Totally aside from the technical/mechanical side of things.......
Once a certified airplane has had the engine removed and swapped out with a Mazda rotary engine and aftermarket reducer drive, what steps are nessary to fly without the FAA crawling up my butt? I'm sure a regular A&P would run like hell from one of these when it came time for an annual... Take it easy on me guys.... I don't even have my wings -- yet! *** Sent via http://www.automationtools.com *** Add a newsgroup interface to your website today. |
JD Butler wrote:
Totally aside from the technical/mechanical side of things....... Once a certified airplane has had the engine removed and swapped out with a Mazda rotary engine and aftermarket reducer drive, what steps are nessary to fly without the FAA crawling up my butt? I'm sure a regular A&P would run like hell from one of these when it came time for an annual... Take it easy on me guys.... I don't even have my wings -- yet! *** Sent via http://www.automationtools.com *** Add a newsgroup interface to your website today. Oh my god, as if the thread about British cars wasn't full of enough horror stories, now we are going to take on Mazda rotary engines. Straight answer: Assuming you can find a Mazda rotary that still runs, you put it in an experimental and name me as beneficiary on your life insurance. For a certified airplane, the cost of the paper alone would buy you one hell of an airplane. -- Jim Pennino Remove -spam-sux to reply. |
On 23 Feb 2004 05:46:33 GMT, JD Butler wrote:
Totally aside from the technical/mechanical side of things....... Once a certified airplane has had the engine removed and swapped out with a Mazda rotary engine and aftermarket reducer drive, what steps are nessary to fly without the FAA crawling up my butt? Go through the entire certification process, including demonstrating that the engine meets all the Part 33 and many of the Part 23 requirements. Otherwise, your plane is permanently(*) in the Experimental category. What's worse, it cannot be licensed as a Experimental Amateur-Built aircraft because you did not build the airplane, hence it has to be licensed in one of the other Experimental sub-categories (R&D, Market Research, etc.). Requirements for each sub-category differ, but they are all more-restrictive than the Amateur-Built one. Depending on how your FSDO interprets the rules, you may be restricted to solo flight only and/or have to get permission for every flight beyond a limited distance from the based airport. (*) It actually can have the original engine re-installed and revert back to its original certification. Ron Wanttaja |
Oh my god, as if the thread about British cars wasn't full of enough horror stories, now we are going to take on\ Mazda rotary engines. Straight answer: Assuming you can find a Mazda rotary that still runs, you put it in an experimental and name me as beneficiary on your life insurance. What's so bad about Mazda rotaries? AFAIK, homebuilders are still successfully using them in a variety of designs; apparently there are plenty available. I only have experience with one Mazda, a little coupe I owned back in the 70's. It ran great for three years until my ex drove it into a flooded underpass in Houston. Smooth and fast as hell (the car, not my ex) but a little rough on gas mileage, it had a 4-barrel carb on it the size of a dinner plate. -- Dan C172RG at BFM (remove pants to reply by email) |
"Ron Wanttaja" wrote in message ... On 23 Feb 2004 05:46:33 GMT, JD Butler wrote: Totally aside from the technical/mechanical side of things....... Once a certified airplane has had the engine removed and swapped out with a Mazda rotary engine and aftermarket reducer drive, what steps are nessary to fly without the FAA crawling up my butt? Go through the entire certification process, including demonstrating that the engine meets all the Part 33 and many of the Part 23 requirements. Otherwise, your plane is permanently(*) in the Experimental category. What's worse, it cannot be licensed as a Experimental Amateur-Built aircraft because you did not build the airplane, hence it has to be licensed in one of the other Experimental sub-categories (R&D, Market Research, etc.). Requirements for each sub-category differ, but they are all more-restrictive than the Amateur-Built one. Depending on how your FSDO interprets the rules, you may be restricted to solo flight only and/or have to get permission for every flight beyond a limited distance from the based airport. (*) It actually can have the original engine re-installed and revert back to its original certification. Ron Wanttaja And I believe you have to go through the certification process every year. |
Dan Luke wrote:
What's so bad about Mazda rotaries? AFAIK, homebuilders are still successfully using them in a variety of designs; apparently there are plenty available. Nothing if they are built correctly using the correct materials. The problem was the original engines had both material and manufacturing problems. As I recall (remember, this was about 30 years ago) the material problem was in the rotor tips and the manufacturing problem was something to do with parallelism. It was common to see piles of engine crates for warrenty replacement at the local Mazda dealer. By the time they got the problems sorted out, the bad mouth was out and the market dried up. I only have experience with one Mazda, a little coupe I owned back in the 70's. It ran great for three years until my ex drove it into a flooded underpass in Houston. Smooth and fast as hell (the car, not my ex) but a little rough on gas mileage, it had a 4-barrel carb on it the size of a dinner plate. The engine, when working, has a great power to weight ratio but lousy mileage. The early problems and the "gas crises" of the mid 70's pretty much doomed the Mazda rotary. -- Dan C172RG at BFM (remove pants to reply by email) -- Jim Pennino Remove -spam-sux to reply. |
| Question about center-line push-pull engine configuration | Shin Gou | Home Built | 4 | June 7th 04 06:57 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Rear engine in a crash question | BernadetteTS | Home Built | 17 | November 24th 03 05:10 AM |
| Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 02:51 AM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
