Burning out a Magneto Drop
Old February 28th 04, 02:45 PM
O. Sami Saydjari
Default Burning out a Magneto Drop
I just received a booklet from TCM called "Tips on Engine Care" (a very
good book...available from TCM's website...http://www.tcmlink.com/). On
page 12 it says "Never but never attempt to "burn out" a magneto drop
with ground run-up. This 'time-honored' procedure succeeds only at the
expense of the engine's mechanical health."
Well, I was taught this time-honored way. What the book does not say is
what you are supposed to do when you get roughness in one magento. Ideas?
-Sami
N2057M, Piper Turbo Arrow III
Old February 28th 04, 03:07 PM
C J Campbell
"O. Sami Saydjari" wrote in message
Really? Does the book say how this will hurt the engine's mechanical health?
To be honest, this "time-honored procedure" seems to have no effect
whatsoever on whether engines make it to TBO or beyond.
Old February 28th 04, 03:21 PM
O. Sami Saydjari
The implication in the book is that it will overheat the engine because
it will cause one to run the engine at high RPM on the ground where
airflow is not as good as in the air. They want you to minimize
high-RPM ground operations.
_sami
Old February 28th 04, 03:25 PM
Paul Folbrecht
You can burn off a mag with as little as 1700 rpm for just a couple
minutes.. surely this isn't hurting anything, at least not during the
cooler months.
_sami
Ideas?
health?
Old February 28th 04, 03:37 PM
jls
-Sami
When you lean your engine and rev it up on the ground you are super-heating
the heads, the sparkplugs, the pistons, the valves, seats, and guides ---
just to clean a fouled plug or two by burning the lead or carbon fouling off
the electrode. It's best to clean the fouled plug. Of course, the problem
is NOT with the mag.
My instructor (who was not at all a gearhead) once did that burn-it-off
thing in a 152's O-235 Lycoming, and it wasn't long before that engine was
in the shop for new cylinders. I remember well the heat. We could feel
it and smell it coming through the firewall, and being a gearhead I knew
that THAT was not good for that engine. Besides, an aircraft revved up on
the ground can hardly cool itself, irrespective of the fact you have leaned
the **** out of it.
I haven't seen it but have heard of burning holes in pistons by overleaning.
By the mag drop you already know which set of plugs, upper or lower, and
then all you have to do is find the misfiring cold cylinder. That's easy
enough and what if the problem is a sparkplug wire or injector? You've just
managed to fry your cylinders in the hopes of getting one out of four or six
to fire.
Leaning an engine takes a little finesse. It shouldn't be done on the
ground unless you're in Denver or on a high-altitude ramp. A small fraction
of that fuel charge is cooling your heads as it evaporates and flows through
the combustion chamber and out the exhaust port. Ideally it is rich enough
to give you a perfect stoichiometric charge plus just a little for cooling.
If you burn it all by leaning you have lost your mixture's ability to
dissipate heat. In addition, some of a lean charge is burning as it
departs the combustion chamber because a lean mixture burns more slowly than
a rich one. Damned if I want my exhaust valve to glow just to clean a
sparkplug.
Old February 28th 04, 04:11 PM
C J Campbell
" jls" wrote in message
fraction
through
enough
cooling.
than
sparkplug.
I think you are exaggerating. More than a little bit. I guarantee that even
at sea level you are going to get spark plug fouling if you do not lean your
engine somewhat during taxi -- especially when taxiing in. You just
completed a descent with the mixture full rich and the engine idling -- lots
of cooling and plenty of opportunity for spark plug buildup. I suspect that
the detonation and premature ignition that result from your recommendations
are even harder on an engine than occasionally clearing a spark plug.
Old February 28th 04, 06:22 PM
jls
"C J Campbell" wrote in message
fraction
through
enough
cooling.
than
sparkplug.
Yeah, I don't know if the exhaust valve glows or not but I know when one
gets too hot and don't plan to let it happen to my engine.
your
lots
I don't see any big problem with leaning as you taxi. We lean sometimes on
descent and will often lean if an engine tends to miss or surge. It
depends on the engine and airplane too. Leaning at idle, or close to it,
as in when you are taxiing, won't fry your cylinders. But leaning at high
static rpm's will, sooner or later. Thus the reason for TCM's advice not
to do it.
I suspect that
recommendations
Explain what recommendations I have given which will cause detonation and
premature ignition. Fuel of the improper octane, engine hot spots,
improper leaning and engine conditions I am generally opposed to cause
detonation and preignition. See, e. g.,
http://www.sacskyranch.com/eng180.htm
Old February 28th 04, 06:30 PM
jls
[...] I suspect that
recommendations
Here's an even better link to clear up the confusion:
http://www.sacskyranch.com/deton.htm
And I always wondered why combustion chambers in angle-valve engines were so
clean. I just learned some of the reasons why. They burn cleaner.
Old February 28th 04, 06:31 PM
Matthew P. Cummings
Very true, and it sounds like the 152 he's talking about got cooked, not
leaned to burn off plug fouling which doesn't take that long.
Old February 28th 04, 07:34 PM
jim
I have no problem burning off a fouled plug, just like last night. Left,
lower plug, seems to be a problem. Another pilot says it is a problem
that shows up just after re-fueling and you prime before a re-start.
*** Sent via http://www.automationtools.com ***
Add a newsgroup interface to your website today.
Burning out the pitot heat? Mitty Instrument Flight Rules 3 December 30th 04 05:04 AM
Drop in and say hello Gilan Home Built 0 June 4th 04 05:12 PM
Economist: Let the dollar drop Luca Morandini Military Aviation 5 February 14th 04 05:58 PM
:-) let enola gay drop one more :-) old hoodoo Military Aviation 3 December 28th 03 05:39 PM
Ellery Queen and the Case of the Missing Magneto Gear Teeth MikeremlaP Owning 3 July 26th 03 03:01 AM
