Saturday. But the wind was as forecast. Do run up there sometime and visit Joe's, across from the airport. Well worth it. ~Paul Will have to do that - on my SOLO x-country. :P |
#79
![]() Paul Folbrecht wrote: ... and the exterior does look really good. My personal nickname for my old 150 was "The Whore", because it was painted up real pretty but had been heavily used. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
#80
Two LOLs in a row here.. G.R., you're as funny as the Onion.
G.R. Patterson III wrote: Paul Folbrecht wrote: ... and the exterior does look really good. My personal nickname for my old 150 was "The Whore", because it was painted up real pretty but had been heavily used. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
Want to talk with Eggenfellner customers | Ed Wischmeyer | Home Built | 3 | December 19th 04 04:20 PM |
Radio talk in the UK | Paul | General Aviation | 36 | March 8th 04 10:57 PM |
Can we talk about the Randolph problem? | Michael Horowitz | Home Built | 5 | October 30th 03 04:44 PM |
Thunderbirds members to talk about flight history | Otis Willie | Military Aviation | 0 | August 20th 03 04:13 AM |
crazy talk - 320 into a 360 application? | [email protected] | Owning | 1 | August 6th 03 03:32 PM |
