TIO-540 in '79 TR182. I had a top overhaul 68 hours ago. Changed out the
mineral oil at 18 hours and just changed the 15-50 oil at 50 hours. Chromium is 30.4. I suspect that new cylinders will cause a higher than normal Chromium for a while, but is this unusally high? Thanks, Michael |
In article UD21c.165927$uV3.715301@attbi_s51,
Michael 182 wrote: TIO-540 in '79 TR182. I had a top overhaul 68 hours ago. Changed out the mineral oil at 18 hours and just changed the 15-50 oil at 50 hours. Chromium is 30.4. I suspect that new cylinders will cause a higher than normal Chromium for a while, but is this unusally high? I have cermichrome cylinders in an IO-540 with about 870 hours. I got 41ppm chrome and I noted that I had cermichrome cyls (AOA note 993) and they returned "all values appear normal". For context that's about twice as much as iron, 8 times as much as Al, and 10 times as much as Silicon. -- Ben Jackson http://www.ben.com/ |
NEW - Exposing more on the Felony Fraud SwiftLiars Organized Crime connections | Psalm 110 | Military Aviation | 0 | August 21st 04 09:40 PM |
NEW - Exposing more on the Felony Fraud SwiftLiars Organized Crime connections | Psalm 110 | Military Aviation | 0 | August 21st 04 09:39 PM |
FAA Knowledge Test Results | Richard Moore | Instrument Flight Rules | 4 | October 12th 03 07:10 AM |
AOA - Aviation Oil Analysis Results Missing? | George Sconyers | Owning | 5 | September 27th 03 11:29 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
